Question about Adobe Photoshop Lightroom
Printing Module When clicking on the Print module I get the following error message "An error occurred when attempting to change modules." Ihave downloaded the 1.4.1 upgrade and the system will not let me reinstall from the disc
  • Kreifus May 25, 2008
    My printer is an Epson Stylus Photo R300
    Scholar:
  • 198 Answers
Try to download another version through internet... i guess u can download it in download.com... just try it once
Posted on May 25, 2008
  • 1 more comment
  • kishore swamy May 25, 2008
    i request you to be specific with the name of your printer... so tht we can giv particular solutions... thank u
    http://labs.adobe.com/technologies/light...
    try tis
    http://www.epson.com/cgi-bin/Store/suppo...
    from this link your job will be easy i guess.....download the drivers here
How to get printing threw pos system
Sir/Madam
PRINTER ERROR CYCLE POWER
Control Panel Message
61.x PRINTER ERROR CYCLE POWER
Event Log Error
Service Message 61.0x.00
The printer encountered a parity error when accessing either internal memory (x = 0) or SIMM memory (x = 1-4).
Required Action
  1. Cycle power.
  2. If the message persists: Verify that the SIMM module is installed correctly.
  3. Turn off the printer, remove the SIMM module, and then turn on the printer.
  4. If the message does not display, replace the defective SIMM.
  5. If the message continues, turn off the printer and remove the next SIMM module, then turn on the printer.
  6. Repeat this step for the remaining SIMM modules until the problem is isolated.
  7. If the message continues without any SIMMs installed, replace the Formatter PCA.
If you Still Having Hp Printer Problem Then Visit official HP Printer website Below Link URL:
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay/?sp4ts.oid=25474&spf_p.tpst=kbDocDisplay&spf_p.prp_kbDocDisplay=wsrp-navigationalState%3DdocId%253Demr_na-bpl70117-1%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken#N10C53
Or
If You Still Facing Problem Then Follow Us For HP Printer Online Help On: HP Printer Support
Feb 12, 2014 | HP (EY023AA) Thermal Printer
I'm trying to print of slides for a lecture - when I click "print" on powerpoint, I change the number of slides per page to 3, click frame slides, and click two-sided printing. When I click okay...
I hate to ask, but do you have a duplex printing module on your home printer or are you printing from a printer that has two sided printing capabilities?
Feb 07, 2011 | Computers & Internet
Unable to obtain authentication input/output error has occured. error while loading applet module is not registered
unable to obtain authentication input/output error has occured.
Nov 19, 2010 | DigitalPersona U.are.U 4000 Fingerprint...
HP C7280 doesn't print 2-side from my computer
have you use duplex unit?
you have to change your driver option both side print
Thanks
Oct 27, 2009 | HP Photosmart C7280 Printer
Memory write/read error on start up
Do not post your service tag on any forum, it is private data and needs to be protected (some turkey tried to get some stuff from Dell on a friend of mine's account using her tag she had posted)
If the system will post and boot, try flashing the BIOS to the current version. Then try each RAM module one at a time. Generally, only one module will fail at a time. SO take one out, boot to BIOS (SO it recognizes the RAM quantity change) then see if the system boots without error. If it does, then the module removed is likely bad. If the error still occurs, try the steps above with the other module. If errors occur with only 1 module, replace that one.
If errors occur with either module, you may have a motherboard issue. Or, very unlikely, 2 bad memory modules
Mar 23, 2009 | Dell Inspiron 1525 Laptop Midnight Blue
HP Officejet 7210 All-In-One printer two-sided printing
Had the same issue with an Officejet 7210.
Basically, what the printer is trying (not very well) to tell you is that it is not capable of handling the entire two sided printing project automatically - which for reasons that are completely obscure is the default setting for two sided print jobs - way to go HP!
To solve the problem, open up the printer's properties window (or preferences depending on your approach). On the printing shortcuts page, you should find a drop-down menu entitled Print on Both Sides. This drop down should read 'Automatic' (which indicates that the printer will print the first side, flip and reload the paper and print the other side without any intervention - yeah, riight). Simply change this setting to 'Manual' and the problem is solved!
Happy printing!
'Doc'
Nov 23, 2008 | HP Officejet 7210 All-In-One InkJet...
Error #12288
problem in the driver call to the toll free no 1800110011 and ask for the resolution.....
Aug 17, 2008 | Samsung CLP 300 Laser Printer
Phaser 8550 error 19,004.40
The printhead was installed in another machine and the codes do not match. You need to manually sync them. Here is the procedure:
Manually synchronize the Printhead and Electronics Module codes.
NOTE: The Printhead and Electronics Module codes should synchronize automatically when a new printhead is installed. If a 19,004.40 error occurs, it is possible that the replacement printhead was previously installed in a different printer. After manually synchronizing the Printhead and Electronics Module codes, be sure to test the new printhead for print quality defects.
To manually synchronize the codes;
1). Power OFF the printer.
2). Disconnect the printer from external devices (A/C power can remain connected).
3). Locate the "Factory Only" port on the electronics module (located between the PS and PE lights (Figure 1).
4). Use a Hard Disk Drive (HDD) jumper (Figure 2) to short the top two pins.
NOTE - If a HDD jumper is not available, use another conductive item, such as a screwdriver, to short the pins. Use caution to avoid contacting the surrounding frame, as this may permanently damage the Electronics Module.
5). With pins shorted, power ON the printer.
6). When printer reaches the mechanical initialization stage of the power on sequence, power the machine back OFF.
7). Remove the HDD jumper.
8). Code should now be synchronized. Power ON machine and verify the 19,004.40 error does not re-occur.
NOTE - If error persists after this procedure, attempt the procedure again, and be sure to allow the printer to complete its BIST and POST test before powering OFF in step 6.
Jun 29, 2008 | Xerox Phaser 8500/DN Printer
Xerox C2424 problem (11,009:46 and 13,008.47)
The second fault is a result of the faulty electronics module. It is a print head heat related issue.
Question is, is the print head also faulty.
That electronics module is very expensive.
But the 11,009 specifically is a failure of the electronics module.
Have had those codes a couple of times.
Most likely the 50 volt source has failed, that maintains the print head heat.
A Drum Assembly thermal error has occurred. The following troubleshooting procedures apply to these errors:
arrwup.gif 13,008.47 The Drum Heater is too hot
Jan 30, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
What is an ISSET_SE error?
When you attempt to install the PhotoMAX software from your CD-ROM drive, you may receive the following error message: "ISSET_SE caused a general protection fault in module (FILENAME) at (ADDRESS) where (FILENAME) is the name of the program file you are trying to run, and (ADDRESS) is the memory address at which the error occurs." This is an error that can occur with Windows 95 and 98 under certain conditions -- it does not indicate an error with the PhotoMAX software. This (error message) can occur if any of the following conditions exists: * Norton AntiVirus version 4.04 is installed and Norton AutoProtect is enabled. * You use LiveUpdate for Norton AntiVirus to download an updated version of Norton AntiVirus. * Microsoft IntelliPoint software is installed on your computer, and the Point32 program is currently running. * Microsoft IntelliMouse or Microsoft IntelliMouse Trackball software is installed on your computer, and the Mswheel program is currently running.
Sep 21, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Adobe Photoshop Lightroom Logo
54 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
