Dear Sir, I have a pichup toyota 22RE 2.4L years 1989. The problem is, we put the batterie in reverse connection. So, the ECU and almost electrical wiring were burned.
    Brigadier General:
  • 4,044 Answers
You have a problem that is not going to be an easy fix. Most of the electronics have safety systems to protect them from this so the good news is you may not have to replace the ECU, Alternator or starter. The bad news is you will have to replace your wiring harnesses or at least remove them and replace the burned sections. Then it will just be a matter of going through and replacing components that were damaged. Depending on how much time I was willing to commit to the project I would look at it as a long time project for fun and do it a little at a time, Part the vehicle out or look for a push -pull-or tow trade in event. The job can be done but it will take a lot of time.
Posted on Sep 29, 2010
1989 Toyota 4x4 22re? 6mm hex bolt missing from thermostat housing, could that cause water to leak into the head?
I do not see how that could possible leak into the head unless you had a crack in the area that the water was leaking. It would at least not be because of the bolt missing.
Mar 23, 2016 | Toyota Cars & Trucks
How to reset ecu on toyota pickup?
Disconnecting the battery for 3-5 min will erase all stored adaptive memory on PCM.
Jun 15, 2012 | 1994 Toyota Pickup
How do i tell if my 1989 toyota sr5 4x4 4 cylinder is a 22r or a 22re, and what is the difference please.
If it has a carb it's a 22r, if it has a throttle body (fuel infection) it is a 22re.
Apr 16, 2011 | 1989 Toyota Pickup SR5
WHAT IS BEST WAY TO GET TO STARTER FOR 89 TOYOTA TRUCK TO BE ABLE TO REPLACE IT. IT IS LOCATED UNDER THE ENGINE AND BEHIND THE RIGHT FRONT TIRE. TRUCK IS 4 CYLINDER, 4WD, 22RE.
It a bit of a tight sueeze but off you lift the car up on stands u can get it out from under the truck. Make sure you disconnect the battery first.
Jul 19, 2010 | 1989 Toyota Pickup SR5
1989 22re valve torque specifications
WOW you never made a mistake MR TOYOTA ????
It seems your just lurking in old posts to stir up trouble.
And for you information that engine does have lifters (more correctly called CAM Followers, but they are a type of hydraulic lifter.
Sep 03, 2009 | 1989 Toyota Pickup SR5
89 toyota pickup electrical problems
Sounds like you have an intermittent electrical problem. Check your positive battery wire going into your fuse box the connection becomes loose. I have seen 2 or 3 Toyota pickups have the a similar problem. Also check Battery connections and the ground cable.
If your pickup has a loose battery cables and/or wires it can not charge to it full potential no matter how new your alternator or your battery. Try turning on your head lights and wiggling your battery wires if the lights go dim or flicker, chances are that wire is loose or has a bad connection.
Mar 19, 2009 | 1989 Toyota Pickup SR5
1989 toyota 22re pickup lopes at idle and
possible egr valve problem,you can start with disconnecting the vacuun source to it and see if it rubs better but if its stuck open you may not notice any change,you can look underneath the valve with a light and mirror and apply vacuum to the valve and watch for the diaphram to move up and down,have you checked tec ecu for codes? if you need more info let me know have a good day DB
Feb 14, 2009 | 1994 Toyota Pickup
Pinout ecu toyota 22re 1989 p/up
this should do the trick
http://media.photobucket.com/image/1989%20toyota%20pickup%20ecu%20pinout/4runnerchevy/other%20conversion%20stuff/ecupinoutdiagram.jpg
Feb 12, 2009 | 1994 Toyota Pickup
AFM 22250-65010
can you tell me what this is in regards to what on the vehicle?
Sep 01, 2008 | 1989 Toyota 4Runner
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
