Question about HP Photosmart M527 Digital Camera
Card locked error
While taking pictures the camera suddenly said card locked! So I purchased a new card only to get the same error message. I tried my card in my neighbors camera and it was fine. I am a bit antsy about this matter being that I only had the camera for 6 months
Posted on Nov 01, 2008
When I try to take a picture, it gives me the error message "Card Locked !" I have checked the tab and the memory card is not locked. I have put memory card in another camera and it works. Also, I hav
Check the card slot for debris and clear it out gently with canned air, small thin piece of plastic, etc on the same side as the lock tab. Try not to use anything metal unless you have a really delicate touch.
Oct 30, 2014 | Cameras
My camera suddenly had the message "card locked!".
If this camera uses SD cards then what may be happening is that the little lever that drops into the slot on the side of the card to indicate locked or unlocked is jammed in the locked position. If you shine a flashlight in you might be able to see where the pin is.
May 05, 2011 | Canon PowerShot SD880 IS Digital Camera
Card Locked! Message on Samsung l313
Go into the setup menu and do a camera "reset".
Sep 07, 2009 | Samsung Digimax S500 Digital Camera
Card Locked ! Error
Remove SD card, then whilst card is removed, delete all pictures that may still be stored in cameras 'internal' memory (usually just a few) then replace SD card. Should be unlocked now?.
Nov 10, 2008 | Samsung Digimax L830 Digital Camera
Optio E10
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Oct 11, 2008 | Pentax Optio S7 Digital Camera
Missing pictures
Hey flowernthe,
The error message “card cannot be read" means there was and error when the camera tried to access the memory card. To fix this you should make sure you are using the right kind of memory card, which for this kind of camera is a SD card, and it does not support SDHc cards. Since this camera uses SD cards I would make sure the slider on the side of the card is not set to the locked position. If this doesn't help I would make sure the memory card connecters are clean, and if they're not you can use a rubber eraser to clean them up. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 11, 2008 | Nikon Coolpix 4600 Digital Camera
Memory Card
Try taking the SD card out then plug the camera into the p.c then format the internal memory.
Nov 13, 2007 | HP Photosmart M415 Digital Camera
512 MB card problem
If the new 512mb xD card has a prefix of "H" or "M" before the 512, it is not compatable with your A330 unless a firmware upgrade is performed on the camera. You can download all the details here http://www.fujifilm.ca/x3720.xml
Sep 20, 2007 | Fuji FinePix A330 Digital Camera
"Memory card is locked"
This error message means that the memory card is write-protected. To take a picture, turn off the camera. Then insert a new card or change the storage location to internal memory
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
This error message means that the memory card is write-protected. To take a picture, turn off the camera. Then insert a new card or change the storage location to internal memory.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
HP Photosmart M527 Digital Camera Logo
96 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
