Question about Microwave Ovens
Logik L25MOV10 Mini Oven - Microwave Ovens
Microwave oven turned off completely checked outlet ok no lights or power on appliance. Manuel shows nothing about possible fuse to replace or diagram.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find your mini-manual, or if you want to look at it before removing the controller, you can download it here (just enter your model number).
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Sep 08, 2010 | Whirlpool MH1150XM Convection/Microwave...
No power to gh4155xps
These particular Whirlpool models are a bit overdesigned, in my opinion!
Some have as many as 4 fuses and 3 thermal cutouts (TCOs) or thermostats, any one of which can render the oven "dead" if blown.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
If you don't find your mini-manual, or if you want to look at it before removing the controller, you can download it here (just enter your full model number with suffix from the tag in or on the oven).
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Jan 09, 2010 | Whirlpool GH4155XPS Microwave Oven
I have a GE profile spacemaker microwae oven. The
Yes. You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
If yours is a counter top model, you have to remove the outer cover, and the mini-manual will probably be in an envelope inside the wrapper.
Jan 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My lower oven does not work; top oven works fine
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Thereshould also be a "mini-manual" (tech sheet) hidden inside the unit behind thecontrol panel or hidden inside behind the back cover, etc., and it's very helpful when troubleshooting, testing, and locating components.
Nov 24, 2008 | Microwave Ovens
GE Advantium SCA 1000 oven has no power
I would suspect a blown magnetron thermal cutout or thermostat (whichever it has) or cavity thermal cutout or thermostat (whichever it has).
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our site, we now have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you'd want to scan and e-mail or copy and fax the mini-manual (or at least the "schematic diagram page) to me, I'd be happy to make more precise suggestions.
And you'd pretty much need to remove it from the wall and take the cover off to access either of these suspected parts.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
fax 866-481-2802
Oct 04, 2008 | GE Advantium SCA1000H Convection /...
GE JVM150001 Microwave
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Can you scan and e-mail or photocopy & fax the "schematic diagram" portion of the mini-manual to me?
William E. Miller
prototech@usa.net
fax 866-481-2802
Sep 28, 2008 | Microwave Ovens
Microwave Ovens Logo
147 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
