Question about GE Profile Harmony DPGT750GC Gas Dryer
I need to replace the switch start on a GE DSXH43GV1WW Dryer and Im having a hard time removing the front panel to access the switch start, I took of three knobs in the front off and the fourth big knob which controls time looks like it stays on, the top of the dryer is off and I dont see anything holding the front panel, any suggestions?
  • drallim Sep 29, 2010
    Look inside the corners for several screws that hold the upper front on, then lift up the panel to remove. If everything is spot welded, then the entire cabinet likely has to be removed as one piece. Hope this helps!
3 Suggested Answers
  • 1015 Answers
SOURCE: my GE Dryer, model number Model# DSXH43GV1WW
First make sure that the gas valve is on. Then verify that the gas connector is not kinked or restricted. then remove the connector at the back of the dryer and make sure there is gas pressure. Then visually inspect the pipe at the back of the dryer. Use a flashlight to inspect inside the pipe and make sure there is no debris inside the pipe that could restrict gas flow. On this dryer there is no removable burner door cover on the front or inspection window so you will need to remove the back panel of the dryer. Once the panel is removed you can turn on the dryer. You should first hear a click sound. That is the first gas solenoid valve opening. Then the igniter should start to glow. Once the igniter reaches 2200 degrees the secondary gas solenoid valve should click and the burner will come on. If you do not hear a click when the dryer is first turned on you will need test the first gas solenoid valve. Make sure it is getting voltage with a fluke meter. You can also touch a piece of metal to the top of the valve and the top should be magnetized when active. If you hear the first click but no igniter glow then verify the igniter is getting voltage and test the igniter with a fluke meter. You will need to test the ohms and most should be 500 to 700 ohms. If the igniter does not get a good reading or none it is probably defective and needs replacement. Usually most places that sell appliance parts will test the igniter for free. Just because the igniter glows does not mean that it is good. It can glow but not reach the 2200 degrees needed for the proper operation. Now if the igniter is good and you hear a second click then there might be a restriction somewhere in the gas line between the solenoids or the gas orfice at the burner. The sensor Gort was talking about is the flame rectification sensor and can detect the flame. It is rare for this to be faulty but not impossible. If you get flame for a couple seconds and then it shuts off it could be this sensor. Blow the burner assembly and this area off with compressed air and lint can block the sensor's ability to detect the burner flame. Also I believe your dryer has a larger fan blower than standard dryers. If this blower motor is not working the rest of the system will not come on. make sure the assist fan is working and that the vacuum switch is working and not stuck. Also check the vacuum line is not disconnected or restricted. And always remember that there are exposed power connections inside the dryer that could shock you and cause injury. use caution and if you do not feel comfortable working on this you might want to call a professional.
Posted on Sep 25, 2009
TheMobilian
  • 8220 Answers
SOURCE: GE Dryer will not stay
Does the drum turn? when you press the button? Some of these have a broken belt switch. If the belt is broken the motor will run but then shut down as soon as you let off the start switch. I looked up your model and yours does have this interlock switch (broken belt switch) It might be the switch or a broken belt. themobilian_229.jpgthemobilian_230.jpgthemobilian_231.jpgthemobilian_232.jpgthemobilian_233.jpg
Posted on Nov 22, 2010
How do I remove the lid off of a GE dryer
Try: http://www.appliancerepair.net/clothes-dryer-repair-4.html
They can probably help, especially if you have a reason to take the top off and it is not performing properly.
Apr 01, 2015 | GE Dryers
GE dryer model DCA3BC8776 'Start' knob has come
you should be able to replace the knob from the front of the panel without removing the control panelit has a "D" shaft on the knob and shaft also has a "D" configuration too? right?
Aug 18, 2011 | Major Ge Dryer Timer Knob We1x1263
Hello I have a general electric dryer model DBSR463EG6WW serial number TR775112A and was wondering how do I bypass the start switch because it is broken
please there is no need to start your dryer without the switch. you can easily replace the switch yourself just follow this instructions below to replace your switch. things you will need are philip and hex and nut screwdrivers, putty knife and Replacement "start" switch. then Disconnect the dryer from the electrical outlet. Slide the dryer out from the wall and disconnect the dryer vent from the dryer's back panel.
    1. Loop a piece of string behind the "Start" button and pull forward on the string to pop the knob off the switch's post.
    2. Access the interior of the control panel. Depending on your model of dryer, there are several ways to access the interior of the control panel. On older dryers, there will be an access panel along the back of the control panel that can be removed once all of the retaining screws have been removed. On newer dryers, the control panel is held in place by screws in the front or spring clips. Remove the plastic end caps on the control panel and remove the screws underneath. If your dryer has no end caps, slide a putty knife under the corners of the control panel and lift up on the knife to release the clips. Rotate the control panel toward the rear of the dryer to access the interior.
    3. Unplug the wires from the switch by sliding them off the contact terminals on the switch. Make a note which wire connects to which terminal so you can easily connect them to the new switch.
    4. Press the release tab to unlock the switch and slide it out of its socket. If you have an older dryer, remove the retaining screw to remove the switch. Slide a new switch into the socket and press it down until the release tab locks into place. If you removed a retaining screw, replace the screw. Reconnect the wires.
    5. Rotate the control panel back down on the dryer or replace the rear access panel. Replace the knob and reconnect the dryer vent. Plug the dryer back into the electrical outlet.
