I recently bought a bank foreclosure property that has a Totaline Easystat thermostat and the screen is completely blank and I have no manual. The FAU is a Payne and it is nearly brand new (There is no A/C). All power appears to be on. How can I get my furnace & thermostat working? I'll need heat this winter! (I'm not at the property right now, so I can't walk thru the steps physically, but can reply online)
  • 1,476 Answers
RGTraveler,
Have you checked the battery in the thermostat. In order to work, all electronic thermostats have batteries which need changed periodically. Without the battery the display would not work.
This website should have the service manual for your unit. It will tell you how to check/change the battery.
http://www.wwgtotaline.ca/en/resources/manuals/
Thanks for using FixYa and for the generous rating.
hardrocko
Posted on Sep 29, 2010
Totaline Thermostate P274-1100 works fine when following programming but when I adjust the temperature manually it will start the furnace and after a few minutes the screen displays E2 error, blanks out,...
E2 is the error code for low line voltage. I would think that this is a erroneous code witch would indicate that the thermostat is defective. do you know if this is true line voltage 120v or transformer voltage 24v?
Mar 05, 2014 | Carrier Totaline P291-1003 Capacitor 10mfd...
I have no idea how to use my totaline digital thermostat,
Totaline is a brand name of the Carrier Corporation. Go on www.totaline.com and research the model of your thermostat. User manuals are available.
Nov 11, 2013 | Heating & Cooling
Totaline power
I don't know anything about your particular T-stat, but power comes from the transformer and there should be a 3 amp fuse next to the transformer. They're both located in the air handler (where the fan and evaporator coil Is).
Oct 06, 2013 | Heating & Cooling
What does "Foreclosure" means?
Foreclosure is a situation in which a homeowner is unable to make principal and/or interest payments on his or her mortgage, so the lender, be it a bank or building society, can seize and sell the property as stipulated in the terms of the mortgage contract.
http://www.investopedia.com/terms/f/foreclosure.asp
Aug 29, 2013 | Finance
I walked across my carpet to reset the temperature on my Totaline P/N P474-1050 thermostat. When I touched the thermosat, there was an arc of electricity. The screen went blank and does not respond to any...
There are two options for this. You can try turing all the power off the the unit completely. The inside and outside unit and give it 30 seconds and turn it back on. This may reset it. Chances are you just burned it up. I hate this for you...
Hope it helps.
Jan 28, 2011 | Heating & Cooling
Model # P2740300 totaline thermostat has a blank screen. It's not getting power?
Normally all thermostat functioning with 24 volt. Check power in your thermostat. If not 24 volts, the transformer input where it should be 110/220 volts be there. If yes, your transformer winding open,. Replace transformer. If not,check power.
Dec 27, 2010 | Heating & Cooling
I have a totaline with issues
Replace the batteries first. If that does not fix it, you either have lost 24V from the furnace/airhandler, or the thermostat is bad.
You may get lucky and find that the only problem is a blown 3 or 5 amp fuse on the board. Although that usually indicates a short somewhere in the system.
Jan 30, 2010 | Heating & Cooling
Heating & Cooling Logo
136 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
