My Konica Minolta bizhub C20 saying "Waste Toner Full. Replace bottle" Is it possible to empty or clean this toner bottle(box) and reuse it?. If yes, how?. Thanks in Advance. -Kanak
Kevin Hayes
  • 167 Answers
SOURCE: C250 Waste toner
Actually you are supposed to replace the whole container.
You can order this as part of your service contract just like toner, the cost would be included.
If you are shaking it out, be aware it is VERY flamable in such a fine powdered state.
Posted on Jun 06, 2008
SOURCE: can you resue a waste toner bottle
Change the waste toner bottle. :-)
Posted on May 14, 2009
SOURCE: How to reset waster toner bottle full Xerox 3535
Here's what I did.
Emptied the waste toner cartridge. Left it out of the machine. Held the microswitch (located to the right of the optical sensors) in the "cartridge in" position with a paperclip. Printed one document. Inserted the waste toner cartridge. Error now gone!
GCC.
Posted on Dec 18, 2010
  • 76 Answers
SOURCE: The waste toner box is
have you chek it out clearly? if yes then dont worry let the error come. it happens because of tonner chip some times. but the advice is to take it to the nearest service center.
Posted on Apr 25, 2011
SOURCE: I have a Konica Minolta
Visit the link below :
http://www.inkcloners.com/blog/troubleshooting/changing-toner-for-the-konica-minolta-2430dl-cartridge/
and follow the provided steps in How to change the toner .
Or you can download the instruction manual by clicking HERE ,see page #71 Replacing Consumables .
Posted on Jul 26, 2011
I've replaced the toner cartridge and waste toner bottle, but the display still says 'toner low' and 'waste toner near full'. It refuses to print, even with the old cartridges.
Then you mite want to clean the sensor that monitor the waster toner box pull out the waste toner box and look for the area that show clear plastic then look for those area of the machine and blow the old toner from those areas waste toner mite have gotten on the sensor saw they can not see the clear plastic and think that the waste toner cart is still full.
Sep 09, 2014 | Konica Minolta Magicolor 5670EN Color...
My bizhub c25 waste toner was full so replaced and will not now reset.
The C25 stores toner in a waste toner container. On the front of that container there is rectangular clear window that fits into a sensor when installed into machine. The sensor passes a beam of light through that window. When the bottle is full there is toner inside that clear plastic window which stops the light from making it through the window and the machine will tell you the waste toner is full. Just dumping the container out will not clear that window and by putting it back in the machine you will get the same toner full message. If you are going to try to reuse that container you will have remove the black plastic cover that is glued to the container above the clear plastic. Then use something like a Qtip to clean all the toner off of that clear window(much easier and faster to just replace in with a new container). if you still get the waste toner full message after you install it then remove it and wipe off the sensor that the clear window sits in. This will clear the message and you can continue your copy job.
Apr 02, 2014 | Konica Minolta Office Equipment & Supplies
Waste toner bottle full so replaced but will not reset and says still full
then the clear section of the waste toner bottle is not clear some toner is left blocking the sensor that monitors the waste toner level
Apr 02, 2014 | Konica Minolta New Bizhub C25 Color Laser...
Waste toner full
The waste toner collection box is located before the imaging unit,open the front door observ a black box,pull out and clean very very good,because in rear part of box is located one transparent window,if is not clean after assambled the box a copier say waste toner box full.
Apr 29, 2013 | Konica Minolta Bizhub C35 Multi-Function...
My bizhub 7228 has this on the screen F-26-1 and says i need to contact service
F-26-1 is the low toner ratio code.Check the toner bottle, if its empty then replace it with the new one.If its full then pull out the bottle and again inert it.Now restart the machine and it will start working.
Apr 26, 2011 | Konica Minolta Bizhub c203 Copier
I have a c652 biz hub keeps coming up waste toner box konika minolt printer
To replace the waste toner box, open the front door above the paper drawers. The waste toner box is on the left hand side (usually). Your supplier should have supplied an extra waste toner box. Slide out the 'full' toner box. Replace with an empty one. This should register that you have installed an empty waste toner box. If not, turn off the copier and after a minute or two, turn on the coper again. [If you want to be environmental friendly, the toner box has a small slide cover approximately 1-2cm long (usually on the upper face at the rear as you remove it). Place this end in a plastic bag, slide open this 'cover' and rotate the toner box 180° so this is facing down. Care needs to be taken to prevent the 'waste toner' from flying everywhere. Gently agitate the box until all the waste toner (a grey color) has spilled out. (Approximately 600-800gms) Carefully seal the bag and dispose. An industrial vacuum cleaner can be used to remove the residual toner, clean down the waste toner box with a soft rag and it is ready to re-use.]
Sep 02, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
WHERE IS THE WASTE BUCKET ON PRINTER KONICA 4690MF
Found this on the support site
When the waste toner bottle becomes full, the message "WASTE TONER
FULL/REPLACE BOTTLE"
Konica/Minolta Support
Go to "Ch. 7 replacing consumables" > "Replacing Consumables" > "Replacing the Waste Toner Bottle" this is found on page 165 of the user guide. This walks you through replacing the waste toner bottle.
Hope this helps. GOOD LUCK!
Oct 16, 2009 | Konica Minolta Magicolor 4690MF...
C250 Waste toner
Jun 05, 2008 | Konica Minolta bizhub C250 All-In-One...
Waste Tone Box
Your machine catch's excess toner and puts it in a container and needs you to replace/empty it soon or it will have to stop work, sorta like needs just a dash of attention for all its effort.
The bottle at a guess for this model will be apparent when opening front door, instruction are probally on the inside of door but it is just a container full of black messy stuff that needs to be emptyied and replaced....hang on I'll google it....looks like you need to buy a new box and that will have instructions even.
Some links for your product toner box
http://www.precisionroller.com/catalog_display.php?mfname=konica_minolta_bizhub_c450p_waste_toner_container_details&m=297&d=7597&c=40&i=31526
http://www.tonermax.com/KONICA-MINOLTA-BIZHUB-C450-WASTE-TONER-BOTTLE/i/24194
Oct 31, 2007 | Konica Minolta bizhub C450P Laser Printer
Computers & Internet Logo
1,017 people viewed this question
David Payne
David Payne
