Question about Sony Televison & Video
Need to get rid of the skip sign along side AV4
  • 21 Answers
With your remote, Hightlight the AV4 input, press select on your remote. use the remotes cursor to left/right or up/down to change the name from skip to whatever you want it to be.
Posted on Sep 29, 2010
Testimonial: "first class information thank you"
What does AV1 mean on a SAM*TRON TV mean? How do I get rid of it?
av 1 is the source input for the tv
there should be av 2, 3 4 etc and each one isa for a different input item
for example av1 is for the tv -aerial , av2 may be dvd input , av3 may be x box, av4 home theater
how to get rid of it . click on exit or ok
Sep 30, 2016 | Televison & Video
AV4 input
To get your over the air signals, you would of course hook up the outside antenna cable to the back of the TV set, as per the owners manual. Then go to channel search in the set up menu as per the owners manual, then do a guide plus set up and follow the directions word for word in the owners manual. It is just way to long to explain here. In case you do not have the owners manual, you can get one from here http://www.p4c.philips.com/na4/3/34pw981599/34pw981599_dfu_aen.pdf Good Luck
Aug 26, 2007 | Philips 34PW9815 34" TV
I have a % sign in auto, how can I get rid of it?
WE ARE NOT MIND READERS,IF YOU DON'T INCLUDE,MAKE,MODEL,YEAR AND PRECISE PROBLEM,THEN YOUR QUESTION WILL BE SKIPPED OVER IN ORDER TO HELP THE PEOPLE THAT DO INCLUDE ALL NEEDED INFORMATION AND IF YOU POST MORE THAN ONCE THE DUPLICATES WILL BE REMOVED AS SPAM.THANK YOU.
Jun 03, 2015 | Computers & Internet
Write protect sign on olympus e-pm2
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 02, 2013 | Olympus PEN E-PM2 Digital Camera Body
My (Cable Service) wire feed is directly behind my HDTV and hooked up over my fireplace . The Rxv667 is located on a side wall book shelf. I have A HDMI wire running to the TV from my receiver. Do I need...
Is there a set top cable box, or are you feeding the cable directly to your HDTV (coax directly to the TV). If you are feeding cable directly to the HDTV then you don't need HDMI. There maybe exceptions, but most TV's don't have HDMI output. The only thing you need to run from your TV to the Yamaha is an audio cable. I assume your HDTV has an optical audio out (either TOS or coax.... Your Yamaha will accept either). Connect the optical audio cable to the AV4 input on the Yamaha. This way when you hit the TV scene button on the Yamaha remote, it will select the AV4 audio input (the default for the TV scene). The optical cable will feed the full audio signal, so that the Yamaha can pass through the surround sound or use the decoder as appropriate to feed your 7.1 or 5.1 speaker system.
If you have a set top box, you may be better off moving that near the Yamaha. In this case, cable goes to settop box, output of set top box via HDMI or component video (RGB) and optical audio to the Yamaha (if you use HDMI Input 2, and AV4 for the optical audio (if necessary), the TV Scene will select the appropriate inputs) and then an HDMI to your HDTV.
In case one, you may need to setup the TV to process the audio appropriately. I have experience with Panasonic Plasma but thats about it.
Feb 24, 2011 | Yamaha RXV667 Receiver
TWO PROBLEMS - #1 - MOUSE POINTER FREEZES, ALONG W...
You may be a victim of spyware/maleware infections. You will need to have your system cleaned. This should help resolve your issue.
I would recommend trying CCleaner first to see if this helps you. Please keep in mind this will not rid your system of everything just keep you a float and offer you a fighting chance.
Please keep me posted and updated on your issue. I am here for you and will see your issues out till resolved.
Have a great and wonderful day :)
Thank You
Please do not hesitate to contact support :)
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com
http://www.itsupport.co.cc
May 20, 2010 | Computers & Internet
Lost Codes for Memorex AV4 Remote
I Also posted for Help on FreeCycle.com and a local resident had an original manual with the Codes, and sent Me a Copy on my E-mail. It worked perfectly. thanks 4 trying anyway. Chuck.
Aug 26, 2009 | Televison & Video
Problem with AV 4 input only.
Check to make sure your settings on your PS3 are set to the RED BLUE GREEN (component) input.
Mar 25, 2009 | Philips 55PW9363 55" Rear Projection...
Bass making head unit skip
you need to get a headunit that has an anti-skip buffer, or get one with a USB input. With the USB input, you can put all your music on a flash drive and get rid of the CDs.
Feb 11, 2009 | 1998 Honda Civic
Im having trouble connect say my xbox 360, when i click the input button on the remote it only comes up with the following selections: HDMI, TV. no av1,2,3,4 or anything like that help
just went into menu-settings-input selections i think-and all but HDMI and TV had skip on them, i just put av4(front inputs on tv) on the game option
Apr 27, 2008 | Panasonic Televison & Video
Televison & Video Logo
76 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
