Question about Kenmore Dryers
I have a 90 series gas dryer. The dryer turns on, but no heat is generated. I cleaned out the vent. What could be the problem? thanks.
  • Kenmore Master
  • 8,220 Answers
Check ignitor for continuityI have a 90 series gas dryer. The dryer turns on, - 65f9150.jpg
If both are good and the ignitorI have a 90 series gas dryer. The dryer turns on, - 90af599.jpgome on them check the duct fusece1b034.jpg5d6a20d.jpg
Old school manual and more HERE
Posted on Sep 29, 2010
Where to find fuses. My dryer is not heating up.
Does your dryer have power? If yes, then check (1) the flow of air outside the house from your dryer tube and (2) your circuit breaker panel for each circuit in the house (I've not seen fuses/breakers built into dryers -- though that could change). Then check (3) your heating element, (4) thermostat, (5) high-temp thermal cutoff switch, and (6) for debris in the air flow path to / from from the centrifugal fan.
Here are 3 resources that helped me with my Kenmore Series 90 Dryer:
No Heat? - http://chris-doityourselfrepair.blogspot.com/2011/10/kenmore-90-series-model-110-clothes.html
Looking Inside My Dryer - http://chris-doityourselfrepair.blogspot.com/search/label/Disassembling%20Kenmore%20Dryer%2090%20Series
Exterior Exhaust Duct - http://chris-doityourselfrepair.blogspot.com/2013/08/cleaning-out-and-replacing-exhaust-duct.html
Oct 10, 2014 | Kenmore Dryers
I have a Kenmore 600 series gas dryer it has stopped heating. When you first turn it on it heats right up like it should then after jus a min the heat stops and it wont blow any more heat what could it be?
The majority of the time this problem is because the dryer vent is plugged. Remove the vent hose or pipe and clean it out, removing all lint buildup. Check the damper door where the dryer vents outside for obstruction. Make sure your lint filter and the area it goes into are clean as well. This will fix the problem 9 times out of 10.
Aug 02, 2013 | Whirlpool LGR3624JQ Gas Dryer
Have a Kenmore 90 series gas dryer model 110. 72922188 that won't come up to heat and dry the clothes...Popped the front, cleaned all the lint areas, checked the cycle knobs for proper setting, tub/ motor...
aslong as the ignitor is glowing red then a click frome the flame switch and lights the burner tube and continues to repeat this over then dryer is ok ...... take venting off back of dryer and do a test load .... that will solve if it's a venting problem... if dryer dryes clothes with venting off back of dryer then it is a venting problem ..... from vent tube to out side exhaust... if dryer dosent dry clothes with vent off then u need to replace the gas coils black cylinders on top of gas valve... cost around $30.00 and very easy to installl 2 phillips screws in bracket cap on top of the coils slide off and replace one at a time there is a large coil and small coil and they both come in same kit and need to go back in the same spot they came off in ....part numbers..# 306106 306105 or recheck your model number off dryer data plate and order off sears.com
Jan 28, 2011 | Kenmore Dryers
Kenmore 90 Plus Series Gas Dryer that will not heat
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at t http://appliancehelponline.com/gdryertroublevideo.html his will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Jul 01, 2010 | Dryers
Kenmore 90 Series Gas Dryer No Heat. Have replaced both Coil Valves, and thermal fuse. Gas ignites, runs for 15 seconds then turns off. All ducting is clean. I bypassed thermostate same problem. I also...
try taking off the vent line and run it,also did you remove and clean out the duct that the lint filter slides into,send model number,sounds like a venting problem or a thermostat problem,take out the thermostat and see if there's any lint or junk stuck on it
Feb 19, 2010 | Kenmore Dryers
Hello, My Kenmore 70 serie (model 110.72712101), will not heat up. Cleaned filter and exhaust vent. Any suggestions will be of great help. Thanks!
The ignitor is probably bad not aloowing the gas valve to come on and ignite the gas to heat the dryer. The ignitor is a flat bimetallic element that heats up when the dryer is turned on to light the burner to heat the dryer. It is usually located in the lower left section of the dryer near the burner assembly. It has two wires usually white going to it with a plug in connector on the end.
Jan 18, 2010 | Kenmore 73952 Gas Dryer
Kenmore 90 Series Gas Dryer that drys for 10 mins & shuts off...
Check the vent pipe going to the outside of the house, including the vent louver, to make sure the pipe is not partially or fully clogged with lint.
Your symptoms are a classic description of reduced or no airflow from the dryer.
Jan 09, 2009 | Kenmore 62802 Electric Dryer
Kenmore 90 Series Dryer will not DRY
first check the vent outside to see if it is blowing air out strong, then check for heat.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Kenmore Dryer - Ignitor will not fire
thanks for the question The problem is with a thermal fuse located at the back remove back panel the thermal fuse is located on the air vent 2 small wires go to it replace it . And check the venting make sure the vent is clean because this termal fuse will break down because of poor venting Thanks for the question The appliance doc
May 12, 2008 | Kenmore 63942 Dryer
Kenmore 90 series gas dryer, NO HEAT!!!
Hi, if you get no glow on the ignitor and you have voltage its the little white two terminal fuse on the exhaust side that has no continuity on the series 80 it has 2 blue wires, these complete the circuit for both gas valves and the ignitor. If you have an ohm meter it you will find it rite away. Hope this helps.
Mar 21, 2008 | Dryers
Dryers Logo
43 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
