Question about Estate Dryers
Runs but not heating. Where is the thermal fuse located?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Thermal fuse is mounted to the exhaust duct inside the back cover. If this fuse goes bad the dryer will not heat and you'll have to replace it as it cannot be repaired. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 29, 2010
The dryer runs but there is no heat coming out of it
lllThis is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. seth765.jpgseth765_0.jpg
Jan 18, 2011 | Maytag Atlantis MDG6400AW Gas Dryer
Dryer runs but does not got hot, therefore does not properly dry clothes. I checked the heater element and it is good. Any suggestions?
The Most common problem is a bad thermal fuse.
1 the thermal fuses are located in the cabinet of the dryer under the drum
they can also be located on the front of the blower wheel housing. on the back wall of the dryer or along the heating element can.
2. some kenmore, whirlpool machines have these fuses located in the rear of the machine.especially when the lint filter is located in the top of the dryer.
3. the heating element can also be bad.
4. if you have an ohm meter you can check the continuity of the thermal fuses,as well as the heating element.if there is no continuity on any of the above mentioned parts. Replace the faulty parts.
Jan 10, 2011 | GE WSM2420T Top Load Stacked Washer /...
Motor runs but no heat
check lint trap. then check heating element or thermal fuse. both located in back panel, before removing back panel unplug from wall. locate heating element remove wires and with volt meter set on continuity check for reading or continuous beeping sound. if no sound or reading, replace element. or locate thermal fuse located near exhaust duct, the fuse is coated in white or black plastic with 2 leads sticking up, remove wire and no continuity replace it i hope this will help
rwpfn@aol.com
Sep 01, 2010 | Kenmore Dryers
No heat
The thermal fuse is located on the blower housing while the thermal cut-off is located on the heater housing. If the dryer is electric, runs but doesn't heat, the thermal fuse is not the problem; otherwise the dryer will not run because the thermal fuse is wired in series with the motor and cuts power to the motor when it fails. The problem could the heating element, high-limit thermostat, thermal cut-off, or cycling thermostat. These components can be found in the blower housing and the heater housing depending on the model of the dryer. Specify the model number of the dryer for a more specific advice.
Apr 12, 2010 | Kenmore 63942 Dryer
On the Kenmore series 90 electric dryer, where is the thermal fuse located.
The Thermal Fuse is located on the air blower housing. Its a small white plastic component with two wire leads.
The Thermal Cut-Out (TCO) is located on the outside of the heater box on the end opposite the heating element terminals.
The reason I mention both these components is because some people confuse the two and use the words interchangeably. There is a difference between the two components and what they do.
DOUBLE CHECK YOUR SYMPTOMS:
If your dryer does not run at all, check your Thermal Fuse.
If your dryer runs, but does not heat you need to check the Thermal Cut-Out.
If you have any questions, please post back and let me know what symptoms you are having. Please include your complete model number (located on a nameplate around the door opening) so that I can determine how your dryer is configured. I hope this is helpful to you.
Jan 06, 2010 | Kenmore 73952 Gas Dryer
Kenmore 80 dryer runs and blows air but no heat
If it's an electric dryer, then unplug the machine and check for a blown thermal fuse or a faulty heating element. The thermal fuse is about an inch long and is located inside the rear of the dryer, usually attached to or near the exhaust duct. The thermal fuse and heating element can be tested for continuity using a multimeter or ohmmeter. A lack of continuity will indicate a bad component. Sorry for your trouble and I hope this helped. Best wishes.
Oct 07, 2009 | Kenmore Dryers
Runs no heat
heat coil is probably your culperate
Jul 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
No heat
if it's a gas dryer, it's the thermal fuse. if it's an electric dryer, it's the thermal cut-off located on the heating element housing. good luck bud :)
Jul 06, 2009 | Dryers
Kenmore dryer no heat
check the thermal fuse to see if it's open which means blown(no continuity through it). check to see if heat element is broken somewhere. And if thermal fuse is blown then you'll also have to replace the thermostat switch and the high limit thermostat switch(located close to heat element).
Apr 05, 2009 | Dryers
Kenmore Dryer won't heat
ok you moving in right direction but you jumped a step,,you already checked the thermal cut offf and the operating thermostat,,those where the two on the side of the heater housing,,you should have checked the thermal fuse and the thermistor,,they are on top of the blower wheel housing tuck a lttle to the left,,since you seem that you know what your doing just jump them out starting with the thermal fuse,,,keep me posted on the job
Jan 04, 2009 | Kenmore 63942 Dryer
Dryers Logo
49 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
