Question about Intuit Quicken 2005 Deluxe (283650rb)
I need to move Quicken 2005 to a new pc running xppro. can this be done?
    Brigadier General:
  • 4,044 Answers
There are a few programs that can do this transfer for you. The easiest method is to re-install the software using your original media, do the data transfer then remove the software from the old machine. This will satisfy the Copy right and the software vendor. The registration process may require you to actually call them but it is usually not a problem.
Posted on Sep 29, 2010
How do I move a copy of Quicken from my desktop to my laptop.
Hi.
When you downloaded quicken, it should by default save to a sub folder named "Download" Depending on your PC's operating system, the download folder is normally found in the "My Documents folder" Click on the Start buttom (Windows) in the bottom left corner of the taskbar. Inside the Download folder should be a file with the name Quicken.exe. Copy the Quicken.exe file to a memory stick or flash drive, then stick in into the usb port of the other PC. Click on the Quicken.exe file and it will run the installation of Quicken on the second PC. Install Quicken the same way on the 3rd PC.
Good luck!!
Apr 07, 2014 | Computers & Internet
Tip
Quicken will not print more than seven checks.
You may run into this problem if you use the 2005 or 2006 version of Quicken’s personal finance software (such as Quicken Basic, Deluxe, Premier, Premier Home & Business). If you try to print eight or more checks at once, they won’t print.
According to Quicken Help & Support, Intuit fixed this problem for both the 2005 and 2006 versions of Quicken. You’ll need to download and install the latest patch, which includes the fix for this problem. Quicken offers manual and One Step Update methods to update your version of Quicken with the latest patch. You’ll need an Internet connection to download the patch. If you have a dialup connection, connect to the Internet before you start any of the update methods below. Once you complete the patch installation, Quicken will be able to print eight or more checks.
To read Quicken’s solution for this problem, visit www.quicken.com, click Help & Support, and then select 2006 For Windows (make sure Quicken For Windows and Quicken 2006 appear in the Product fields). Next, type 2997 into the Search field and click Search.
Update Quicken 2005 manually
Visit Quicken Help & Support, select 2005 for Windows, and enter 3810 in the search field. Open the How Do I Manually Update Quicken 2005 For Windows To The Latest Release? link. This page has all of the patches for Quicken 2005. However, you only need to download the patch that has the highest R number. The latest patch carries all of the data from the earlier patches. In this case, you will want to download patch QW05R5PATCH.exe.
Click the file’s link. If you have Windows XP, a File Download – Security Warning may appear. Click the Save button. In the Save As window, choose a location to which you’d like to save the file and then click Save. When the download completes, simply double-click the file to start the patch installation.
(NOTE: This method involves downloading and installing a single patch file. If you don’t have an Internet connection but have a friend who does, you can download the file to his PC and then burn it to a CD [assuming your friend’s PC has a CD-RW]. Use the CD to transfer the file to your computer.)
Update Quicken 2006 manually
Visit Quicken Help & Support, select 2006 for Windows, and then enter 3796 in the search field. Open the How Do I Manually Update Quicken 2006 For Windows To The Latest Release? This page has all of the patches for Quicken 2006. However, you only need to download the patch that has the highest R number. The latest patch is QW06R3PATCH.exe and carries all of the data from the earlier patches.
Update Quicken 2005 Or 2006 With One Step Update
You can also update your version of Quicken using One Step Update. You can start the update by clicking Online Menu and then selecting One Step Update. Next, uncheck any checkboxes that appear and then click Update Now. The tool will download and install the latest update for you.
by: -micromaster
on Mar 19, 2008 | Intuit Quicken Basic 2004 (028287007543)...
Running windows vista service pack 2 but quicken 2014 won't open
One solution would be to run it pretending your Vista is XP. I have seen it done but as I have no Vista machine, I cannot tell you the steps. Search for running Vista in XP mode - once you have managed that, try installing the software.
The second solution would be to open a virtual machine on Vista and running that as an XP machine. Again, I have seen it done.
Try the links I have added below.
The problem I had was with Quickbooks, not Quicken, but the principle is the same and worth a try. Good luck.
Use XP Compatibility Mode in Windows Vista Win7 Vista Windows XP Compatibility Mode in Windows 7 and Vista
Feb 13, 2014 | Intuit QUICKEN 2014 DELUXE
What is my unluck code?
