Question about Epson Stylus CX5000 InkJet Photo Printer
All 4 color cartridges are fine and it came out blank on the sheet of paper?
  • hughestech Sep 29, 2010
    Does the nozzle check performed from the front panel of the printer show up on the page? Try this and please advise so that we may resolve your issue.
    Scholar:
  • 78 Answers
First, try printing the nozzle check from the menu on the printer itself. If that is fine, then try to print a test page from your printers properties panel on the computer ( Printers, right click on the printer and select properties, and then click on print test page at the bottom). If that doesn't work, remove and reinstall the printer software. If it does work, try printing from another program, as the issue may be with the program you are trying to use. Wordpad is always a good test program for this. Please let me know if you still have issues so we can fix this issue and get you printing again.
Posted on Sep 29, 2010
Will not print
get a new printer,you got 4 years out of it
May 19, 2015 | Kodak Office Equipment & Supplies
Paper comes out with nothing on it
On the new cartridge, did you remember to remove the plastic seal from the toner? Do you get blank sheets only when you print or when you make copies too? Were you careful when clearing the paper jam or could you have accidentally damaged the printer?
Jan 07, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Ink cartridge cannot be recognized
Are the cartridges you are using remanufactured? Some printers are very picky about this and will only work with manufacturer cartridges. What brand of printer?
Jul 26, 2017 | Epson...
Just installed new cartridge but blue and red colour is not appearing on calibration sheet..?
Sounds like a bad color cartridge. Start by cleaning the bottom of the cartridge where the ink comes out of with a blank paper until the ink shows on the paper for all colors. If you can't get them to show all colors i would take the cartridge back and tell them it is defective.
Mar 07, 2011 | Kodak ESP 5 Printer
No black ink is appearing on paper
If this is an old printer. The nozzles might be clogged. A Q-tip with a little alcohol might get some of that dried ink out. Be careful it could get messy. Also see if your printer has a built in cleaning test. you might have to access the test from the printer tools on your computer.
Jul 30, 2009 | HP Officejet 5510 All-In-One Thermal...
When I click "Print" paper feeds through the printer, but nothing prints
try to reload your catridge on the carrier or cartridge holder..
and clean your printer tab circuit and also the cartridge tab circuit and run maintenance page on it..
go to your printer panel and select maintenance ..browse clean printhead..and print maintenance page..to clean the cartridge..
May 18, 2009 | HP Office Equipment & Supplies
The printer is printing blank sheet
Hello Shirelle,
Make sure there is nothing covering the jets on the cartridge. Also how long has it been laying around? it might have dried out, and/or expired. On new printers the cartridges have expirations and it will not use them after a certain amount of time. Also try a printer self cleaning and see if that does anything. If none of that works, it might be the printer. - Vincent
Nov 23, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
HP Laserjet 1500 Color, Print out Blank
Hi devi960:
Pages print, but all
colors do not print or
the pages are
completely blank.
One of the print cartridges might be
low or empty.
Run an engine test and see if all four colors print. If
not all colors print, replace one or more of the print cartridges. If the
engine test is successful, replace the formatter.
If the printed pages are completely
blank, the file might have blank
pages.
Check the file to make sure that it does not contain blank pages.
A print cartridge might be low or
empty.
Check the printer control panel for a Supplies Status message,
print a Supplies Status page, or use the embedded Web server
(HP color LaserJet 2500 series printers only) to see the levels
remaining in the print cartridges. Replace any print cartridges that
are low or empty. Messages are not created for non-HP print
cartridges.
If you are using non-HP print
cartridges, one or more print
cartridges are low or empty. The
control panel lights do not indicate
low or empty for non-HP print
cartridges.
Replace one or more of the print cartridges.
Font DIMM might be selected but the
font DIMM is not physically installed in
the printer. (This issue applies only to
printers using an Asian-language font
DIMM.)
In the settings for this printer, clear the Font DIMM check box on
the Configure tab if no font DIMM is installed in the printer. Select
the Font DIMM check box only if the font DIMM is physically
installed in the printer. If you think that the font DIMM is installed,
make sure that it is installed correctly.
The paper curls when
exiting the top output
bin.
The paper needs to print to the
straight-through paper path.
Open the rear output door to print to the straight-through paper
path. Remove each sheet as it exits the printer.
The stack was slightly curled when it
was placed in the tray.
Turn the stack over in the tray.
The paper does not meet
specifications.
See the user guide for information about print-media specifications.
If you are printing on light media, the
Type setting might not be correct.
Select Light in the Type is field in the printer driver.
Nov 13, 2008 | HP LaserJet 1500L Printer
Printer won't stop printing alignment sheet, following changing of ink cart.
my printer only printed 1 page out of 3 so now it wont stop. it pulls the paper in and comes out blank. this will keep going unless i turn it off. how do i reset my printer?
Aug 20, 2008 | Office Equipment & Supplies
Epson Stylus  CX5000 InkJet Photo Printer Logo
60 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
