Question about Electric Earthwise Corded Lawn Mower 20in. Deck
What does the red blinking light on battery meant ? It is on The Electric Earthwise Lawnmower.
  • 1 more comment
  • Lisa Withrow Jul 06, 2013
    I have the same problem and now there is no illuminated light for the charger on a 24v battery for Earthwise electric mower.
  • Lisa Withrow Jul 07, 2013
    Went to batteries Plus - red blinking light led to shock when customer service rep tested charger. Charger is kaput.
  • Richard Oct 08, 2013
    I get that blinking red light occasionally. It occurs right after I plug in the recharger. If I leave it alone, the battery does not recharge. What I do now is unplug the recharger from the lawn mower battery and plug it back in and make sure that the red light does not blink. I have found that pushing in the jack as far as possible kicks off the blinking; I try now to just push in the jack with gentle pressure. This seems to work best.
    New Friend:
Red blinking light according to test at Batteries Plus means that the charger is kaput.
Posted on Jul 07, 2013
2 Suggested Answers
  • 5 Answers
SOURCE: Mower started smoking, then stopped working.
Try to see if there is any oil in it. Or maybe your belt is clogged. A good cleaning and maybe a change of plug may help.
Posted on Mar 02, 2010
Where can I buy a rectifier for a 15 amp earthwise lawnmower
Hello Condo Sarto,
The first site that popped from an internet search...
Sears Parts...
searsparsdirect com
Jun 27, 2016 | Electric Earthwise Corded Lawn Mower...
I turn it on and set it to 375. Why does it just keep blinking?
blinking green red light Electric Kettles Questions & Answers ...
www.fixya.com > Forum > Tags > blinking green red light
Electric Kettles blinking green red light questions and answers. Ask your blinking ...the kettle lights up but won't heat up, just bought it, the on switch shows red, but it isnot working...what to do? ... Chef's Choice 677 Cordless Electric Kettle.
red icon blinking Electric Kettles Questions & Answers - Fixya
www.fixya.com > Forum > Tags > red icon blinking
Electric Kettles red icon blinking questions and answers. Ask your red icon ... Light will not stop flashing Even after descaling and cleaning thoroughly the red lightflashes. Any ideas? ... "On" switch blinks, kettle won't heat Our 4-week old kettle juststopped working. When we ... Chef's Choice 677 Cordless Electric Kettle.
Dec 12, 2015 | Chef's Choice Kitchen Appliances - Others
Batteries shows fully charged. 24 volt shows 27 volts fully charged but shows RED light when install in mower.
it's never the motor, it's always the batteries.
you are most likely testing the batteries with just a meter and not under load
you will need a tool to put the battery under a load, it will end up costing more than two new batteries.
just replace the pair and you will be fine, i have done enough of these over the last few years.
good luck and you will have no problems with the new batteries.
May 21, 2015 | Electric Earthwise Corded Lawn Mower...
Red charge light keeps blinking. does that mean the battery is dead?
Your user manual should provide some info. If not, consult with Radio Shack direct. I'm not familiar to this product so I can't tell you if the charger is defective or the battery needs replacement.
May 07, 2014 | Radio Shack Accurian LMD-5108A Portable...
Earthwise battery charger flashes green then red then quits when plugged in
Typically that is an indication that the battery is bad. A battery supply place, such as Batteries Plus should be able to test the battery and tell you if it is good or not.
Mar 23, 2014 | Garden
I have an earthwise 12 amp electric lawnmower that trip the circuit breaker and now will not start at all. Any suggestions on what might be wrong and how I could fix it
If the circuit breaker trips there are three possible reasons
1. the motor is being overloaded - clean underneath ( as recommended above); or if the grass is too wet or too long or both you may need to handcut; or the motor bearings need lubricating (same problem as me-how?)
2. There is an electrical fault - check the plug and cord (as above) or get an electrician to check the motor and connections; or the carbon brushes to the motor need replacing
3. You have a faulty circuit breaker! - borrow and test with a replacement
Apr 11, 2012 | Electric Lawn Mower
My son removed the batteries from our Earthwise 24 volt mower. We got replacement batteries and need to put them in but need a wiring diagram or instructions to put the wires back in the correct terminals.
The red and blue posts are jumpered on the right side if you are looking from the front. (There is just a wire connecting these two terminals)
The other red post has red and turquoise wires. The other blue post has white, blue and black wires going to it.
Sometimes easier to find solutions under Homelite brand. Exact same mower.
Apr 20, 2011 | Electric Earthwise Corded Lawn Mower...
The first battery light keeps flashing when I turn on the control. I believe it is locked, but I have no idea how to get it unlocked. It is a Merits MP1 electric folding wheelchair.
If you are getting just the red light blinking then the batteries are low and not fully charged. If you have been charging and are still getting just the one blinking light then either your charger is not working or you have bad batteries. Hope this helps
Nov 11, 2010 | Electric Mobility Merits Mp1 Folding...
Mar 01, 2010 | Electric Earthwise Corded Lawn Mower...
Where can I buy a bag for this mower
Go to www.precisionope.com and order one.
Good day.
Oct 04, 2009 | Electric Earthwise Corded Lawn Mower...
Electric Earthwise Corded  Lawn Mower 20in. Deck Logo
444 people viewed this question
Top Electric Garden Experts
dannydoesita
JohnPaul Robertson
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
