Question about Poulan 18" Chain Saw Replbar (small Saws)
Poulan pro model 4218 got caught in stump I was trying to cut down. Bar was bent. Went to box store where I bought the saw and bought "POWER CARE" 18A replacement bar and chain, brought it home and installed it. All looks correct, but when I start the engine it runs but does not turn the chain. Ideas?
  • drallim Sep 29, 2010
    Please state your problem that you are having.
  • shub49 Sep 29, 2010
    Have to go to work; will check and advise in the morning.
    Scholar:
  • 71 Answers
Try the easy solution first and post back if this does not solve the problem:
Insure your chain is on the teeth of centrifugal clutch sprocket correctly. It is easy to have it either on the inside of the sprocket or on the outside of the sprocket. If it is not on the sprocket teeth, it will not turn the chain.
Posted on Sep 29, 2010
Chainsaw won't idle- runs fast only
Gently Tighten the carb adjustment screw fully tight then adjust it out 360 (full turn) then again a further 180 ( half a turn) and your idle speed should be set correctly. Let me know how you get on
Oct 02, 2014 | Oregon Poulan/Poulan Pro 10" Chain Saw...
How can i get my poulan pro 4620avhd to idle ?
I have referenced the Poulan Pro 4218 Manual so you can see a similar troubleshooting guide which should be close to the 4620 version.
Nov 18, 2012 | Poulan Pro Chain Saw 46cc 20"
Where do i find model no. on my 4218 avx 42cc poulan pro chain saw?or is that the model no.
4218 is the model, the key is part of the flywheel, so if the key has sheared it will require a new flywheel.
Mar 17, 2012 | Poulan Garden
I bought a used Poulan Pro 3450 and have been surprised by its performance. It came with a 20" bar and I was wondering what the largest bar I can put on the power head is.
hi there maufader
pauly46 here
poulan 3450 think max bar is 24 " have seen modles come out with 22 " bar on std
with 3/8 0.58 chain std but would not recommend any bigger as might burn out clutches
with increased cutting load/ drag
here is web site for parts
http://www.ereplacementparts.com/poulan-3450-gas-chainsaw-parts-c-16962_17147_17763.html
i know its not a poulan pro but is still a poulan 3450 - but model appear to be identical with very minor differences.
cheers hope this helps
May 22, 2011 | Garden
What size chain does the Poulan Pro 4218 use?
It is an 18" chain .The user manual is at http://www.chainsawsdirect.com/manuals/PP_3516_4218_Man.pdf
On page 6 the part numbers for the bar and the chain are shown
Hope this helps .. if so, pls leave feedback, if not - let me know!
Jan 24, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I just bought a Poulan 16'' chain saw with quick adjust chain tensioning. The chain seems to loosen after a short time of use and the chain comes off. Quite disturbing.
1. It is common for a new chain to stretch. that is probably what occurred
2. I'd hold the tip of the bar 2-3" above a stump or even a news paper, rev it up for a few seconds and look for a line of bar oil. If none is visible your bar oil reservoir is empty or saw isn't oiling. If you added oil and it's not oiling return it to where you purchased it.
HTH
Lou
Sep 08, 2009 | Poulan Pro Chain Saw 46cc 20"
I would like to go down A bar size our two on my poulan wildthing
I have a Poulan Pro 295 20".  When I bought it I also bought a 16"bar and chain and have been using those since.  They make the saw much easier to handle and are a better match to the available power. The key dimension is from the bar's mounting hole to its end.  At the store look at the normal replacement bar for your 18" saw, and pick out a 16" or even 14" bar with the same dimensions there.  This can be easily seen by laying one bar over the other.
Apr 02, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have a Poulan Pro PP3516AVX chain saw. I used it
Their not the best saws but make sure the nuts holding the bar and cover on are tight after adjusting chain sometimes improper cutting will continue to kick chain off bar.
Mar 15, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan 46cc has very little power
you need to adjust the gas an air on those two little screws on the carburator
Feb 03, 2009 | Poulan Pro Chain Saw 46cc 20"
Bar sprocket smokes, gets hot spot
Sounds like you're not getting enough oil to the chain. Basically you've got an oil pump, pickup and filter involved in getting oil from the resovior to the chain/bar. If you cleaned the obvious area and the chain is not coated with oil, you may have a clog further up (inside) the oil delivery mechanisms. Also, drain the oil from the tank, and see if you can "blow" air through there. With the saw running & pointed down, you should be able to see oil on the ground being slung off the chain, if not, you are not getting enough oil to the chain.
Nov 29, 2008 | Poulan Pro Chain Saw 46cc 20"
Poulan 18" Chain Saw Replbar (small Saws) Logo
75 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