Dec 24, 2010 | Dryers
Taking a ge dryer apart to replace worn belt. the dryer works fine with light load but squeeks with medium to heavy load. drying time is fine.
you will need to replace the drum glides near the front of the drum,just behind the door,which will require you to remove the front panel to access the glide unit,there is a gold and a green glide,you will need to get the right one after disassembly
Jan 12, 2010 | GE DWSR483EBWW Electric Dryer
I have a GE DPGT750GC2PL dryer and the drum cracked at the seam? is there a recall for this or am i the 1st? the dryer started to make a thumping noise and when i took it apart i found the drum is coming...
the drum is easy to replace, you need to remove the control panel and the top of the dryer to get the front panel off the dryer. Make any connectors so you know what way to hook them up again just to be safe. After you have all of this apart, relieve the tension on the strap that go's around the drum. Replace the drum and and reinstall everything in reverse. I don't have the link to the repair manual here at work, but I did find it here. Read it over and take you time, it's really not a hard item to replace.
Where are you located, I have a heating problem and if I don't fine the answer to fix it will more then likely toss mine out and could part out the known good parts.
Harry
Oct 24, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
My GE dryer will not always start when is push the
HI. Actually, the door switch will be the next component that you will need to test in this situation.Once you have ruled out the door switch, I would then replace the timer module. The door switch plays a very important part in the operation of the unit. If the switch is weak, or faulty, it will not allow for a complete closed circuit.
The door switch may be accessible without removing the front panel or cabinet. The switch is located in the front panel of the dryer, around the perimeter of the door opening. Inspect the switch to determine if it can be popped out or accessed by removing a fastening screw. If it cannot be accessed from the front, it will be necessary to open the dryer cabinet. When reaching into the dryer be careful of sharp edges on the cabinet and interior supports.
Access varies by model, if your dryer has a lower front panel (kick plate) start there. It should lift up and off or it may be held in place with a few screws or snaps; it may also have a catch at the edges or center gap between the kick panel and main panel. To release the catch, push a putty knife, wrapped with masking tape, into the gap and push back the catch. The next easiest access point is the rear panel. The rear access panel is held in place with several screws along the outer edges. The last resort method of access is the removal of the entire front panel. The front panel supports the front of the drum and so removal is more difficult. Front panel removal varies. In general, access is gained by lifting the top (remove the lint trap screws first), removing the screws that secure the front panel, and detaching the panel from the drum.
Locate the doort switch, it typically has two wires connected to it. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a multimeter to test for continuity. Set the meter to the ohms setting X1. For a two wire switch, touch one probe to each terminal. You should get a reading of infinity. With the probes still in place, press and hold the switch, the reading should change to zero.
If the switch does not test as described, it should be replaced.
Now, if the door switch is ok, and passes the above test, this will lead to the timer.
Oct 22, 2009 | Dryers
My GE Dryer, model number Model# DSXH43GV1WW, isn't heating, but is spinning and blowing air just fine. I understand the response that I should check the: 1. Electronic gas ignitor and; 2. The thermocouple...
there should be an inspection plate on the rear of the unit to remove to inspect the duct assy and if operating you should be able to see or hear if gas valve is opening or the sparking of the ignitor
Sep 25, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
I have a GE Profile dryer. The dryer is squeekly
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Concerning the squeaking sounds. this can be caused by a bad drum belt or a leveling issue as well. more issues will be bad drum support rollers or, a failing bearing assembly in the idler pulley. the blower, baffles and guides will deteriorate as well, causing noise overtime. These are most of the uncommon issue that will cause this issue, but the most common issue will be failed idler pulley bearings. The pulley will tend to squeak very loudly if the bearings are worn.
Access to the idler pulley varies by model, if your dryer has a lower front panel (kick plate) start there. It should lift up and off or it may be held in place with a few screws or snaps; it may also have a catch at the edges or center gap between the kick panel and main panel. To release the catch, push a putty knife, wrapped with masking tape, into the gap and push back the catch. The next easiest access point is the rear panel. The rear access panel is held in place with several screws along the outer edges. The last resort method of access is the removal of the entire front panel. The front panel supports the front of the drum and so removal is more difficult. Front panel removal varies. In general, access is gained by lifting the top (remove the lint trap screws first), removing the screws that secure the front panel, and detaching the panel from the drum.
When reaching into the dryer be careful of sharp edges on the cabinet and interior supports. Reach in to the belt and give it tug. It should be taught and have only a little give. The belt should go under the idler pulley and over the motor pulley. Lift the idler pulley toward the motor to relieve tension on the belt and remove it from the motor pulley.
Turn the idler pulley wheel, it should turn smoothly, quietly and without any wobble. Inspect it for cracks or uneven wear. If the idler pulley does not maintain proper tension or is damaged it should be replaced. Depending upon your model, the entire assembly or just the wheel or bearing may be replaced.
Jul 30, 2009 | GE Profile Harmony DPGT750EC Electric...
How to get the front panel off GE Profile Harmony
Here's a simple overview of what you have to do:
You actually don't remove the back sir, but that's okay, that's a common misconception for this model dryer. The proper way to disassemble this particular dryer is you start with the top. You have to start with the removal of the control panel, then the top of the dryer. What I would consider the top cover. Then you'll have to remove two plastic brackets. Then you have to remove the front. There's two aluminum brackets in each corner, remove those. Open the door and there'll be two more screws to remove on each side. You have to lift the front just a little and then pull towards you. I forgot to mention, before that part, you'll need to ensure you are disconnecting the electrical wiring. There's almost no chance of connecting the wrong ones even if you forget. GE made this part novice proof. Once you get the front removed, you'll see the lint/trap. There's a couple of screws on either side of the aluminum housing. Not much to it. Let me know if there's anything I can clarify further. Have fun!
Mar 31, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
GE Profile Harmony DPGT750GC Gas Dryer Logo
59 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
