Question about Ryobi Backpack Blower 25.4cc
I have the Ryobi Back Pack Leaf Blower(8576) It's been real good to me for 3 years. It started bogging down at speed so I chaenged the fuel filter, rebuilt the carb and made sure the gas lines were clear. It still dies after I give it gas. There are no adjustments on the WYC c\type carb so adming is out of the question. Can someone help me out here? It's leaf season dagnabit.
    Scholar:
  • 150 Answers
There is a screen at muffler exit (spark arrester) remove it and replace or clean it. I use a small torch to burn it out. Its worth a shot.
Posted on Sep 29, 2010
  • heyheymama Sep 29, 2010
    Did that already, thanks. New plug too.
Ryobi 8576 fuel line replacement
usually get them at any lawn mower or chain saw sales shop ,not BIG BOX stores .
Sep 14, 2015 | Ryobi Garden
Ryobi gas blower tuff starting and bogs down, and dies
take the muffle off and run it if ok open the muffler a bur off the screen inside with a tourch
Mar 25, 2012 | Garden
Ryobi backpack blower will run all day with choke up but as soon as I pull the trigger it starts bogging down
Thats a lean condition. Check fuel lines and fuel filter. If the fuel ilnes are discolored or stiff or really super mushy, If the fuel filter has become detatched from the fuel line then the fuel lines need to be replaced.
If the carb can be adjusted you can try to adjust but its likely that the carb should be rebuilt with new diaghrams and gaskets.
Adjust by turning the low speed screw out ( counterclockwise) 1/2 a turn. The low speed screw is always the one closest to the motor and usually marked on the carb body with an 'L'. When you richen a motor up the idle will drop so you will probably have to turn the idle screw in 1/2 a turn. 1 and 1/2 turns out from light bottom is standard starting point ( 2 turns for poulan products). If you get more than 3 and 1/2 turns out on the low speed screw or if turning the screw has little or no effect then the carb should be rebuilt.
Dec 12, 2009 | Ryobi Backpack Blower 25.4cc
Ryobi backpack leaf blower about three years hard to start
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 24, 2009 | Ryobi Garden
Ryobi blower will not start unless primed by
If it is under 2 years old, I would take it to a warranty repair center. The carburetor have been giving some problems so they have needed to be replaced because they are sub standard quality.
Sep 28, 2009 | Ryobi Backpack Blower 25.4cc
Echo gas leaf blower bog down
Likely dirt in high speed needle valve(H); could be leaky fuel line(air leaking in), plugged fuel filter, pinched fuel line, etc - anything restricting flow of fuel. Likely, you aggravated an existing problem by cleaning the air filter which would have been providing some choke effect if it were partially plugged.
Sep 21, 2009 | Echo Garden
Ryobi Backpack Blower 25.4cc Logo
534 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
