Question about NetGear Computers & Internet
How do i lock my netgear wireless router - NetGear Computers & Internet
    Sergeant:
  • 231 Answers
In order to secure your router make sure your router is connected using an Ethernet cord, you must open your Browser,(Internet Explorer-Firefox or Safari) In the address bar type in 192.168.0.1 or www.192.168.1.1 (depending on the product) This will bring you to your routers configuration.
1.Unless you've configured otherwise, the default username is admin and the password password
2.Under "Security Options", select your desired encryption method (preferably WPA2-PSK)
3.Choose a Network Key it can be anything, as long as it's 8-63 characters in length (Then Hit Apply)
4.Now on the computers you wish to connect to over wireless, repeat the process. I hope this Helped
Posted on Sep 29, 2010
5 Suggested Answers
anandg27
  • 1272 Answers
SOURCE: i cant put a password lock on my netgear wireless
Hi, follow the below steps to enable security on the wireless router:
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari) on a computer connected to the router.
2. Access the router usually by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Select security options as 'WEP (Wired Equivalent Privacy)'. Set the 'Authentication Type' as automatic. Set the 'Encryption Strength' as 64-bit.
6. In Key 1 type a 10 digit number. Apply the settings.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Oct 27, 2009
  • 556 Answers
SOURCE: Connecting a netgear wireless router to a 2wire
Are the router addresses assigned on the same subnet?
many routers have a base address of 192.168.0.1 and a subnet mask of 255.255.255.0 meaning all addresses 192.168.0.? are part of their network.
One problem can be that both routers can be using the same subnet -- not an issue if they are connected to different connection points (such as two different houses) on the internet. However when connected to each other in your house they are confused because they have the same two different networks with the same addresses. -- for slightly different reasons --
For those that want you to connect from one router to the wan of the other you need to assure the base addresses are in different subnets -- assuming the one connected to the internet is addressed as 192.169.0.1 with a subnet mask of 255.255.255.0 his network as stated before is all addresses 192.168.0.?. Change the second router to a base address of say 192.168.2.1 with a subnet mask of 255.255.255.0 his network is everything staring 192.168.2.? they are now different and it should work. On the wan side of the router you can assign a unique 192.168.0.? address not in the DHCP range of the first router or accept a dynamic IP address from the first router. The dynamic address is probably the easier and less problematic of the solutions.
For those wanting you to connect to a lan port and ignore the wan port they should also have asked you to turn off DHCP in the second router (where you do not use the wan port) and allow the first to do all the dynamic network address assignments. In this case you could have two DHCP servers on the network competing to assign possibly the same network addresses -- if they have overlapping ranges duplicate addresses could be assigned resulting in device connection issues for those with duplicate addresses. Even in this case you may need to assure the gateway addresses are unique on the network ie of both routers are addressed as 192.168.0.1 the second where the WAN is not used could become 192.168.0.2 (where that address is not in the active DHCP server's assignment range) or 192.168.2.0 (note the DHCP server had better be off or else the empty wan port 192.168.2.0 could become the "gateway" address of attached PCs and since there is no connection there will be no access to the internet.
I hope this helps
It is quite likely either solution could work if all the proper changes were made.
Posted on Dec 15, 2007
cnavarro
  • 2460 Answers
SOURCE: Netgear Wireless Router won't work with my Linksys wired router.
As asked above, why would you want the wired router and the wireless router on the same network?
The direct answer to your question(s) is found on Netgear's website. http://kb.netgear.com/app/answers/detail/a_id/965/kw/wpn824/r_id/166
The key is to turn off the Netgear DHCP, and give it an address that is unreachable by the Linksys DHCP ie if the Linksys gives out IP addresses starting at 100 or 101, you set your IP address to 99, turn off the DHCP, and plug it into the network NOT using the WAN port, ever. We tend to start at 251 or 221 just for clarity's sake.
The point is you answered your own question. The Netgear wired and wireless works fine. One piece of equipment and better reporting statistics....what are you missing?
Carl
Posted on Apr 25, 2009
  • 62 Answers
SOURCE: netgear wireless-G router was working fine. now it is locked
1)The Default password for wireless-g is admin and the password itself is the word password both being lower case.
2)If the default password is not working or it is locked then the password might have change the password to something else.
3)To get the default access to the router web interface we have to hard reset the device but if we reset the device to the default setting's the internet connection will be terminated and the all the setting's has to be done from the beginning.
4)Following procedure will help you in hard resetting the device:-
a)You will find the very small/tiny circular pin hole on the rear panel of the device very close to the power.
b)Use the paper clip or a pin to reset the device and keep holding the reset button for at least 30-35s.
c)Then , While holding the paper clip take the power cable out from the device , wait for 10-15s and then plug the power cable back to the device while holding the paper clip.
d)Wait for another 10-15s and then release the paper clip.
e)Once we have all the lights back on to the device then take the power chord out and plug it back within 30s.
5)Once we follow the instructions the router will be reset to the default setting's and the internet connection will be terminated.
6)Open the IE page and in the address bar type the url:-http://www.routerlogin.com and then press enter key.
7)A small window will prompt up which will ask you to type the user name and password which will be
user name:-admin
password:-password
and then left click on log-in.
8)Once you will left click on log-in it will navigate you to the router's administrator page which will be netgear smart wizard page from where you can configure the router's setting's.
Posted on Nov 18, 2009
How do I turn netgear on>
If there is a lock symbol that means the wifi is password protected. if you are the owner and forgot your wifi password, you have to reset the router.
if you are in a cafe, please ask the staff if they can let you have access.
Oct 19, 2014 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
My netgear router on security lock, how do I unlock it?
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash.Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
May 09, 2012 | Gateway Belkin 54g Wireless DSL/Cable...
HOW CAN LOCK THE ROUTER
http://192.168.0.1
You can now change the admin password and configure the wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Apr 07, 2011 | NetGear WGR614 Wireless Router
I want to password protect my netgear router how can i?
I assume you are referring to the wireless security - if not post back exactly what you are trying to protect from
  • if you goto this site - http://kb.netgear.com/app/home enter the model and version and in the question - ask - " how to set wireless security" - you should see a page listed
Apr 12, 2010 | NetGear DG834G Router
Cant lock my wireless router forgot password
reset you router on factory set with reset button and need to reconfigure again.
Apr 11, 2010 | NetGear WGT624 Wireless Router
Netgear wireless router wgr614 not transmitting
Yes changing channel will make a diffeence most of the time for this kind of issue. The reason is there could be multiple routers or interference in that area locking to the same frequency.
Aug 01, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Netgear router
You need to find the router password (is not the one you use to access wireless), after you rememeber the password and username you need to open your browser and type the url to access the router, usually inlcuded in the instructions manual.
After doing that, log into the router menu and check your wireless password and settings.
If this is not working, please jard reset your pasword.
Hope to be usefull.,
Mar 25, 2008 | NetGear WGR614 Wireless Router
Computers & Internet Logo
960 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
