Question about Ovens
Viking gas oven wont turn on - Ovens
  • Ovens Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Sep 29, 2010
I'm looking at a used Viking double wall oven in gas-Viking Vgd0271SS.. Does anyone know anything about it?
This is a high end wall oven. Common break downs are oven ignitors, all ovens fo that though. Life span for an igniter is 5 to 10 years. Viking is rare to have problems..
Dec 07, 2014 | Ovens
Viking gas oven/broiler won't light
send me a model and serial and I will try to send you in a direction on how to troubleshoot. need more info.
Feb 24, 2018 | Viking Ovens
My Viking DESO 101 oven wont turn off
Yes then controler has gone bad for the oven , you can locate the part on line and have it shipped right to your house or give me the model and serial number and make and i will locate it for you later today
Dec 08, 2011 | Viking DESO101 Oven
My Viking oven will not lite, the igniter glows, but it will not lite. I have to turn on the 4 stove top burners and then it will lite. Also, when the oven reaches temperature and the therastat shuts it...
That sounds like you have too high of gas pressure which keeps the oven gas valve from opening...turning on the burners lowers the gas pressure enough to allow the gas valve to open. this is a saftey feature on many gas valves.
To stop that you will need to install a gas pressure regulator which will hold back the gas pressure so the valve can open.
Here is a tip that I wrote about regulators and them failing on the low side, but it will give you and idea what I am talking about and what you need to install in the line to your range.
http://www.fixya.com/support/r5849793-propane_lp_or_natural_gas_regulator
heatman101
Apr 22, 2011 | Viking 27" Professional Select Built-in...
On my viking oven i get a FO on the panel. The oven wont cut on.
hi
f0 error is either an E.C.R. (electronic range control) or that it is the keypad and it would probly be about 300 buuucks to fix
Jan 09, 2011 | Viking VGS0166 Stainless Steel Gas Single...
I have a Viking gas single oven with four burners. The burners work fine but the oven won't fire up. I smell gass an I see a glow under the oven but no heat. But if I turn it to broil I get some heat but...
I had the same problem with the single oven, It the voltage feeding the oven, it like to be 120 or above if it drops below 120 then this problem occurs. I had ever thing checked, gas pressure, and the oven. Electrician installed a voltage regulator on that circuit.
Dec 30, 2010 | Viking Ovens
Viking gas oven will not heat up
Oven not Working or
Oven not Heating
Oven Problems
heatman101
Dec 10, 2010 | Viking Ovens
Have a viking professional oven and it takes too
A weak oven ignitor will cause this problem. even though it eventually lights the temp has dropped considerably so you don't get consistent temp. turn the oven on and listen for the burner to light. should light within about 2 minutes. if not replace oven ignitor(s)
May 20, 2010 | Viking 27" Professional Select Built-in...
Slow and uneven ignition on the oven burners that causes the oven to take hours to preheat
MOST OF THE TIME THIS IS CAUSED BY A WEAK IGNITOR.WHEN THE IGNITOR IS WEAK IT WONT PULL ENOUGH CURRENT THROUGH THE GAS VALVE TO OPEN IT UP.SOMETIMES IT WILL OPEN ONLY PARTWAY .GOOD LUCK!
ERIC
Jan 23, 2010 | Viking Ovens
VDGO viking gas oven upper won't heat
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
Aug 16, 2009 | Ovens
Ovens Logo
61 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
