Question about Intel D101GGC Motherboard
Keyboard and mouse problem
When I start my pc after some time keyboard and mouse get's hang,but not the processor.Only keyboard and mouse get's hang.
  • 105 Answers
1. You can disconnect the Hard disk then test the system if keybaord and mouse working, then there i s problem with your operating system or RAM.
2. Processor fan will rotate even after system hang up.
3. Check the RAM for cause
4. Operating may need to reinstall
Posted on May 25, 2008
On start up fan runs, no beeps, black screen, no response from keyboard & mouse. Unplugged everything for 30 minutes, then tried again, start up began then went to black screen, no keyboard, no m
in your case, there might be some problem with the main board.
usually no beeps will related to the processor error / mainboard error / ram error / PSU error
to check the processor : try to exchange the processor with the same type.
to check the Memory: try use rubber eraser to clean the cooper plate of the memory. then plugged it again.
in case if there is a power supply error, then try to exchange the power supply using other PC PSU.
if all steps above are checked, the problem might be at the mainboard. in that case, replacement will be the best option.
Jan 20, 2012 | Acer Computers & Internet
My mouse and keyboard won't work...after i restart it several times,then it works,,,it will wake up out of standby or start up,but the mouse won't move,sometimes when the mouse does move the keyboard won't...
i assumed that you use device PS2 (Mouse & Keyboard), this rarely situation, but you haved installed and not more better, because the problem not with your system, but with your hardware, maybe you can change with USB Mouse Device and for Keyboard PS2 is better than USB Keyboard.
Mar 01, 2011 | HP Pavilion Media Center TV M8200n Desktop...
Keyboard and mouse pad getting hang
Try to check on your power adapter to see if it is delivering well. These adapters at times freeze the laptop that it can fail to work. You therefore might need to replace the adapter.
Also, You will need to check on your processor and RAM. See if they work fine.
Dec 03, 2010 | Acer Aspire 4530-5889 Notebook PC
I powered up the board. all fans lights came on for about 4 seconds also only had ram/ processor hooked up
Hi.
the problems lies under the fixing your processor.
Remove processor. replace it again carefully. remove mouse and keyboard. remove any PCI and AGP etc.
Start the pc " POWER ".
If it continues doing the same, - no sweat,,,
Check for a new Processor and replace ram as well.
Start the pc. "power".
If success comes up. then by that time you would have the solution.
plug keyboard and mouse..
Start the computer and enjoy.
Good Luck
Nov 11, 2010 | Intel D945GPM Motherboard
Keyboard
you can use the On Screen Keyboard , please follow the bellow steps:-
1.click on start [Bottom at laft] after that
2. Programms
3. Accessories
4. accessibility
5. on screen keyboard
Jan 19, 2010 | ASUS Essentio Desktop with Intel Pentium...
Foxconn MoBo 947p7aa & keyboard lockup
Check if the processor temperature. ... sounds like that could be the problem. It would cause the computer to FREEZE the moment you start "working" on it because then the processor must do it's thing but it instantly overheats because either the processor cooler fan is'nt functioning correctly or the thermal paste has hardened and no longer offers a "connection" between the processor and the fan
Jul 06, 2009 | Foxconn (865G7MC-ES) Motherboard
Why my mouse and keyboard hangup when i attach my flash
It sounds like you could be low on memory or your processor is working super hard.
To fix this, first, check and see how much ram you have by right clicking on "My Computer", then click "Properties". Your processor speed and ram will be shown in the window. If you have less than 256 MB of RAM, or a processor less than 1.2 GHz, then you might need to upgrade your processor or RAM.
Apr 16, 2009 | MSI 848P Neo-V (MS-6788-040) Pentium 4...
Computer hangs during xp installation
make sure you have met the minimum hardware requierments when installing your XP...which is
• PC with 300 megahertz or higher processor clock speed recommended; 233 MHz minimum required (single or dual processor system);* Intel Pentium/Celeron family, or AMD K6/Athlon/Duron family, or compatible processor recommended
• 128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
• 1.5 gigabytes (GB) of available hard disk space*
• Super VGA (800 x 600) or higher-resolution video adapter and monitor
• CD-ROM or DVD drive
• Keyboard and Microsoft Mouse or compatible pointing device
Apr 11, 2009 | Microsoft Windows XP Professional for PC
Problem when any file right click by mouse or keyboard
IS this a laptop or desktop. If it is a laptop, are you using the built in mouse pad. If it is a desktop is the mouse (optical) or (ball), USB (rectangler connector) or PS2 (round)?
Aug 06, 2008 | IBM Lenovo Mouse 76H6618
Keyboard/Mouse Freezes System Sporadically
Wireless routers generally are 2.4 Ghz, as well as the wireless keyboard and mouse. I think there is interference from the router that causes the keyboard and mouse to hang. I had the same problem with my 2.4 Ghz cordless telephones and my new wireless router. Went to 5.8 Ghz telephone and the problem stopped. I'm not sure yet how to work around the keyboard/mouse issue.
Sep 17, 2007 | Computers & Internet
Intel D101GGC Motherboard Logo
167 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
