Question about Denon DHT500SD System
Denon DHT-500SD - DVDs wont load
Hi
I've had this system for over 3 yrs - no problems until this week. It displays No Disc when you insert any DVD after it attempts to load it. I've un plugged everything and checked connections. I've cleaned the DVDs - still no joy Help Please !!
  • victor_knott Sep 21, 2008
    Similar problem - but it says 'loading' permanently
  • callumc Oct 07, 2008
    When loading any DVD the error message NO Disc appears and machine "whirrs" as it tries to load. Have turned everything off and checked connections with no joy. Everything else functions normally.
    Sergeant:
  • 395 Answers
The problem may be two fold
1 the optical pickup assembly's lens may be dirty and needs to be cleaned (donot use any liquid to clean the lens just a soft cotton swab will do)
2 the optical pickup assembly has failed and can no longer read discs (if the laser or sensors inside the optic fail it is "blind" and can not "see" the disc)
start with the cleaning.
Posted on May 26, 2008
I had this prob. Pick up a DVD lens cleaner disc , run it thru and you will sort this out. cheers. Ian
Posted on Feb 12, 2009
Dvd whirring noise
All the disks I've tried have, although it's only been 3 or 4 (both home-made and original). It sounds like the motor and/or the head moving around. Next week I'll go to the store I got it from and bring a DVD is particularly noisey in the drive, and try it in their floor model to see if it's this particular unit or the model in general.
Parts Of BMW.
May 30, 2012 | Denon Televison & Video
1815 denon won't load dvds but will load cds
Hi...
Buy a DVD cleaner disk ( radio shack or walmart or best buy)
Run it a couple times
Aug 26, 2010 | Denon DVM-1815 Multi-disc DVD Player
"PROTECT" appears on my DENON DHT-500SD
Sounds like a speaker wire is shorting against either another speaker wire or something metallic. Check your speaker wires to make sure they're not shorting (touching). If that doesn't work, I'd take it to a repair facility. Good luck!
Feb 16, 2010 | Denon DHT500SD System
Denon DHT-500SD system and want what is on TV to come through 500
You could try the optical route. You should be able to use the analog RCA audio outputs of the TV to the analog TV or VCR audio inputs of the receiver as well. Select the appropriate input on the receiver and you should have TV audio.
Jan 02, 2010 | Denon DHT500SD System
Disc error message when load DVD
Are you loading to play or to record?
Commercial DVDs should play.
DVDs for recording may not be recognized by your drive. First make sure that the disc is blank. You must insert a blank disc of the proper format: DVD-R or RW, DVD+R or RW. Even with the proper format, some brands may not behave the same way as other brands.
Dec 24, 2008 | JVC XV-N320 DVD Player
Denon dht-500sd Cinema Systems is say no disk when there is a disk in the drive someone please help
That meen it can not read or detected the disc inside, usually is the laser assembly or spindle motor defective or simply got dust on the lens you need qualifier Tech to open and clean if it is success other wise it need to replace a new DVD deck assembly
I hope that geve you some ideas
Dec 07, 2008 | Televison & Video
No sound/test tone front front right channel
1-make a reset to your system.2-repeat your speaker setup.3-confirm that you assign your sysem for 5 chanell surround system.-4-change the cables between left and right front speakers if the trouble go to left channel you will have a problem in receiver itself-if the problem exict you will have a problem in speaker itself(cable or speaker)
Sep 30, 2008 | Audio Players & Recorders
Denon 3910 won't load some dvds/cds and vibrates while trying.."disc error"!
I have the Denon 2900 (about 4 years of use) and until recently, suffered from the same (growing) problem. CD's were very difficult to start/read. I recently found advice which I tried and was succesful with. It was manually cleaning the laserlens. I took away the outer housing by unscrewing all off the on top (6), side (4) and the back (2) bolts. After that I took out the top plate of the laserunit which took two very little screws taking out. Now you are looking at the cd-tray with the lens. Take a very soft and clean cloth and moisten it a little bit with clean water (be very carefull with the moistening, don't allow any waterdrop to come out of the cloth into the laserlens while cleaning! Carefully clean the lens and dry it with a dry part of the same cloth. Replace the top plate and the outer housing and the player will recognize the discs like it's new again. Good luck! Robert Jan, The Hague the Netherlands
Dec 25, 2007 | Denon DVD-3910 DVD Player
Denon DHT500SD System Logo
533 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
