Question about Panasonic KX-TA308 Phone
Hello i got some problem with panasonic kx-tem824 when i trying to connect by RS 232 serial port I cant do it,the pc print a error pbx connection unscussceful 00363405h cant anybody help me please, thank you to can help me in this case
3 Suggested Answers
cnavarro
  • 2460 Answers
SOURCE: can i get a pssword for pbx panasonic kx-td 1232
Sure. It's a dealer option to crack the password. There's a brute force program that will do it, or there's an installer trick. I can't give you either one in a public forum. Please call a Panasonic TD dealer. You may find one at www.kxt411.com
Carl
Posted on Nov 05, 2009
SOURCE: PBX Panasonic KX-TEM824 configuration
Operator /automatic line
Posted on Aug 13, 2011
How to put and answering machine..
Panasonic KX T7730 Google Search Check this link to download the user manual to this phone. It has all details. Hopes it will help you. Gopakumar Gopalan Google
Jun 17, 2014 | Panasonic KX-T7730 Corded Phone
Tip
Options for Adding Serial Ports The serial port is prevalent on PC's ...
The serial port is prevalent on PC's as well as scores of industrial, scientific and consumer devices, making it a convenient starting point for communications. Since RS-232 itself is only suited to short connections (50 ft. max.) many applications require that it be adapted to fit requirements. RS-422, typically used for extending RS-232 communications, provides full duplex communications between two devices. It can also provide one way communications from one master to several slaves. RS-485 communications standard allows cable lengths up to 4000 feet. It also provides very high noise immunity. Multidrop connections up to 32 different nodes can be made over a single twisted pair cable along with a signal ground connection.
This article summarizes the choices a system designer has when adding a serial (RS-232, RS-422, or RS-485) communications device. There are many different ways to add additional serial ports to your Desktop PC, Palm, or Laptop PC. USB, PCMCIA, PCI and ISA are some of the methods that will be discussed.
The Universal Serial Bus (USB) provides a high data rate and Hot Swap connection for PCs, providing an easy connection to a wide variety of multimedia and network USB devices. Generally considered to be for home or office use, USB is finding its way into Industrial applications.
PCMCIA Serial Ports are yet another way to add serial ports to a PC that has PCMCIA Slots available. Most Laptops today offer only one (if any at all) DB9 type serial ports. A PCMCIA Serial Card is a good way to add a serial port (or ports) to any laptop that is low on available serial ports (RS-232, RS-422 or RS-485).
PCI Cards are becoming more popular as a way to add serial ports to desktop PC's. PCI type slots are becoming the "norm" in standard PC's today, and PCI Serial Cards are an excellent way to add serial ports. The standard Desktop PC may only come with one serial port standard (if any serial ports at all). PCI Serial Cards use Software Drivers to address the ports to the PC.
ISA Cards are yet another way to add serial ports to the older desktop PC's. ISA type slots are becoming scarce in standard PC's today, but are still an excellent way to add serial ports. The ISA Cards are typically addressed using dip switches and shunts or jumpers to set IRQ's for each port. No Software Drivers are required with ISA style serial cards.
Palm OS PDA's may be connected to RS-422 or RS-485 data circuits using Palm adapters. These adapters offer total portability for collecting data and field service chores. The Palm device and the adapter will usually slip into a shirt pocket. Some models use the PDA's connecting cable, some include a cable and some are cradles that allow the PDA to nest in place and connect directly to the Palm base socket. PalmTerm Freeware allows you to transmit and receive data from the Palm serial port.
on Sep 12, 2010 | Computers & Internet
Kx-td1232
You have to change the usb to a virtual serial port to do it.
Aug 06, 2012 | Panasonic Kx-td1232 Super Hybrid Pbx...
KX-TES824UE USB DRIVERS and proramme CD wanted
i install Panasonic provided software for the pbx TEM824 to connect through usb port it shows "can not open usb port".
Guide me what to do.
thanks.
Sep 11, 2011 | Panasonic KX-T7730 Corded Phone
How can I view and print call log from PANASONIC KX-TEM824?
Viewing is easy, printing not so much. The system has a DB-9 serial port on the cabinet. That serial port can be used to capture SMDR (Station Message Detail Recording) to a software program that can sort and print the call logs. Outside of that, you can turn on call logging (an option 6 or 7 or 96 and 97 IIRC from the PROGRAM press a button and dial the code) that will visually display personal or system calls.
It would be in your Operating manual. We use a program from the U.K. that captures the serial port and makes it available on the network, called Serial Logger Service It's a 30-day free trial, then $75 to register it..
Carl
Aug 19, 2011 | Panasonic KX-T7636BK Digital Telephone...
How to connect my laptop via RS232 to my NEC XN120 telephone exchange using the PC Pro telephone system software in order to programme the exchange?
I connect mine with the RS-232 cable in the side of my laptop. It's a Toshiba rinning Windows XP (nee Vista).
Since you're asking the question, I guess you don't have an RS-232 port. For my Vista machines without serial ports, I own a USB to RS-232 adapter cable. On our side of the pond, they carry names like Iogear GC-232. Here's a U.K. search result http://www.amazon.co.uk/USB-RS232-Converter-Cable/dp/B00077DJIQ
Sometimes, you have to go into the device manager and change the port assignment of these adapters to something in the 1-4 serial port range. That was common with the old software.
Carl
Feb 22, 2010 | NEC Lands Phones
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
Panasonic KX-TA308 Phone Logo
204 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
