T V. remote control not working, new batteries instaled
  • cbetts Mar 08, 2009
    Tiny remote control came with the TV, it dropped on the floor and has not worked since. Tried installing new batteries however it made no difference. I also tried to use a universal remote and none of the codes would work with this TV. Any suggestions!!
    Scholar:
  • 57 Answers
Have you got a phone with a camera? The easiest way to check the remote is to "fire" the remote at the camera and view the image on the screen. If the remote works at all, you should see flashes of light around the infra-red LED on the remote. If you can't see anything, you can open up the remote, check for obvious poor solder joints. Sometimes a liquid spill insulates the keypad from the carbon contactors on the rubber pads. Try cleaning the ENTIRE remote in surgical or methylated spirit. Dry the remote thoroughly and then reassemble it and try the camera technique again. I have solved lots of remote problems this way.
Good luck.
Posted on May 26, 2008
    Sergeant:
  • 291 Answers
MEGATRONIX::
you are a "mense"= good human! eyeyeyeyeyeyeyeyey...ahahahah (angels singing in heaven!!)
I had to buy a remote control sensor card from MCM electronics @ $7.98 a pop.
Posted on May 27, 2008
My remote won't work
Many remote controls freeze up and appear "Dead", but some can be instantly brought back to normal operation by following 4 simple steps.
Use these steps on OEM (original equipment) remote controls for TVs, DVDs, Audio Systems, Satellite and Home Theaters.
Note: If you follow these steps on a universal remote control, you will need your universal's owner's manual to reprogram it.
1) Remove all batteries from the remote
2) While the batteries are out of the remote, push and release every button on the remote control one at a time, until all buttons have been pressed and released at least once. This action drains the capacitors in the remote's circuits and causes the remote's brain to go back to factory defaults.
3) Re-install the batteries, taking care to insure each battery is installed correctly. Use new batteries if you are unsure about the batteries you removed.
4) If this Remote Re-Start procedure is going to work, your remote should now be back to normal. Try it.
If your remote works, Great. If not, you can shop for a new OEM remote control at Remotes.com 1 800 Remotes Factory original replacement remote controls
If you need codes for Universal remotes REMOTE CODES COM
Feb 29, 2016 | Televison & Video
Swann dvr4-950 remote control not working
If new batteries, properly installed, did not get it working again it may have to be replaced.
Dec 15, 2014 | Televison & Video
My rmt-05 remote is not working after i put in new batteries
have you checked the polarity one the new batteries you installed? (flip the batttery updside down)
Aug 29, 2014 | Westinghouse RMT-05 TV Remote Control for...
I changed the batteries in my rca remote and now the indicator light will not turn off and the remote does not work
The new batteries may have been installed incorrectly. Check the polarity marking inside the battery compartment.
Nov 11, 2013 | RCA New Original CRK76WB3 Remote Control
My remote control does not get the light on with batteries brand new...remote control does not work
Check the battery contacts in its battery comparment for any rust or dust accululated. Clean them well before insrting batteries. If all are OK, the fault should be with its internal circuit board. If so, you have to open the remote control to rectify it. If you wish to get more details about how to check a remote control, check this link.
http://electronicshelponline.blogspot.com/ Pull up older posts there, either by its left side bar, or see it in 'Timeslide' window. One among the posts have details about how to check and repair a remote control.
Jun 19, 2013 | Televison & Video
Remote control for vmb070 does not work
There should be a clear indication on your remote where the battery compartment is. Usually there is a slideoff cover that has to be removed. Some remotes have covers that are difficult to remove. Once you have the compartment open, you can remove the batteries. Check for signs of corrosion inside the compartment and clean it before installing new batteries. Be sure to observe proper polarity when installing new batteries
Mar 17, 2013 | Televison & Video
My remote control does not work suddenly
Try installing new batteries such as Duracell batteries. Make sure they are installed properly in the remote with positive to positive nodes and negative to negative node. If you own a digital camera, you can test the remote to see if it is working. Point remote at camera (powered on) and press a button on the remote. If you see a blue / purple light on the remote's led, then the remote is working. If not, then the remote is probably broken and you need to buy a new one.
Aug 09, 2010 | Sony RM-PP404 Remote Control
Does any body know how to reset the ML350 alarm??....The remote control doesn't work after i replaced a new battery to the remote control. I couldn't even use the remote to lock/unlock the car. I was
SOME OF THE REMOTES REQUIRE THAT THE KEY BE IN THE IGNITION, IN THE ON POSITION. TAKE THE BATTERY OUT AND WAIT 10 MINUTES. THEN PUT THE KEY IN THE IGNITION AND INSTALL THE BATTERY WHILE THE KEY IS TURNED TO THE ON POSITION. HOPE THIS HELPS YOU. PLEASE KEEP ME POSTED. THANKS FOR AN HONEST RATING AND FOR USING FIX-YA. GOOD LUCK
May 18, 2009 | 2007 Mercedes-Benz ML350
Sony RM-Y180 remote control
Did you install the batteries correctly?
Some remotes (Universal) need to be re-programed when you install new batteries.
Go to remotefinder.rca.com/default.aspx?site=rca for proper codes.
Oct 30, 2008 | Sony RM-Y180 Remote Control
Televison & Video Logo
115 people viewed this question
Top Televison & Video Experts
