Question about Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis washer is bouncing up & down so hard it is bottoming out. (not banging side to side!) Model #27062603 - only 1 1/2 yr old but is used daily Any ideas?
  • 15,935 Answers
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
Kenmore top load washer,model 110 20102311,should i be able to move tub from top very easily in any direction or should there be some tension,my tub is banging of side walls in spin cycle
The tub should move easily from side to side, however, a better test is to push down sharply on the tub and let go, it should come up and stop the first time, not bounce up and down several times. If it bounces up and down the suspension rods are shot. The part number for the kit of 4 is W10780045, all 4 need to be replaced as a set. To replace them the top needs to be loosened and lifted up, the rods disconnected from the top 2 at a time and replaced (doing opposite corners makes it easier IE: front right and left rear, front left and then right rear). Disconnect the top ends of two rods, lower top, lean washer back and pull out the disconnected two rods from the bottom, reverse the process to install.
Sep 30, 2017 | Kenmore Washing Machines
When washer goes into spin cycle it starts to tub starts to bang against side walls and shortly after error out, with an error on electronic display. Kenmore Elite Oasis
either unit is unlevel or one of the tub supports has come disconnected .... these washers have a slanted top lid so you must put level at side of washer on front and both sides and check front to back with level at side cabine seam as your leveling point
Jan 24, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
When the washer spins the drum sounds like an airliner it also just started making a banging sound I can feel the banging on the right side of the washer
Try load it a little lighter and spread the clothes more evenly (in other words so that the weight is not all on one side.
Sep 06, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I am working on a Kenmore Oasis washer, model
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$#@
Jun 29, 2010 | Kenmore 24032\24036 Top Load Washer
I am working on a Kenmore Oasis washer model 110-27062603 which fills a little then code F-50 comes up and it will not run. I can cancel and drain water. I read through diagnostics-found no reading on...
Jun 23, 2010 | Kenmore 24032\24036 Top Load Washer
Excessive vibrating and banging in the spin cycle with some washes. The unit is only 1 month old. Any advice?
You have a improper installation. The machine has to be perfectly level side to side and frotnt to back. After leveling, check the feet on the bottom and see if one is bouncing on spin with a load. Adjust the bouncing foot down until machine stops bouncing.
Jan 25, 2010 | GE Profile WPRE6100G Top Load Washer
4 yr old washer has started banging around violently during wash cycle. Then during the rinse cycle when it starts to slam it will usually shut down with and error of UL. What could be the cause and can it...
some times the springs that hold the tub in place will come off try to look under the bottom there are metal brackets around the drum and should be large short springs holding it three or four if loose just reattach look at one still conected to use as example to put it back together
Oct 17, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Oct 15, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore front load washer #44072 drum banging noise
2 possible issues with your washer.
1 or both the support shocks or springs have broken
the drum would look off center even when empty
or rear bearring has worn out.
this is a very common problem with the fridgidaire washer... (this kenmore is a frigidaire model)
problem is caused by very hard water (well water) or improper use of detergent. this machine uses a High efficency type detergent, marked by "HE" on the detergent container
May 27, 2009 | Kenmore 44072 Front Load Washer
Kenmore Oasis HE Top Load
there are 4 rods holding the drum up, check to make sure all 4 are attached.
Oct 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
88 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
