Question about Dryers
Defy Autodry 252
Hi. I have a defy tumble dryer from South Africa. Firstly I cant get parts here in Australia. secondly I cant get it repaired at a reasonable cost after sourcing the parts from SA.
My problem is, the belt that runs around the drum had cut. I managed to buy 1 from SA and bring it over. My hubi put the new belt on and it worked for abt 10 mins and then it started to blow just cold air after that. we went to a repair company here, they tested the element and said its blown, and they dont have the same size so we must get it from SA and they will fix it. We bought the new element and now we find out the element is not the problem.
What could be the problem? Why is it only blowing cold air?
4 Suggested Answers
  • 3074 Answers
SOURCE: DEFY AUTODRY WIRING DIAGRAM
disconnect dry and in the back of dryer in top left hand corner is your diagram, looking from back of dryer, just remove the 6 screws from the top panel at the back of the dryer Good Luck Tim
Posted on Dec 26, 2010
  • 16 Answers
SOURCE: Defy dryer, not heating
Check that you have 220v first. Your dryer will work on 110V but will not dry. You need to check all thermostats with a ohm meter (be sure to unplug dryer), they should be 2 ohms or less. Set ohm meter to 1x. If they are good go to heating element (your ohm meter should be on 1X as wel. You need to check to make sure you have continuity (however, this does not mean that it is not bad). You need to take it out and visually inspect it to make sure it has no breaks in the coil. If it does you can buy a rewire kit for runder 30 bucks for most models.
Posted on Jan 06, 2009
heatman101
  • 43501 Answers
SOURCE: Defy autodry, comes on timer
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Aug 18, 2011
Defy Tumble Drier DTD 252 wiring diagram
Request the wiring diagram directly from Defy.
Dec 10, 2017 | Dryers
Defy autodry tumble dryer
This will be bearing noise, the front of the drum uses a felt strip as a bearing and this can wear causing a metal on metal grinding sound, or it could be the rear bearing. You need to dismantle it to investigate further.
Mar 06, 2012 | Cell Phones
Defy autodry, comes on timer works but will not tumble
heatman101
Aug 15, 2011 | Dryers
I've bought a Defy Autodry tumble dryer, but the black "rubber" on the door keeps coming out, which then pushes the door open, and the machine then automatically stopped. Can i just replace...
A TUBE OF CONTACT CEMENT WORKS WONDERS ON THE SEALING RUBBER - JUST FOLLOW THE INSTRUCTIONS ON THE TUBE . IF ITS GOOD ENOUGH FOR DOOR SEALS IN THE AUTOMOTIVE INDUSTRY ITS GOOD ENOUGH TO HOLD YOUR DOOR SEAL IN PLACE - GOOD LUCK.
Jul 26, 2011 | Dryers
Where can i find a maneul on a defy 721
Check in this two links:
- Defy AutoDry
- Defy AutoMaid
Both in PDF format.
Apr 25, 2011 | Ovens
Dec 26, 2010 | Dryers
Jan 03, 2009 | Roper RES7646KQ Electric Dryer
Dryers Logo
421 people viewed this question
Top Dryers Experts
