Question about Dell 1710 Laser Printer
I have two 1710n dell printers that when they print, the lines ar curved and non of the words are in a straight row
    Scholar:
  • 78 Answers
If both of the printers have seperate toner and drum cartridges, then it is probably a feed roller issue ( one side is pulling the paper more than the other, causing a curved line ). One trick to try would be to print a page, and pull the power cord halfway through the print. Open the printer and remove the paper and drum and toner and look on the drum. If the latent text is curved on the drum, Then replace both. It is odd that you have two printers that are having the same issue though, especially if you have two drum and toner units. Also, check to make sure that the paper is seated properly in the paper tray, if there is too much play around the paper, the printer may not feed the paper properly. With physical access to the printers, a tech should be able to figure out the problem fairly quickly.
Posted on Sep 29, 2010
Dell 1710n need cd
Hello you can download the installation software here:
http://www.dell.com/support/drivers/us/en/04/Product/dell-1710n
Please select your windows system.
Remove previous installed programs, before you install the new software.
The setup for the static ip, you have to select this under the install of the printer program.
Good luck
Feb 01, 2013 | Dell 1710n Laser Printer
The printer cant print it keeps showing "!" or
The blinking exclamation point means that the cover to the printer is not closed all the way. Try opening and closing the cover to get rid of this error. If there is another picture like an ink drop or a sun that is also blinking at the same time then the error can mean something different.
Here is a link to your manual for your printer that includes troubleshooting erorr codes:
http://support.dell.com/support/edocs/systems/1710n/en/om/1710_en.pdf
Oct 14, 2011 | Dell 1710n Laser Printer
Hp 1710n printer had a paper jam, I fixed it but it still says it has a parer jam and won't print no matter what I do.
Try unplugging the printer from the power supply WHILE IT IS SWITCHED ON. Then disconnect the data cable. Now reconnect the power cable, followed by the data cable.
This will work for several problems but is not guaranteed.
Jan 04, 2011 | Dell 1710n Laser Printer
Dell printer 1710 n .
In Control Panel - Printers, Right-click the Dell 1710N and remove check for Offline.
Jun 12, 2009 | Dell 1710n Laser Printer
Help
There is no setting on the 1710 printer to clear the error of a non Dell branded toner being inserted. Some higher end Dell printers do have a setting for Non-Dell branded toner. Not all Dell printers have this setting. Resetting the drum count will have no effect on a non dell branded toner error.
Nov 07, 2008 | Dell 1710n Laser Printer
Reset page counter
Try to unplug your printer and leave it for 1 to 2 hours.
Feb 27, 2008 | Dell 1710n Laser Printer
Dell 1700n printer
Print out about ten or more sheets and see if it clears up.
Jun 27, 2007 | Dell 1710n Laser Printer
Dell 1710n printers hang
Try using the Lexmark Print Server instead of the generic print server (if you use a Windows Server to share the printers). Also a new driver V2.0 was just released. Additionaly you can try to set 100 full duplex, but this is complex and has to be done at the printer, pressing a serie of buttons. These printers are crap, we have constant problems with them.
Mar 27, 2007 | Dell 1710n Laser Printer
1710n Printer - poor print quality
You need to inspect your drum unit as well. If you can line up the marks on your page with the drum then you will need to replace the drum unit. If you donot find any problem with the drum unit then check the fuser unit on the back of the printer. Be very careful when checking the fuser since it is EXTREMELY hot. Good Luck
Mar 06, 2007 | Dell 1710n Laser Printer
Dell 1710 Laser Printer Logo
65 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
