Question about Kenmore 43142 Front Load Washer
When I fill detergent, bleach, and fabric softener into the appropriate receptacles of my Kenmore front loader I see it all run into the machine immediately. Can this be correct?
    President:
  • 1,554 Answers
It is definitely not normal for the detergent, fabric softener, and the bleach to be dispensed immediately. They must be dispensed at the appropriate time in the wash cycle. It's either the machine is not level, dispensing mechanism is malfunctioning, or the dispenser compartments are excessively filled. There are level markings for the bleach and fabric softener compartment where they can be filled up to before dispensing on their own begins. Dispensing should only start after the compartments are filled with water.
Posted on Sep 29, 2010
I need a manual for Spectra TL3635 INOX washer
The manual doesn't appear to be available online, but you don't really need it.
Remove the drawer by pulling it out, and then lift and pull. Are you sure it isn't marked what goes where? My Whirlpool washer is marked in raised writing.
The detergent is one large compartment that is open at the back.
The bleach dispenser is usually in the middle and is small.
The fabric Softener is full depth, but has a system which siphons the softener out when water is added to it. In other words it is a reservoir that holds the fabric conditioner until needed.
With the drawer removed, turn the machine on to do a small wash. Water will come down on the section for detergent at the very beginning. towards the end of the first fill, another jet of water will come down to add bleach to the already filled machine. After the rinses, when it gets to final rinse, a jet of water will hit the Fabric Conditioner compartment. Get ready to insert the drawer if the water splashes out, or plug the front with a tea towel.
Aug 12, 2015 | Washing Machines
How do i remove the drawer to clean it out the bleach, softener, detergent dispensers?
The dispenser slides out . There are plastic slideson both sides of the outer dispenser tray which run into grooves internally . be careful not to force its removal as you will damage the tray
Feb 10, 2015 | Kenmore Washing Machines
Fabric softener compartment
You will need to clear the line from the fabric dispenser to the tub.
Oct 15, 2012 | Kenmore HE2 Plus Front Load Washer
How to operate the washing machines front load washer brandt bf850
  • Open the front door and load the clothing into the washing machine. Check the owner's manual for the maximum load size. Overloading the washing machine may interfere with its ability to spin the clothes and rinse them clean.
  • Fill the detergent receptacle on the front of the washing machine, making sure not to fill it past the indicated line. Always use a liquid detergent that is designed for front-loading washing machines.
  • Add bleach or fabric softener, if needed. Most front-loading washing machines have a section for fabric softener inside the detergent receptacle. Check the instructions on the bleach to find out when it should be added to the washing machine.
  • Close the front door of the washing machine and make sure it locks into place. The machine usually will not turn on unless the door is securely locked.
  • Check the owner's manual to find out how to select the different options and wash cycles. As a general rule, use warm or cold water for most types of colored clothing. Hot water should only be used when washing white cotton items.
  • Start the front-loading washing machine and let it run through the entire wash, rinse and spin cycles before opening the door to unload the clothing.
  • Please rate this solution. Regards.
    Nov 04, 2010 | Brandt WFH1176 Front Load Washer
    Maytag a112 manual on how to add bleach AND fabric softener
    Hi
    Choosing Your Detergent, Bleach, and Fabric Softener..
    Learn what the different items you need to wash your laundry.
    Liquid Laundry Detergent and Fabric Softeners
    When using liquid laundry detergent, you do not want to poor it directly on your laundry. The dyes in the liquid laundry soap could stain your clothing. You will want to start your washing machine and add the liquid laundry soap while the water is filling the washing machine.
    You then can add your laundry once you have about and eighth of the washing machine tub filled. This will ensure your laundry doesn't become stained by the detergent. You should only add the amount that is poured into the cup to the fill line. When you add more, you could find yourself wading through mounds of bubbles overflowing from your washing machine.
    The same reasoning applies to liquid fabric softeners. However, liquid fabric softeners are added to the washing cycle after the initial washing cycle is finished. You will want to add the fabric softener once the washing machine has filled with water and started to agitate. This keeps the fabric softener from touching the laundry and will work it into your clothing better.
