Question about Kenmore 24932 Top Load Washer
I have a Kenmore Elite model 110.20932994 washer. It feels with water and then does nothing, will not agitate, spin or drain. I tried jumping the lid switch and that did not change anything. Thought about the coupling but the motor is not running at all. I replaced the timer on this machine about a year ago when I was having the same problem and it fixed it.
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite Model 110 washing machine will not stope the agitate cycle
If the washer fills but does not agitate or spin, this is usually a symptom of a bad lid switch. The switch will either be located on the right hand side of the washer tub opening, or in the rear on the left hand side under the console. If you have a right hand model, examine the lid and make sure the plunger that activates the switch when it is closed is still intact. The plunger is a plastic piece that is physically mounted on the lid. Sometimes they break off. If the plunger is intact, try taking a small object (like a screwdriver or popsicle stick and push down on the lid switch contact while the lid is open and the timer knob started. You should hear a distinctive "click" when you push on the switch and the washer will agitate. Sometimes the switch can become loose and no longer make good contact. If this is the case, simply tighten the two mounting screws on the tub opening. If the switch relay is not clicking you may need to replace it. The part runs about $35.
If you have the left hand style switch that is enclosed under the console, the contacts are closed by a small metal bar on the back of the lid. Sometimes this bar becomes bent or loose. Open and close the lid and listen for a distinctive "click". If you don't hear anything, you may need to adjust the metal bar, or replace the switch. This style of switch tends to cost a bit more.
If you can provide me with your model number (located under the wash lid along the tub opening), I can research the part number for you and let you know where you can get it and give you step-by-step instructions on how to replace it. This is a simple repair job that the average consumer can perform with simple instructions and a few household tools. First, determine if this is the cause of your problem. Post back with comments and let me know if this helps you.
Posted on Nov 24, 2007
jsrock516
  • 5911 Answers
SOURCE: kenmore 70 series
Okay...I'm a little confused on your symptoms. You initially said it fills, but doesn't agitate or spin, but drains.
Then, you finished with the washer filling, no agitate or spin, but now doesn't drain.
Which one is it?
The symptoms you describe are usually associated with the following:
1. Fills, may or may not agitate, won't spin or drain - lid switch.
2. Fills, may or may not agitate, won't spin, but still drains - motor coupling.
3. Fills, may or may not agitate, won't spin or spins slow - gear case.
4. Fills, agitates, spins, but does not drain – water pump.
NOTE: These are the more common failure items with these symptoms.
Double check the lid switch by opening and closing the lid. You should hear a clicking noise to indicate the switch is working. The switch is located under the top panel along the wash tub rim on the right-hand side. If not, check to make sure the lid strike (small plastic piece on the lid itself) is in place. This activates the lid switch when the lid is closed. Also, check the mounting screws along the rim (there are two of them) to see if they are tight.
If the motor coupling were bad, the washer would still drain, but there would be a rattling sound as the washer tries to spin or agitate.
If you need replacement parts, go to searspartsdirect.com and type in your model number in the "Search by Model Number" window. The lid switch can be found under the "Top and Cabinet" heading as item number 11 (part #3949238). Instructions on how to replace are located at the following link:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
If you wish to replace the motor coupling, the part can be found under the “Brake/Clutch/Gearcase/Motor/Pump” heading as item number 13 (part #285753A). If you need instructions on how to replace, just follow this link:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
Now, there’s a couple of ways to drain the washer. If it’s a simple lid switch problem, you don’t need to drain the washer to replace the switch. With a broken switch repaired, the washer will run and drain by itself. However, if you wish to drain the tub you can use a shop vac to pull a vacuum on the drain hose. This may take a few times depending on the size of the shop vac. These wash tubs typically have about a 35 gallon capacity. If you do not own a shop vac, you can by-pass the lid switch by jumpering the two BLACK wires at the lid switch connector that is connected to the console. CAUTION: Make sure you UNPLUG the washer before jumpering, then plug back in.
I hope this information is helpful to you. If I’m wrong about the symptoms, please post back and update me on what the washer is or is not doing, so I can assist you further.
Posted on May 15, 2008
ndguy2481
  • 251 Answers
SOURCE: Washer does not spin and drain water. (Kenmore Elite Heavy Duty)
it seems to me ur washer transmission is going out or already there
Posted on Nov 26, 2008
  • 7 Answers
SOURCE: my kenmore elite oasis runs fine but wont go through spin cycle
Try replacing the motor coupler between the motor and pump three small pieces about 18.00 dollars at sears parts store.
Posted on Feb 04, 2009
jsrock516
  • 5911 Answers
SOURCE: how to install lid switch
The symptom of a washer that fills normally, but stops suddenly and will not drain is commonly caused by a lid switch malfunction.
The following link explains how to install a lid switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
If this is just a matter of reinstalling a switch that has come loose, a new switch may not be required. Inspect to ensure the mounting screws, switch casing, or switch lever are not broken. Make sure the mounting screws are tight. NOTE: You do not have to drain the washer to replace the lid switch. With the switch replaced, the washer will drain on its own. This will save anyone the trouble of having to bail. If you have questions, please let me know. I hope this helps.
Posted on Apr 27, 2009
My kenmore washer won't drain or spin. I took out all the water & it still won't spin. I hear the lid "click" and I hear a "hum" when I turn the knob to spin, but nothing else...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Jan 27, 2011 | Kenmore 24032\24036 Top Load Washer
I have a series 90 Kenmore top loading washer model number 110.26912691. At the end of the wash cyle it began to make a loud buzzing noise. I've tried to reset, the water will fill, but the washer...
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11026912691/0582/0153200?pathTaken=
Initial suggestion is a Lid Switch:
Dec 14, 2010 | Kenmore 15864/15862 Top Load Washer
I have a Kenmore model # 13212200 it will agitate but will not drain or go to the rinse or spin cylces. I have tried by closing the lid as well when trying to got the next cylce. Is it my control panel?
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11013212200/0582/0153200?pathTaken=
Oct 26, 2010 | Kenmore Washing Machines
Water draining problem
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20702991&pathTaken=partSearch
Jun 13, 2010 | Kenmore 27632 Top Load Washer
Water won't pump out I have no spin cycle in kenmore top load washer
Jun 03, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Machine agitates but wont drain
May 30, 2010 | Kenmore 22422 Top Load Washer
My kenmore series 80 wont drain it agitates but stops when it is time to drain md#23822100 sr#CM3908062
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.23822100&pathTaken=partSearch
I'm assuming that it will neither drain NOR spin.
If it works, the Lid Switch is a relatively inexpensive part.
Apr 19, 2010 | Kenmore Washing Machines
WASHER FILL, NO PROBLEMS AGITATING, WHEN TIME
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
This is the Whirlpool PDF on installation and maintenance of direct drive washers. See the section on how to bypass the lid switch and on the transmission.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
Following is an illustrated description of how to remove the cabinet on Kenmore / Whirlpool top load direct drive washers.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Since it won't drain, the problem points to the lid switch. You already have the cabinet off so replacing the switch isn't too difficult.
The Sears site has the Sears (and probably Whirlpool) part number.
Oct 08, 2009 | Washing Machines
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
My kenmore elite oasis runs fine but wont go through spin cycle
Jan 13, 2009 | Kenmore 23822 Top Load Washer
Kenmore 24932 Top Load Washer Logo
180 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
