Question about Panasonic Panafax UF-595 Plain Paper Laser Fax
ADF won't pickup paper off Panafax UF790 - Panasonic Panafax UF-595 Plain Paper Laser Fax
    Problem Solver:
  • 17 Answers
Open the ADF door and clean rollers and ADF pad with windex sprayed onto a paper towel , if problem remains call service tech to replace parts required.
Posted on Sep 30, 2010
What to do about the ADF pulling too many sheets through?
Make sure the pick up roller is free of paper dust. You can get cleaner paper at an office supply store. It is sticky on both sides and will remove paper dust from the surface of the pick up roller.
Aug 21, 2014 | Panasonic Panafax Uf-8000 uf8000
I have a message on screen sayng " ADF Jam" there is no paper jamming the system. I cannot make this message go away, and so i cnnot use any other function of the printer. How might I clear...
Hi travlynn2,
  1. The ADF
    unit is the grey paper tray located on the top of the scanner unit.
    Check the following points if it does not feed paper, or you receive an "ADF jam" error message:
  2. Check the position of the ADF document guide:
    1. Lift up the ADF unit. Locate the document guide on the underside, as shown here:
    2. The document guide should be tucked in behind the grey plastic casing, but a paper jam can push it out of position. Figure 8 below shows the correct (1) and incorrect (2) positions:
    3. If your document guide looks like example (2)
      on the right, lift it out on the right-hand side. Tuck it in behind the
      grey section, so that it matches the example on the left (1).
    1. Close the scanner unit.
    2. If the printer is displaying "ADF Jam, press start to continue", press the B/W Start button to clear the error:
    3. Test the printer by scanning or faxing via the ADF unit.
  3. Check the ADF edge guides:
    1. The adjustable paper tray edge guides must be set to the correct paper size for the paper you are loading. Otherwise, the paper may skew, misfeed and/or jam.
    2. Slide the edge guides to enclose the loaded
      paper (in the direction of the yellow arrows below), without causing it
      to bunch or crease. The paper should be aligned with the relevant paper size marker:
      Figure 9. The ADF edge guides.
  4. Check the ADF unit feed rollers:
    1. Open the cover of the ADF by pulling up the grey lip, as shown below:
    2. Check thoroughly for fragments of paper and foreign objects. Take care not to tear any jammed paper when you remove it.
    3. Use the green gear (circled in yellow below) to turn the paper feed rollers and feed through jammed paper:
    4. Paper dust or foreign material on the rollers may cause paper to misfeed. Clean these parts with a damp, well-wrung cloth:
      1. The upper paper pickup rollers (circled in red, above top left). You can turn these by hand.
      2. The lower paper pickup rollers. These will rotate as you turn the green gear (circled in yellow above). See the inset for a close-up of the lower rollers.
    5. When complete, close all the covers.
    6. If the printer is displaying "ADF Jam, press start to continue", press the B/W Start button to clear the error:
    7. Test the printer by scanning or faxing via the ADF unit.
  5. Check that the ADF unit sensors are not obstructed.
    1. Open the cover of the ADF unit.
    2. Look at Figure 12 below. Check the position of the black plastic parts (the actuators) circled in red.
    3. If the black plastic actuators do not stick out from the ADF cover, they may have been pushed out of position by a paper misfeed and be obscuring the ADF sensors. Tap the back of the ADF unit firmly to release the actuators.
    4. When complete, close all the covers. Check and test the printer as explained in Step 6.d.vi.
Hope this helps.
Thank you for using FixYa.
Sep 21, 2011 | Epson ACULASER CX11NF All-In-One Printer
ADF does not "grab" paper. Replaced pickup
Hey, If you have a ADF jam you should replace the pickup assembly (part# D1815-Z3) as well as the separation pad (part# D1815-Z4). Here is a video I made that shows you how. Iteminc.com has these parts and ships same day. Hope it helps!
Oct 31, 2010 | Dell 1815dn All-In-One Laser Printer
Paper misfeed in toshiba 452 in scanner tray
hi i thinku have to clean ADF pickup rollers with washig sope adn just dry with tissues it will solve yors problem if not just replace ADF pickup rollers
May 15, 2010 | Toshiba E-Studio 3511 Color Copier
Is there an Error Correction Mode on the Panasonic Panafax UF790 fax machine? We're having problems with our fax after converting to an IP Telephony system.
Yes, it is in the technician's service menu, however, that will not cure your problems with a DIGITAL phone system.
ALL fax machines are ANALOG.
Sep 10, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
I bought a panafax-uf790 about 2 years ago. Now I am having the worst paper jam problem. It would always stop at the same place and record paper jam. I've constantly remove the paper and it keeps giving me...
Just a suggestion, Try the following, obtain a compressed air canister, or a compressor filled with air, open the unit from where the paper feeds and ejects after printing, blow the compressed air through the feeder and the ejection side, turn the rollers if possible whilst doing this.
May 12, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
ADF Does not show paper is loaded. If slide the document under the pickup roller in the ADF it will show document loaded but when I hit copy a "pickup roller error" is displayed. What would cuase...
Sometimes paper dust, and bits of paper clog the paper sensor, you can try using a can of compressed air to blow the sensor clear. use a flash light and locate the pickup rollers, and sensor. Clean both, if you can reach them. If they are clear, then the sensor might have stopped working. Check your warranty.
www.lhsjrinc.services.officelive.com
May 07, 2009 | HP LaserJet 3055 All-In-One Printer
Panasonic Panafax UF-595 Plain Paper Laser Fax Logo
101 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
