Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
All air handlers calling for cooling, compressor doesn't come on board reading 00 (normal)
  • Mitsubishi Master
  • 43,501 Answers
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the Mitsubishi line. The manual include both troubleshooting and installation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Posted on Sep 29, 2010
I have a Rheem rpmc-042jaz heat pump (scroll) that has a bad defrost board (47-21517 - 16) The defrost board was bypassed by a service tech to allow cooling but no heating and I'm now trying to install a...
trace the wiring of the reversing valve.. its an electromagnetic relay in the middle of a cluster of tubing near the compressor. depending on its normal state when un-powered (normal heat or normal cool) the tech may have simply disconnected the relay (normal cool), or connected it directly to the call-for-cool line (typically yellow) (normal heat) regardless of heating or cooling, the compressor always runs the same direction
Oct 31, 2013 | Heating & Cooling
Unit exactly one year old. Was interruped by lightning strike last night. Afterwards air handler blowing, but not cooling? Turned unit of at temostat, waited a few minutes, turned back on and unit (both...
Marion, if there was a lightning strike and then a power surge when the power came back ON, I don't doubt what the servicemen had to say. The age of the unit plays no role in it, when something like this happens. Power surges can be killers to electrical appliances. That's why it always wise to turn the unit off during a power outage. Just ask anyone who was in Irene's path a couple of weeks ago. Power went out for days & weeks for some, when it came back ON, electrical appliances were damaged or ruined or started house fires.
Hope this helped you and thanks for choosing FixYa.
Sep 19, 2011 | Amana Heating & Cooling
Tempstar air handler model #nfcp2400c2 with 5kw heat strip someone has installed a contactor on inside and taken the control board out is there anyway to bypass board to use as a straight cooling only...
Yes, you need a tstat, a contactor, and a transformer.
Contactor runs the fan, transformer sends the low voltage to the tstat. Tstat turns on contactor for fan and compressor for cooling
May 17, 2011 | ICP Vortex Fan Timer Control Board For Air...
A Trane 20 Ton roof mount A/C unit model # YCD241B4L0DD does not work... Test sequence works OK through it's steps but after power off reset jumpering TB1 to call for max cooling 1+2 does not...
Hi
Please check the bellow link to diagnose what could be wrong with your AC…
http://www.inspectapedia.com/aircond/aircond1123.htm
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Jul 24, 2010 | Heating & Cooling
We have 2. LA125HV w/ 1 condensing 1. air handler
I could not find a "fault code" list for the LA125HV but for thier Multi Split Units LG lists code CH7 (C7) as "Indoor Unit is Set in Different Cool/Heat Operation Mode." So maybe your air-handler tihinks it's in Heat mode will the compressor is in Cool mode, or vice-versa....
Dec 07, 2009 | LG LA125HV Split System Air Conditioner
Heat pump not cooling after wiring damage repaired.
Do you have the model number? This would help find the code
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 10, 2009 | American Standard Heating & Cooling
Outside compressor off while handler on inside, no cooling
CHECK WIRING MAKING SURE NOTHING FELL OFF BUT IF NOT REPLACE THE MOTOR BEFORE YOU BLOW YOUR COMPRESSOR
Jun 20, 2009 | Heating & Cooling
Central air and heating, not cooling
Need to have checked out by a diagnostic ac man.
Aug 08, 2008 | Haier Energy Star ESA3183 Air Conditioner
Mitsubishi MSH12TH heat pump air handler 110v
Wireing this type AC with the wrong voltage, will damage more than the circuit boards. I think the installer wil need to be responsible for the damage he created. The factory will also try to get out of the replacement because of the installers lack of know how.
Oct 20, 2007 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
175 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
