Question about GE DSXH43EAWW Electric Dryer
Grinding noise when it gets hot. sounds like metal rubbing. barrings? still heats good
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Sep 29, 2010
2005 Ford Explorer is making a grinding noise
I had some issues with my 2005 explorer left rear. It was making a creepy old door sound at low speeds and then a high pitched whisel at high speeds. That turned out to be a broken wheel bearing and had it replaced. Note each wheel has two wheel bearings. After that a new noise developed that sounded like metal scraping/ grinding metal. It end up being the brake dust cover got bent when they replaced the bearing and it was rubbing something, the fix for that was bending it so it didn't rub. I hope this helps.
Sep 03, 2012 | 2005 Ford Explorer
Freezer making a grinding noise on and off
If it is a metal to metal grinding noise it could be a warning of a potential compressor failure. BUT try to localize the sound before you panic!
It could also be one of the fans wobbling or rubbing against the housing.
Jan 07, 2012 | Amana ATB1832AR Top Freezer Refrigerator
At slow speeds, there seems to be noise coming from the front like a rubbing or grinding sound, Could it be the struts orsome bushing problem?
Could be the front brakes are low. They have a small metal scraper which rubs the rotor when the pads get low. Typically the noise stops when you put brakes on. Most prominant at low speeds.
Otherwise I would check the sway bar. They can somtime shift sideways in their bracket and cause similar symtoms mostly while turning.
Hope this helps.
Jul 07, 2011 | 2004 Ford Escape
When the dryer gets hot, the tumbler begins to make a continous squeaking noise as if there is metal to metal; not a grinding noise. If you allow it to cool down and restart, it doesn't start until it...
Well ya never mention in your question what brand you have but a GE or Hotpoint dryer has a small plastic insert that wears thin over time. It begins to do a squeak squeak squeak type of noise.And that noise is intermittent, on a Frigidaire model the noise would start out low and gradually get worse. The bearing sometimes gets so bad it gets chopped off and the tub falls into the heating element.
Jun 30, 2011 | Dryers
Grinding sound when turning
if its a grinding/knocking type sound then it could be the cv joint gone bad.the side that makes the noise when you are loading during turning(turning left you are loading the right cv joint and vise versa)that is the side the bad joint is on.it will happen whether or not your foot is on the brake.if the noise happens as strickly a grinding noise like when brakes are metal to metal when applying the brakes then it could be brakes need replacing.also have seen were if the inner fender is loose or oversize tire is on it can rub sounding like grinding.
Apr 08, 2011 | Nissan Frontier Cars & Trucks
Grind steel on steel noise rear passanger side when coming to a stop do you know what the problem is?
hi this sounds like your rear brakes are warn and the metal grinding noise you can hear might be the metal part of the pads rubbing on the disks, either that or your break shoes are doing the same if they are the drum type rear brakes, hope that helps
Dec 02, 2010 | 2000 Dodge Durango
Rotation noise from rear end while riding
If the rubbing sound you have does not have a metalic sound to it then try rubbing a bar of soap on the inner side of the drive belt. Sometimes we keep our rides too clean and remove the natural lube in this area causing a sound as you describe
Jul 20, 2010 | 2008 Victory Vegas Low
When moving in gear car makes a sharp grinding noise like knifes being sharpened - so frightening
This means that you need to replace your front brake pads. There are two metal bars on the brake pads that rub against the rotor when they get worn down to a certain point, causeing that "nails on a chalkboard" sound whenever the car moves. It's just a safety indicator that most car manufacturers use, as the horrid sound is hard to ignore, and people would rather get it fixed right away than endure it any longer. Hope this is what you were after.
Dec 09, 2009 | 2006 Acura RL
Front grinding/rubbing sound when accelerating
if you slide under the truck and try moving the cv with your hands and there is any looseness in joint or noise the joint is indeed worn out, the cv joint if bad should not stop the truck from shifting into 4 wheel drive it could be stuck in 4wd and this would cause cv joints to break, if u have access to lift get all tires in air and try2 vs 4 drive and see if tires turn if not lift front tires off ground tires should turn freelyin 2wd, as u turn tires listen to wheel bearing and shaft noises for grinding clunking indicating bad parts, simple tricks that may help u find problems for cheap good luck!!
Jul 09, 2009 | 2005 Ford F-150
My GE WDSR2080G makes a metallic rubbing noise during agitation
Take front off and watch while it agitating useing a good light and see if you can tell where the noise is coming from 52c26ee.jpg
Oct 21, 2007 | GE WDSR2080D Top Load Washer
GE DSXH43EAWW Electric Dryer Logo
106 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
