What are the symptoms of defective hard disk on laptop
  • 64 Answers
It doesn't boot
Posted on Sep 29, 2010
Setting up hard drive to usb connection
Either:
* the USB cable is defective;
* the USB-to-SATA interface is defective;
* the SATA disk-drive is defective;
* the power-supply to the disk-drive is defective;
* the parts are _not_ "defective", they just are incorrectly connected.
Try a different USB cable.
Try connecting the disk-drive as a "slave" drive into a desktop computer that supports SATA, to see if the drive itself is OK.
Use a multimeter to measure the voltage/amperage emitting from the power-adapter.
Do you hear the disk-drive spinning?
Does it produce any heat, when it is spinning?
Apr 23, 2010 | Toshiba Satellite A100-S8111TD Notebook
Screen
I assume your computer boots up, the hard disk spins and the hard disk LED light flashes.
If so then you may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 11, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
500 GB Fantom Drive not recognized on either of my Macs. Tried Firewire and usb; blinking light turns to steady red.Worked fine for about 2-3 years.
The symptoms don't look too good. Looks like the host controller is querying the hard disk (blink) and not liking the answer - or lack thereof (red).
It looks like the internal disk is defective. Sometimes the disk can be (possibly partially) recovered by disassembling the enclosure and mounting it in another enclosure or directly inside a compatible desktop PC.
Aug 14, 2009 | Fantom Drives 120 GB Hard Drive
Presario 700 has a blank screen. Started occasionally going to a blank screen, now it stay blank. Will replacing the hard drive correct this problem?
If the laptop appears to boot up and the hard disk is spinning and the hard disk LED is flashing then the hard disk is OK.
Then the fault could be a faulty video cable or connector or CCFL lamp or inverter.
Try reseating the video cable/connector that connects to the motherboard first.
If this doesn't work then to determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 16, 2009 | Compaq Presario 700 470024-192 Notebook
Aspire 6920 after power up, goes to black screen
You could have a defective LCD screen, If the laptop appears to be booting up and running and the hard disk is spinning and the hard disk LED light is flashing but the screen is dark then, to determine if you have a LCD screen or video card problem, read this and follow these instructions.
Check out
www.lcdparts.net
Jun 23, 2009 | Acer Aspire 6920 Notebook PC
Blank display
Check out
www.lcdparts.net
Jun 23, 2009 | Toshiba Satellite M35X-S161 Notebook
Compaq V3424au that has a blank screen on startup with all lights
Check out
www.lcdparts.net
Jun 23, 2009 | Compaq Computers & Internet
My screen is dark
You could have a defective LCD screen, If the laptop appears to be running and the hard disk is spinning but the screen is dark then, to determine if you have a LCD screen or video card problem, read this and follow these instructions.
Check out
www.lcdparts.net
Jun 21, 2009 | MSI M670 Notebook
Disk detection On and Off
You could have a partially defective hard drive and could fail permanently at any time.
Try reseating the hard drive and if you manage to get the laptop up and running, I would suggest you back up your data before the hard drive fails.
May 29, 2009 | Dell Vostro A860 Notebook
Display problem
Check out
www.lcdparts.net
Jan 21, 2009 | Sony VAIO VGN-FJ270/B Notebook
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
