Question about Pioneer VSX-D510 Receiver
I connected my Jamo E65UB Subwoofer to my Pioneer VSX-417 - S/-k Receiver, but it dosent come any sound out of it, and dont tell me : "Have you turned "do u have a subwoofer?" on yes" ? yes i have i tryed from -10 to 10 Db ive tryed every setting on the reciever... whats wrong ? i tryed both SW out-puts also
SOURCE: Pioneer VSX-D606S subwoofer set up
If you push the middle of the remote the select I belive it it it will give you options on the receiver. There is one which says subwoofer on / off. Hope that helps.
Posted on Jun 02, 2007
SOURCE: Pioneer VSX-505S Subwoofer Installation
That type of subwoofer is not used with this receiver. This receiver actually outputs no power for a subwoofer, therefore only needs a plain ol' rca signal wire. This is due to the fact that you need a powered sub... one that you plug in to the wall and it has its own built in amp. you simply run an rca from yyour 505s to that sub.
Posted on Jun 24, 2008
VOTIT
  • 2071 Answers
SOURCE: broken connector in subwoofer connection on receiver
The only thing you do is to open your receivers,then locate the output connector if you see the female RCA jack ,then push it out the broken piece ,that's it
Posted on Jul 27, 2008
  • 263 Answers
SOURCE: How to connect to an subwoofer
You need a subwoofer cable then you attatch the cable from the back of the amp into the sub and power on the subwoofer and amp and hey presto your away.
Posted on Aug 04, 2009
SOURCE: pioneer vsx-305 need wiring diagram for this
I have problem with connecting subwoofer to receiver.
Posted on Jan 28, 2010
Pioneer vsx 519v
Are you sure the correct input is selected on BOTH the TV AND the A/V receiver?
Does the subwoofer work on other inputs? If not, is the subwoofer connected correctly? If so, is the input connected correctly?
Jan 31, 2014 | Audio Players & Recorders
Pioneer Elite VSX-92TXH subwoofer pre out does not work
These receivers have a history of having broken connections on the subwoofer jack. Would have to go in for repairs.
Apr 09, 2013 | Pioneer Vsx-92txh Elite Home Theater A/v...
Pioneer VSX-822-k Subwoofer problem
Go to manual setup, selct the subwoofer and set it to Pus.
Jul 29, 2012 | Pioneer Vsx-822-k 5.1-channel 3d-ready...
How to connect my subwoofer to my vsx-405 receiver
Hello
Try to download the user manual to Pioneer VSX & THX user manual. click here to down load the same. You will get details of it connections from the manual.
http://www.dataentryjobs.us/67948.html
Feb 24, 2012 | Pioneer VSX-405 Receiver
I have jamo sub200. I connect to pioneer vsx-rs320k audo video receiver. when I turn the volume of subwoofer to a higher value with the receiver, the bass sound becomes distorted and not satifieng to...
hi,
Do one thing set the control behind the sub. set the level and cutoff control at it half position. Set phase control at "0" position. Then test the sound. if you ate using tower speaker as front speaker then you have to set the position of phase control 180 ,
ok
Apr 11, 2011 | Jamo SUB 200 Subwoofer
My jamo sub 200 & pioneer vsx517 receiver is not working properly
What do you mean that it sometimes doesn't work? It doesn't power on automatically?
Check settings of your receiver - if it has subwoofer output enables and if low frequencies from all channels are directed also to the SUB. By default only the LFE channel (.1) of 5.1 signal input is fed to the subwoofer. So Sub will work in this case only when you listen to 5.1 signal (DVD movie for example), but for radio or stereo music, only front speakers are used. By configuring this bass redirect, you can use subwoofer for all signal types.
Feb 08, 2010 | Jamo SUB 200 Subwoofer
Aug 04, 2009 | Pioneer VSX-D510 Receiver
No Sound from Subwoofer
The original Pioneer subwoofer has its own amplifier built in to the speaker, so the only cable required on the original speaker is a single RCA cable. To connect a different brand subwoofer to the Pioneer you will have to make sure that you have a subwoofer with the same specs. It will need its own built in amp to work, as you can only connect it with one RCA
Jul 31, 2009 | Pioneer VSX-818V-K Receiver
Pioneer VSX-D510 Receiver Logo
270 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
