Question about Ulead Videostudio 8 for PC
I've got an Ez Grabber and all i get is a black screen with a few green and blue lines. And before you ask, yes i have tried every single possible option and just the same blank screen. please help!
2 Suggested Answers
  • 4 Answers
SOURCE: I have a EZ Grabber but do not know how to work it.
had same problem. ensure right selections are made in the souce menu. & that your connectors are out connectors and not ins.
Posted on Sep 23, 2009
Testimonial: "Thank you for your suggestion unfortunately I am unable to test it out at the moment but will get back to you when I can. Again many thanks."
Samsung LCD TV diagnosis. Possible tcon board?
T-con board is causing all your problems. You are correct. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2015 | Samsung Televison & Video
My Samsung TV developed a a single blue vertical line on the left side. what could possibly cause that.
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name and type (TV, VCR, DVD player etc:) of your device, in the search box [at the top right] of the home page. It will make surf easy.
Jun 13, 2015 | Samsung UA-40H5500 40" Full HD Smart...
How do you edit with the ez grabber vc500
Hi
I give below a link to the EZ Grabber installation manual.
http://www.derbymagic.com/files/EZGrabber_manual.pdf
I have been through this but can find nothing to indicate an "edit" facility.
I then tried this link
http://www.dmmdownload.com/downloads/CURRENT/PVR/Diamond%20VC500CXT%20Walkthrough%20Response.txt
which clearly indicates an edit facility via some Arcsoft software which presumably is supposed to come with the grabber.
It is possible that one of the "software utilities" on the webpage (link below) may contain the software required.
http://www.diamondmm.com/driver-downloads.html?option=com_content&view=category&id=599&Itemid=1014&select_item=354_598&select_item_354_598=355_599
Good Luck
Aug 25, 2014 | Diamond Multimedia ( VC500) Video Capture
GE digital timer 15313 has 3 wires, black, blue and green. Wall switch wires have bare, black, red and white from one line, and black and white from the other line. I've tried every combination
It sounds like you are replacing 3-way switch.
Low voltage light? Are these lights connected to 120Volt circuit?
I think you want the GE 15312 timer, instead of GE 15313.
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
GE 15313 is for single-pole incandescent light bulbs only.
This is live answer 11-2012
Add a comment for more interaction on answer.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 22, 2012 | Hardware & Accessories
I have an EZ Grabber Item No: A07JR. Trying to get VHS film played on a Sharp VC-MH815 6xHead/Nicam/Hi-Fi Stereo Player Recorder. Useing video composite from the player to USB attached to a Toshiba...
This is a solution, probably resolve your problems as well, for converting VHS to DVD, its a tip I posted some time ago, might help you out:-
There appears to be quite a few problems with people trying to convert their video tapes to DVD using a PC and propriety converters, editing programmes etc.
Friends have also has such issues, lip synch being one of the most prolific.
I've successfully converted mine, without too much issue and managed to avoid these issues.
I hook up my VHS recorder with a DVD recorder2_bing.gif which also has a HDD. Daisy chaining it on to a TV to monitor. All with scart leads.
Play the tape, record to the DVD hard drive. Finally edit and dub to DVD.
Have fun ..............
Nov 25, 2010 | Cameras
Red screen, horizontal lines, 2'' black vertical bars both sides
it looks to me that you are not a technician becouse you are measuring at the wrong places risking a hazard shock if you have a little experience get the service manual and check your power supply and the h v capacitors near the horizontal output if not please take it to your service center
Dec 16, 2009 | Televison & Video
Sep 18, 2009 | Ulead Videostudio 8 for PC
Mitsubishi WT-42413 Blue Green and Red Line
there is a section in the tv working just to keep the screen fitting top to down (vertical section) some capacitors are dry now in that area. this one has not to be a expensive job in the workshop. Try estimates
Apr 14, 2009 | Mitsubishi WT-42413 42" Rear Projection...
Phone line/phone jack problem
The wiring on the jacks is set up for a 2 line phone.
If you take the jacks apart, you will see either:
A) red, green, and black, yellow
B)white blue/blue white and white orange/orange white
You need to swap the pairs.
If there are red/green/black/yellow wires. remove the yellow/black and move them to where the red/greens are. Then put the red/green wires, where the yellow/black used to be.
OR, you need to swap the orange and the blue wires.
Dec 22, 2007 | Lands Phones
Ulead Videostudio 8 for PC Logo
341 people viewed this question
Top Ulead Computers & Internet Experts
d3yavu3
Alun Cox
Karan Sethi
Are you an Ulead Computer and Internet Expert? Answer questions, earn points and help others
