Question about Samsung Home Security
Yes i have a ssc14web observation system and we lost power, when it came back on the system would not show all 8 cameras i unhooked all 8 of them and hooked them up one at a time but when i hook up the 8th camera the system goes blank and flashed back and forth between quads and does not show any cameras
    President:
  • 2,777 Answers
I see, if you hook that 8th camera to a different location on the device, does it do the same? It may be a problem with that camera that occurred when power was lost, that is what it sounds like. Test it by plugging it in 7th for example...
Tim
Posted on Sep 29, 2010
How do I pair up cameras when 4 out of 8 go out
NEED TO CHECK THE POWER SUPPLY THAT FEEDS THOSE FOUR CAMMERA'S
Nov 12, 2014 | Lorex Sg19ld804161 19 Inch Lcd Observation...
Why my coby mid8065 stop working i try the reset button but still nothing happen, it show the coby logo and the android but didn't go far.
Steps on how to do the restart. -You have to turn off the system. -Then press and hold the power button until you will see a message that will popup in a window that saying "Device Options"Appears on the screen. -Then select the power off again then you can see it again.You can be able to check that it first. -Then just select okay And while holding down the -Back -Button -Then Press and hold the power button. -Until you see the Coby`s Logo -Then wait until it change to Android Logo. - Then press the Back button.And Then the system menu will appear in the screen. -And then choose the wipe data/factory reset. >Home >Menu Buttons >Press the back,the button once you select the wipe data/factory reset then just click option. Then the confirmation that you will see in the screen Is a "yes" "Option". Then Choose "yes"-delete all user data,option by using the "Home"and "Menu"buttons. Then it will perform the factory data reset. -wait until it done. -Then once your done the main system menu has to appear in the screen. -And then reboot the system. -Then you have to press the back button to reboot the system. -The system will reboot the initial factory data setting. -All the user data will be lost. -Then Give the reboot,at least for 5 minutes. -Then Do not assume the unit has frozen.
Sep 08, 2014 | Coby MID8065-8 - Kyros MID8065 8 8 GB...
Motorola mini defy wont load only motorola shows
How to hard reset:
Warning! All data will be lost!
1.Power off your phone
2.Press together volume up + volume down + power button until recovery menu appears
3.Select "recovery" with volume buttons and press camera button to confirm
4.Press home button when Android logo appears
5.Select "wipe data" with volume buttons and press camera button to confirm
6.Select "yes" and press camera button to confirm
7.Wait until format ends
8.Select "reboot" and press camera button to confirm
9.Wait until phone restarts
That's it!
- See more at: http://factory-reset.blogspot.com/2013/09/motorola-defy-mini-xt321-hard-reset.html#sthash.eUfAgbLd.dpuf
Jan 31, 2014 | Motorola Mobility Defy Mini XT320 Black...
Windows internet explorer not working
was explorer working perfectly on your computer previously? If yes, you can try system restore.
System restore can help to back date your computer to the time when explorer was working.
Start > All programs > Accessories > System tools > System restore.
Read and follow instructions. System will restart during the restore process.....
After that try again and observe if explorer will function/work properly/normally.
Please let me know if this doesn't solve your problem so that I can help you further.
Regards.
Jan 05, 2012 | ASUS Computers & Internet
I attach Nikon CoolPix S550 (off) directly to USB port of iMac (OS 10.5.8), then turn camera on. Nikon Transfer (Preferences set to launch when camera is attached) does not launch. No sign appears on...
Some Macintosh computer systems support using a digital camera using SD/MMC card in two modes: 'Digital Camera' mode and 'Disk Drive' mode. At times, when try to use the camera using SD/MMC card in 'Digital Camera', it is not recognized by iPhoto or Image Capture. To solve such behavior, you might need to reformat the digital SD/MMC card and use backup to restore the lost files. But sometimes, you observe certain issues while restoring from backup or the backup is not available. To cope up with such situations, you should use Photo Recovery application to recover the lost files efficiently.
For an instance, consider that you perform following sequence of steps:
  • You connect your digital camera that uses SD/MMC card to a Macintosh computer in 'Disk Drive' mode
  • You switch to 'Digital Camera' mode and observe that the camera is no longer recognized by iPhoto or Image Capture
Similar behavior is also observed if you use FireWire or USB card reader to connect the SD/MMC card to your Macintosh computer and try to switch to 'Digital Camera' mode.
Solution
To prevent such errors from occurring, you should continue using the camera in 'Disk Drive' mode. You can then successfully access it through iPhoto or Image Capture. However, to solve the existing problem of the SD/MMC card, follow these steps:
  • Connect the camera in 'Disk Drive' mode or use FireWaire or USB card reader to access the card.
  • Backup all the files to your system
  • Use your digital camera to reformat the card.
Note: A digital camera using SD/MMC card uses different protocols in different modes so that to communicate with the Macintosh system. But it can only be accessed through Desktop, when connected in 'Disk Drive' mode.
After reformatting the SD/MMC card, sometimes you observe that backup is not valid and couldn't provide the required results. In such situations, you are suggested to use Digital Photo Recovery products to recover them. Photo Recovery utilities are competent tools to scan a logically crashed media using powerful scanning algorithms. Also, they provide interactive user interface that allows easy implementation
Nov 25, 2009 | Cameras
Lost images
plug your SD memory card directly into the computer your photos should still be on them unless your daughter chose the option to delete the originals.  There is no hard drive in the camera.
Apr 01, 2009 | Canon PowerShot SX10 IS Digital Camera
Can't get the quad screen to let all four I need a manual
I believe the newer version of your unit is the SSC14WEB. The instructions should be similar.
You can download the manual at:
http://dl.owneriq.net/3/369f279c-f502-4903-8918-0912f9063e94.pdf
Dec 18, 2008 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Sub won't power up
DVD reset procedure for TH-A10
1. Make sure there is no Disc in the tray.
2. Disconnect the power cord.
3. While Pressing "Stop" and "Open/Close" buttons together reconnect the power cord
4. Front display will show "TEST0".
5. Then the display will change to : "TEST1 JC2".
6. Press "Enter" button on the remote, display will show "EEPROM"
7. Press "Power" to shut unit off.
8. Reset is finished
Nov 16, 2008 | JVC TH-A10 System
Home Security Logo
158 people viewed this question
Top Samsung Home Security Experts
Mike
Heilcode
Level 1 Expert
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
