Question about Procom (177653) Utility Heater
Pro-Com Gas Heater Some times the pilot light goes out, flame burns a nice blue color. im afraid to go to sleep with hreater on
    Scholar:
  • 146 Answers
Many times the thermocouple will build up so corrosion where it seats into the gas valve. This will cause the heater to just go out at random time. When the pilot goes out it will turn the gas valve off so no gas will escape from the valve.
Try cleaning the end of the thermocouple and see it that takes care of your problem.
Posted on Oct 01, 2010
Pilot light blows out while heater gets hot. Mr Heater 30000 butu ventless propane wall heater.
call a gas fitter for the repair
could be a freezing of the gas because of a blockage that is restricting gas flow
gas is not a diy repair
Dec 31, 2016 | Blue Flame Heating & Cooling
My wall heater is a williams gas wall heater and I just had a question is the pilot always suspose to be lit the main is not lit but when it is off there Is still a flame that's on Ithink its the pilot is...
All gas appliances have a constant on pilot light.This keeps you from having to light it everytime it goes on. The pilot flame is small, and usually mostly blue in color. If there is any yellow or orange color in the flame then the jet is dirty, which can cause a malfunction ( just thinking this could be handy to know!).
Thanks for using Fixya!!
Nov 09, 2013 | Heating & Cooling
The pilot won't stay lit on gas hot water tank.
Make sure thermocouple tip is seated inside the burner flame.
Make sure thermocouple is not overtightened. Finger-tight + 1/4 turn.
If the pilot lights, then ECO energy cut off is not tripped, but gas control valve might be bad.
Check color of pilot flame: it should be strong and clear blue.
If pilot flame is weak, or color of flame is yellow-orange: Clean pilot orifice and burner and combustion parts on yearly basis.
Clean air intake screen if applicable.
Increase air supply to water heater. Open a window and see what happens.
Check for adequate draft going up chimney using match under vent hood to see if smoke drafts immediately upwards.
Bleed air out of gas line.
Check gas pressure.
Open following links for troubleshoot resources:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Pilot-outage-troubleshooting.pdf
http://waterheatertimer.org/pdf/Vent-spillage-test-atmospheric-gas-water-heater.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Sep 21, 2011 | Water Heaters
Kenmore Water heater, Model # 153.339462, Pilot lights, burner burns for approx. 10 - 15 minutes then both go out. after which it is more difficult to light the pilot. I need ideas please
Clean combustion parts, clean air intake, get more air to water heater and see if problem continues.
Look at color of burner flame and pilot flame: if flame has yellow-and-orange instead of clear blue flame, then combustion parts need cleaning.
Pilot and burner problems can be caused by bad thermocouple, thermocouple not sitting in flame, weak pilot flame due to dirty tube or low gas pressure, air in gas line, no draft up vent, backdraft coming down vent, dirty combustion parts, clogged air intake, insufficient air, insufficient air quality, hot attic, bad gas control valve, etc.
Open following link for pdf resources, and illustrations for cleaning combustion parts, and some service manuals:
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 03, 2011 | Water Heaters
Jandy LG250N pilot won't stay on after releasing switch on gas valve. Main switch on unit is off. I am able to keep pilot flame on for one minute by depressing switch but pilot always goes out after...
Thank you for posting your question here on Fixya.com.
No, the pilot generator or the pilot head itself is the issue. You need a good, solid blue flame across the generator to get enough power to hold the switch open when you let go of the knob. If the pilot flame is week or not aimed across the generator it will not stay lit.
If it is but the generator is old and weak, it will go out as well. If you can see the pilot flame and it is a nice blue color, replace the generator. If it is not, disassemble the pilot and either clean it out or replace it.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Aug 06, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
Set on pilot to lite heater. Once i release valve pilot goes off. This happened several times.
the pilot flame should sweep about 3/8" to 1/2" of the thermocouple. if this is happening then your thermocouple is bad and need to be replaced. pilot should be blue in color and be a sharp flame not lazy and yellow tipped
Jan 06, 2011 | Williams 3501922 (NG) Gas Compact Heater
On my gas fireplace, the pilot light used to burn blue. Now it's burning more of an orange color. How do I fix it?
needs blowing out remove pilot tube from pilot remove injector and clean it out then replace it all test joint with soapy water to check for leaks
Jan 21, 2010 | Vanguard International Blue Flame - Medium...
Pilot light flame is mostly yellow. LP gas
Thr thing you need to do is take the pilot assembly all apart and blow the dust and dirt out of it.
After burning for many, many hours the air that is move up through the pilot assembly leaves dust and dirt which plugs off a bit of the air and makes the flame run rich. Meaning that it does not get enough air mixed in for complete combustion.
When you clean it you will see the dirt and dust com out of it.
Reassemble carefully just as you took it apart and it will be back to working great again!!
I hope that this will help you to solve your problem!
Heatman101
Dec 23, 2009 | Blue Flame Charmglow 30K BTU NG Vent Free ...
Pilot light will not stay on when egnition switched is released!
the little copper tube that sits in the pilot flame is faulty. this is called a flame sensor. replace this and you should have no problems
Dec 03, 2007 | Empire ECS HB06M HearthRite Heater
Pilot light seems to high
there may be an adjustment screw for pilot height. you'll have to look at the valve. a pilot should have an inner cone of greenish blue color and the surrounding flame should be a deep blue no yellow or orange tips. the pilot burns pure fuel no air. the main valve does mix air with the gas in order to burn.
Oct 24, 2007 | Procom ML300EBC Heater
Procom (177653) Utility Heater Logo
1,059 people viewed this question
Top Procom Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
john h
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