There are restrictions for the Code,
Hope the llink below can help you. Good Luck :0)
http://web.intuit.com/support/quicken/service/unlock/6273.html
you may obtain another unlocking code or a Quicken CD using one of three options:
  • Online Unlock Tool option (Available for 2003, 2002, and 2001): To unlock your version of Quicken online, please click here and follow the directions on the screen to generate a new unlock code. Please be at your computer with Quicken open and the serial number displayed. (Do not write down the serial number and close the program before using the Unlock Tool, as a different serial number will generate each time the program is opened). Our Unlock Tool will check for your previous unlock and issue a new unlock code, free of charge.
  • Online Unlocking Option (Available for 2005 and 2004): To unlock again online, you will need your order number for reference. You will also need to have the Quicken 2004 or 2005 CD in the CD-ROM drive while walking through the unlock process. (Note: You do not need the CD for the New User Edition). Launch the version of Quicken currently installed on your computer. Once launched, go to the help menu and then to the Unlock again option. If you have your Unlock code from either your conformation e-mail or from the Order Status window you can enter it in the blank field. If you do not have the Unlock code, select Go online to automatically unlock Quicken. Quicken will then connect to the Shop Intuit Web site. Enter your Shop Intuit member ID and password. In the Order History window, enter your unlock order and click View. In the Order Details window, click Unlock Code. Close the Shop Intuit Web site. Restart Quicken to begin using your new features.
  • Live Chat option (Available for 2005, 2004, and 2003): To request a new unlocking code, contact Quicken Chat (5:00 A.M. - 5:00 P.M., Pacific time, Monday - Friday and 7:00 A.M. - 7:00 P.M., Pacific time, Saturday - Sunday) Please be at your computer with Quicken open and the serial number displayed. (Do not write down the serial number and close the program before chatting, as a different serial number will generate each time the program is opened). Our Quicken Chat Representative will research your account to locate your previous purchase and issue a new unlocking code, free of charge.
  • Telephone option (Available for 2005, 2004, and 2003): To request a new unlocking code, call Quicken Sales and Service at (800) 811-8766 (5:00 A.M. - 5:00 P.M., Pacific time, Monday - Friday) and press "2" for customer service. Please be at your computer with Quicken open and the serial number displayed. (Do not write down the serial number and close the program before calling, as a different serial number will generate each time the program is opened). Our Sales and Service Representative will research your account to locate your previous purchase and issue a new unlocking code, free of charge.
To place an order for the newest edition of Quicken, please visit www.quicken.com. If you have additional questions regarding Quicken 98 or 99, please contact Quicken Sales and Service at (800) 811-8766, 5:00 A.M. to 5:00 P.M. Pacific time, Monday through Friday.
Good Luck.
Nov 07, 2009 | Intuit Quicken 2003 Basic (270902) for PC
I cannot get quicken 2002 basic to install on my new computer with windows vista.
That's because Quicken 2002 will NOT run on Vista. Quicken 2005 & 2006 will run on Vista, but will have issues and script errors. Intuit will only ensure Quicken 2007 and newer will work on Vista.
Aug 08, 2009 | Intuit Quicken 2002 Deluxe (78588)
Quicken Deluxe 2009 stopped working
your quicken deluxe 2009 is very OK... i think your system vista 64bit is the problem.. is there any other way that your 64bit vista is updating? if you try to use your quicken deluxe and it might works there.. so this time you are going to system restore your vista 64bit and back the recent checkpoint that quicken is run normally...
Jun 19, 2009 | Intuit Quicken Premier 2009 for PC
I did a pc recovery,when I did this my quicken deluxe 2008 program was removed from my computer. Later I reloaded Quicken deluxe 2008, but instead my quicken 2005 came up. How do I get quicken deluxe 2008...
Remove all previous versions of Quicken. Reinstall your 2008.
If you still have trouble ... go to the quicken support page and keep clicking on help until you get an opportunity to Chat with our friends across the sea. @008 is still within the 3 <> yewar window of getting free chat support
Sep 24, 2008 | Intuit Quicken Deluxe 99 for Windows...
1. Downloaded and registered Quicken Deluxe 2008 but did not receive ID and password info that I have previously done with Quicken. 2. Have done a download from bank on 2 accounts, then downloaded data...
That means that there end has had a problem. You will just need to wait until they get there servers working again.
Hope This Helps,
All The Best,
RCF
May 28, 2008 | Computers & Internet
Quicken 2004 Installing on Windows Vista
Jan 18, 2008 | Intuit Quicken Basic 2004 (028287007543)...
Intuit Quicken 2005 Deluxe (283650rb) Logo
90 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Dan Shibata
Dan Shibata
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
