Question about Camping, Backpacking & Hiking
I have brand new just fitted MK Gel batteries and a known working charger. When the charger is plugged in and charging a orange light should come on or green when fully charged. At the moment only the red power light comes on and the charging indicator light does not. It is a Pride Celebrity 4 wheel scooter. I have checked the voltage through to the controller box. Lights and controls working fine. Kind Regards David Hornby
    Brigadier General:
  • 3,917 Answers
Could be controller or maybe wiring is bad. If the green light doesn't come on then this would probably be the circuit breaker has popped or possibly a fuse blown somewhere. There may be a fuse on each of the battery harness leads, so they could be worth a check. May also be a bad connection somewhere or a broken wire. Also worth checking the key switch in case this is not working. If the green LED on the console IS on, is it flashing and if so, how many times. This is a built in diagnostic system and will tell you what is wrong with the scooter if you have the owner's manual to refer to.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 29, 2010
Why dose my battery charger start for a second and click of
Could be scooter battery voltage is too low for charger to charge battery.
(It is a problem with gel cell batteries I have got a scooter that won't charge at all at home am going to try jump starting with another battery to fool the charger but I might have to buy new batteries.The Nursing homestaff took the scooter off my father in law and left it in the shed to get nice and flat instead of leaving it on float charge I should send them a bill for new batteries
Sep 16, 2014 | Health & Beauty
A brand new DSI from EBay, Turns on and plays. But will not charge Pluge gharger in a red (orange) light comes on, on for 6or7 hours but still flat tryed diferint charger still not working. eany Help...
Yo need to have it serviced or exchanged if under warranty. Oh first, if the charger is not the problem try out a new battery. Also, can you power it on withoit the battery? Meaning will it work plugged into the charger and the battery taken out.
Jan 01, 2012 | Nintendo DS Lite Console
What are the Best replacement batteries for the Jazzy Select 6 and Where is the best place (retail store or online) to buy them? I bought the U1 Gel Batteries at wholesalebatteriesonline.com and they...
ggirl why did you buy a pig in the poke they should refund your money because the batteries should have a six month warranty. Now always ask for the date code on batteries you are buying they shouldn't be any older than 4 months old. There are good batteries out there but if I offend anyone I'm sorry but MK batteries are very good also Interstate batteries and probably others that I'm not aware of. The best way to insure good batteries are buying fresh batteries, Charge them before you use the chair and always get into the habit of charging overnite if you use the chair daily. Never leave the charger plugged in more that 12 hours and if you don't use the chair daily charge at least once a week and always put up fully charged. Mk recommends charging the batteries daily for the first 20 days. Never run the batteries or let them fall below the red light on your battery level indicator. Your chair runs on about a 5 volt range (26-21 volts) after that the red light blinks like crazy. If it falls below 20 volts the charger will not charge the batteries. If you take care of them they should last you 3 years or more. Hope this helps
Oct 19, 2010 | Pride Jazzy Select 6 Indoor Power...
I have brand new just fitted MK Gel batteries and a known working charger. When the charger is plugged in and charging a orange light should come on or green when fully charged. At the moment only the red...
David, If you are not getting the yellow light on the charger then you have a problem with the charger. What voltage are you getting at the batteries when charging? You can check the charger by removing the end plate where the lights are to see if there is a fuse on the output side of the charger. if there is check to see if the fuse is blown. There probably is a fuse on the other end but since the red light comes on it is good. If you plug the charger into the charger port and put your ear to it you should hear a hum coming from the charger. Hope this helps you
Sep 29, 2010 | Health & Beauty
My ds lite won't charge.. the orange light appeared blinked
We had this problem with a brand new DS Lite...turns out it was a bad charger. If you have access to another charger, try that first. Good luck!
Apr 03, 2010 | Nintendo DS Lite Console
Laptop will not charge..
First of all, it could definitely be something with the battery. Batteries have a finite life-time, and yours might had reached it's end...
Anyway, chargers for laptops are quite "unique" for each brand, sometime even for each model. There's a chance that by your "trial and error" you might even caused more damage... :/ You should CAREFULLY take a look on what your laptop consumes, in terms of VOLTAGE and CURRENT. Connecting incompatible charger (even if it's plug fits perfectly) might (and often will) damage your battery and/or the motherboard.
With that said, try replace the battery (if you can try it without buying a new one - better), then use your ORIGINAL charger. Of that doesn't work - use a replacement branded charger. If that doesn't work either - you might need to check it the laptop still works.
Mar 10, 2010 | Dell Computers & Internet
Ds is plugged into charger. But when i try to
What is the orange charging light doing? If it is just flashing on, or only staying on or a minuet, that means you need a new battery. The orange light foes on when the battery has been charged to its maximum capacity. After each charge, the capacity is decreased. So if the orange light is on for only a short time, get a new battery.
Feb 28, 2009 | Nintendo DS Lite Console
Brand new psp battery will not charge
Did you charge it first? You need a good initial charge. Depending on the charger, it could be about 6 hours.
Also, remove the battery and check the metal contacts on the top and make sure that they are not covered by anything. Some come with a film to protect them.
Mar 10, 2008 | Sony PlayStation Portable (PSP) Console
Camping, Backpacking & Hiking Logo
93 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
