Question about Goldstar DH2510A Dehumidifier
Dehumidifier freezes up within 10 mins of run time. does not matter where the temp is set at.
  • Goldstar Master
  • 43,501 Answers
The unit is low on charge...
Here is a tip that I wrote that will help you understand why and what you can do with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Posted on Sep 29, 2010
DEHUMIDIFIER BOTTOM 2 COILS FREEZING UP AFTER 45 MINUTES ON ,NO DUST ON EVAPARATOR OR CONDENSER TOOK APART BLOWED CLEAN
It shouldn't run continuously for 45 minutes at steady state.
Choose a different setting so that it goes off and on, running no more than 5-10 minutes at a time.
If you are turning it on for the first time in a very humid environment you may want to approach optimal humidity slowly. But once there, it should cycle on and off and not freeze up.
Mar 29, 2017 | Dehumidifiers
UNIT RUNS AND IT GETS VERY COLD WITHIN A MINUTE OF TURNING IT ON. SET ON 4 OR 5 AT ALL TIMES BUT THE WATER WILL NOT DESPENSE TO THE BUCKET.
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
heatman101
Jun 07, 2011 | Dehumidifiers
My dehumidifier stops working after the water container is only about 1/10 full. This has been progressive, until now when it stops within a really short time. ???
Find the switch that reads the container ... bend the feeler gague a little until you find a setting that works for you ... beter yet ... attach a hose to the catch pail and run it to a drain.
Sep 13, 2010 | GE Dehumidifiers
What are the settings (humidity)from 40 upwards on my micromark ? . Is the lower setting to take out most moisture ? Thank You
40 is 40% humidity in room - that's really dry.
For moist area you usually want 50 or 60%.
Dehumidifiers are for damp areas. If temp ouside is below freezing, inside house is probably already too low.
Dec 01, 2009 | Dehumidifiers
Cycles every 3 minutes
It may be in a basement that is to cool. Unless this is a special low temp dehumid it needs to be in the upper 60's to work correctly. Also a 50 pint is for a pretty good size area, if it is in a small area or if the temp is to cool in the basement it is in it will freeze up and cycle off. 3 min is awfull quick though. It may be low on freon also. Just a couple things to think about.
Jun 20, 2009 | Whirlpool AD50USS Dehumidifier
Ice forming on the coils of my Crosley Conservator dehumidifier
Dehumidifiers2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
Jan 09, 2009 | Frigidaire FDL25P1 Dehumidifier
Fedders Dehumidifier
ALL DEHUMIDIFIERS REQUIRE ROOM TEMPS TO BE AT LEAST 65 DEGREES AND A HUMIDITY OF AT LEAST 50 % TO OPERATE PROPERLY. ANYTHING LESS AND IT MAY FREEZE THE EVAPORATOR COILS. EVAPORATOR COILS WILL ALSO FREEZE IF THE COILS ARE DIRTY AND HAVE RESTRICTED AIR FLOW.TRY TAKING THE COVER OFF OF THE UNIT AND CLEANING BOTH SETS OF COILS INSIDE. THEY ARE COPPER OR ALUMINUM WITH FINS ON THEM.
ALSO CHECK THE FAN TO BE SURE IT IS RUNNING.
THAT WILL CAUSE AN OVERHEATING CONDITION AND WILL SHUT DOWN THE COMPRESSOR ALSO.
Jan 13, 2008 | Dehumidifiers
Maytag M7DH45B2A freezing problem
Is this a humidifier or dehumidifier?
Nov 15, 2007 | Maytag M7DH45B2A Dehumidifier
Goldstar DH2510A Dehumidifier Logo
137 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Michael Youngman
Michael Youngman
Jerry Greenberg
Jerry Greenberg
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
