Question about American Standard 1041224299 Williamsburg Chrome Tub Shower Faucet
When I pull up the plunger to engage the shower head it does not completely close. Which means that I do not get good water pressure from the shower head. What can I do to fix this?
5 Suggested Answers
  • 68 Answers
SOURCE: low pressure on Delta 1400 series shower head
The Shower Valve is regulated to give only 2.2 gallons a minute. If you have the shower head off test how many seconds to get an approximiate gallon running in the middle hot/cold position. If longer than 30 seconds either the stem in the valve is clogged or the water lines to the valve are too small or kinked.
Phil
Posted on Dec 09, 2008
mpcheeseman1
  • 1400 Answers
SOURCE: took off shower head water barely comming out but
Hello
Is there a water restrictor in the shower head?A small round disc usually white or clear.
This could be clogged.
Next,take a old toothbrush and some comet cleanser and scrub the showerhead holes,this will get any hard water deposits out of the holes.
Posted on Mar 30, 2010
  • 349 Answers
SOURCE: shower head and bathtub faucet both running when showering
Sounds like diverter valve which is your shower handle valve is bad take it apart and check out and replace it if possible because that transfer water to shower head.
Posted on May 05, 2010
packrat1948
  • 528 Answers
SOURCE: I have an american standard kitchen faucet with a
Check the aerator and see if it is getting plug up.
Posted on Feb 08, 2011
American standard single handle shower vavle drips when tub spout is on.
Be sure to pull the plunger all the way up when diverting the water between the the tub and shower if ti keeps giving you a problem it's faulty
Mar 05, 2016 | American Standard Home
Hot water pressure is weak. Shower head isn't clogged. Cold water pressure is good. How do I increase the hot water pressure?
Is the hot water pressure good at other fixtures in the house? I'm guessing your newer valves have a scolding adjustment that is set very low. Check the instructions that came with the valve assembly.
Feb 10, 2016 | Danze & Single Handle Tub And Shower...
I can't get shower head pressure from the outer head of my new grohe freehander.
Everything you installed new. Please chack if not one of the gaskets came in a pipe or a line. I once had a rubber ring almost complete blocking the water flow.
Nov 01, 2014 | Grohe Shower Freehander 27 007 Chrome...
All hooked up dobble cked but water only trickles so ample supply
Make sure the hot water is turned back on. Pressure balancing valves won't work if both cold and hot water is not on. Pull shower head off and test to see how it flows out of the shower arm. If good, clear out shower head. Whenever water is turned off for a time, and then turned back on, restricting shower heads and aerators usually get clogged. In the future, always open up a tub spout before turning water back on. This releases the air and other debris most effectively before testing other fixtures in the house.
Apr 23, 2011 | Moen 3175 Legend One Handle Shower Faucet...
Low water pressure from shower head with the shower head removed
If you have good pressure at the water faucet close to the shower and low at the shower then the shower valve needs rebuilt. If you have low pressure at all then start going down the line toward the water service coming into the house looking for where the low pressure starts in the distribution system and you should be able to isolate the problem.
Feb 08, 2011 | Delta Home
I have extremely low pressure from my Moen Posi-Temp 1222 shower valve, but otherwise it functions well. Should I replace the posi-temp cartrige?
Hi Ken--
Positemp cartdiges should deliver years of maintenance free operation. Usually, clogs develope downstream from the cartridge. If the cartridge still works well, that is, if it still pulls and turns freely, and the rest of the house has decent water pressure, check your shower head. Remove the head and test the water pressure. If the water flows better without it, you may have a clogged shower head. Over time, rust and scale can build up inside the shower head and block what would otherwise be decent water pressure. If a visual inspection does not yield any visible blockage, you can consider cleaning the head by soaking it in a calcium removing solution such as CLR. This often helps, but my preference is to replace the shower head completely.
--Hope this helps.
Oct 06, 2010 | Moen Plumbing
When I turn the faucet to hot ,water comes out of the shower without pulling the shower pullup
either to much water pressure to unit or pull up is clogging /damaged if u have separate valves on water supply start at half way and work ur way open or close till water doesnt come out of shower head
Feb 15, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Water only comes out shower head, won't come back out faucet. The shower plunger only puts water out shower head, not out faucet.
sounds like the diverter is jamed. it may be in the spout or a button in the escheuchon. if spout try to unjam the pull up knob or the pull down ring. if in the escheuchon remove part and replace.
Jul 12, 2009 | Delta & Single Handle Shower Faucet
Leaking shower head
Check the spout pull knob . Debris can be keeping it from closing completely.
Jul 05, 2009 | Moen & One Handle Tub & Shower Faucet
Bathtub will not drain...
remove the two screws on the overflow,thats where the lever is, then pull out the plunger. clean it off and turn the water on and let it run a minute so it can flush out any grime or hair that may be down there. If you look at the linkage on the plunger it will have a threaded piece. unscrew that a couple of turns to lengthen the linkage. dont lengthen it to much,only 2 or 3 turns should do. reinstall plunger and fill tub, if it is still giving you problems try adjusting it again. If all else fails then goto a plumbing store and buy a new drain, you can buy just the plunger,linkage, and handle.
Mar 24, 2009 | Plumb Shop Alsons #PSB2510 Chrome...
American Standard 1041224299 Williamsburg Chrome Tub  Shower Faucet Logo
159 people viewed this question
Top American Standard Plumbing Experts
Donni Steen
john h
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
