Question about Samsung Televison & Video
I have a samsung LCD tv but the i cant get the touch buttons on the tv to work
    Novelist:
    Champion:
  • 203 Answers
All I can tell you to do that might help is to unplug the set from it's power source for 5 minutes, then reconnect it and try. Also, look to make sure one button is not stuck in the engaged position. I've done the Samsung warranty work for several years on those sets and only recall needing parts for this problem once. It was front control pcb and required major disassembly and reassembly. Hope that helps fixya.
Posted on May 27, 2008
We have to push the on button on our TV from 20-100 times to get it to turn on. Have changed batteries and restarted to no avail.
"He said our TV has a problem". Brilliant! To be more specific, he could have suggested switch failure or a failing power supply.
Apr 26, 2017 | Samsung Televison & Video
How to shut off manually
UN55D6400UF TV Will Not Power Off If your TV is on but will not power off when you press the power button, you could be having an issue with your remote control or a faulty circuit inside your TV.
To determine the source of your problem, follow these steps:
  1. Power the TV on if it is off.
  2. Unplug the TV from the wall outlet for 30 seconds, and then plug the TV back in.
  3. namo_fileview.jsp?type=nfs&pid=decisiontree&did=57355&cid=yokn68wxkhym@namo.co.kr&sep=%7c
    1. Press the POWER button on the remote control.
    2. [img src="http://support-us.samsung.com/cyber/namo/namo_fileview.jsp?type=nfs&pid=decisiontree&did=57355&cid=79HKC8BOY9YC@namo.co.kr&sep=%7C" height="51" border="0" width="50">
      • If the TV powers off when you press the POWER button on the remote control turn the TV back on continue to Step 4.
      • If the TV does not powers off then there is a problem with the remote control. Click here to go to the Remote Control troubleshooting section of this guide.
    1. Press the POWER button on the TV.
      • If the TV powers off with the remote but does not power off with the power button on the TV there could be an issue with the touch sensor on the TV. Before setting your unit up for service try these two things.
        1. Try sliding your finger accross the power button.
        2. Have other people try using the touch buttons on the TV.
        3. If either of these two options work then there is not an issue with the touch sensor on the TV. There are many variable that can limit the conductivity of a persons fingers. The conductivity of your fingers might not be enough to easily control the touch sensor on the TV.
        4. If the TV does not power off when you press either the POWER button on the TV or on the remote control, then the TV will need to be serviced. Click the Create online service request button below to have the TV repaired.
Mar 26, 2014 | Samsung UN55D6400 - 55" 1080p 3D LED LCD...
My samsung corbi s3653 tuch pad dont work
If you can get the keypad up pres *#0*# and check the lcd test, if you cant press the touch pad you need to call samsung on 1300-362-603 for service booking
May 02, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
Tv broken?
YOU WILL HAVE TO REPLACE THE POWER SUPPLY IN THE TV
Aug 24, 2009 | Samsung LN-T4671F 46 in. LCD Television
Cant turn on lost remote
Good day sir/maam, there are really few manufacturers of TVs that adopted to use a remote to turn on the TV. so if the remote is lost, you cant power it on, check out your dealer if they have a spare remote, or visit any electronics depot for any universal remote that your TV is compatible with, ask the dealer if it would work on your Samsung TV.
Note: browse your user manual, if it has a secret button or a combination of buttons to power on your TV. that may help.
Aug 07, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
Seemed to short circuited through power surge from
You have a bad Main bd. Have a trained Samsung tech repolace the Main bd.
Jul 02, 2009 | Samsung LN-T4671F 46 in. LCD Television
Circuit diagram Samsung LE23R88BDX - LCD TV
when I turn off and then Turn on after 10 minutes the TV notwork(by using remote or touch button). I try to disconnect power supply andthen reconnect and waiting a couple of minutes and turn on but no work (nosound and black desktop) .I repeat this procedure many times so some timework and sometimes not work. please help me to solve this problem
Feb 24, 2009 | Samsung Televison & Video
No picture
try chicking the horizontal section or vedio section...
Jan 28, 2008 | Samsung LN-S4051D 40 in. LCD Television
Samsung LCD "keys locked"
Hey it taken me a few years to find a solution to this problem.
I also own a Samsung syncmaster 2032mw.
BTW you must hold / use the "Menu key on the side of the TV", as holding the remote key dosen't work!!
Many thanks dopeNL
Dec 28, 2007 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Televison & Video Logo
Henry  Thomas
Henry Thomas