    Powdered Laundry Detergent
    You will want to add one cup of loose laundry detergent to your washing machine in the same manner you would do the liquid laundry detergent. By doing this, the powdered laundry detergent will dissolve easier.
    Bleach
    When adding bleach to your laundry, there is a small triangular cup in the corner of your washing machine. By adding one cup of bleach into that dispenser, the bleach will be added to the laundry at a precise time during the wash cycle.
    Setting Your Washing Machine
    Most washing machines have three or four cycles. For instance, the Maytag Washer I have has four cycles, regular, permanent press, delicate, and soak.
    Regular Washing Cycle
    The regular cycle is used for the following types of clothes and other apparel:
    • Jeans
    • Towels
    • Blankets
    • Sheets
    • Quilts
    • Bedspreads
    The soil types for this cycle are heavy, normal, and light. This means clothes or other articles that are lightly too heavily soiled should be washed in this cycle. This is due to the washing cycles can be set from a minimum of eight to fourteen minutes maximum. You can use all three of the water temperatures in this cycle.
    1Permanent Press Washing Cycle
    The permanent press washing cycle is used on the clothes that may or may not need to be ironed.
    Such as:
    • Blouses
    • Shirts
    • T-shirts
    • Under garments. This would be your unmentionables and socks.
    • Jackets
    • Sheets
    • Baby Clothing
    The soil types for this wash cycle are normal and light. The washing times for the permanent press cycle are six minutes to ten minutes. You can use all three washing temperature modes for this cycle as well.
    Delicate Washing Cycle
    The delicate washing cycle is normally used for sweaters, cotton, silks, and other fabrics that need to be washed with care.
    The soil types for the delicate cycle are normal and light. The washing times for the delicate cycle are four and six minutes. It is best to wash your delicate clothes in warm or cold water. Always wash clothing that is more than forty percent cotton in cold water to prevent shrinking.
    Soak Washing Cycle
    The soak cycle would be used for heavily soiled clothing, such as, football and baseball uniforms. This will help rid the uniforms of caked on mud and grass stains.
    You can also use this cycle if you wish to only bleach your white's once a week or once a month with bleach.
    Washing Your Laundry
    Choose the cycle you need for your laundry. Add the laundry detergent, fabric softener, and bleach (remember regular liquid bleach is for white clothes only.) Start the washing machine and let fill to dissolve the dry detergent or to mix in the liquid detergent.
    Now add your clothes to the washing machine. Clothes the lid so the washing machine will continue to wash your clothes.
    If you are using a Laundromat, put your clothes in the washing area and shut the lid or door. Add your detergent and other cleaning items in the correct compartments. Put in the correct amount of change so the washer will start.
    Thanks for contacting fixya.com
    Nov 13, 2009 | Maytag Washing Machines
    Detergent drawer filled with water
    remove the drawer and clean the siphon it sounds as if it is blocked up either with powder or concentrated fabric softener. this should fill up with water and then empty itself due to gravity. the siphon should look like an upside down cup on a cylinder.
    Jul 23, 2009 | Kenmore Elite 45986 Front Load Washer
    Which compartment does my detergent/fabric softener go in?
    You can get all of Whirlpools user guides here:
    http://www.whirlpool.co.uk/app.cnt/whr/en_GB/pageid/pgsrvifuhome001/ifu/home Generally the one one the left - is for pre-wash (if clothes really soiled), the middle one is for powder (if you use it) and the last one is for softener or bleach.
    I just use liquitabs - which go directly into the drum, and fabric softender.
    Jun 16, 2009 | LG WD-16110FD Front Load Washer
    Washing instructions
    My book says for the Axxis WFL 2050/WFL 2060 : from the left while looking at it from the front: detergent for wash, stain remover, middle: fabric softener, fabric conditioner, right one: detergent for soaking agent. (Do not use chlorice bleach in this wasking machine).
    Oct 11, 2008 | Bosch Axxis WFL 2060 Front Load Washer
    HE washing machine
    As you look at your dispenser. The Left compartment is for Detergent. The Right Front compartment is for the Fabric Softener Liquid. The Right Rear compartment is for Chlorine Bleach.
    Jul 27, 2008 | Kenmore Elite 45986 Front Load Washer
    Kenmore 43142 Front Load Washer Logo
    222 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
