Question about Dell E173FP 17" LCD Flat Panel Monitor
Dell e173fp monitor, how to open it correctly?
As I have same basic knowledge i electronics and I suspect the inverter having a problem, I would like to open the monitor (case). But these modern plastic case has few screws.. and some secret to open it. Short, I did not find our how to open it. Does anybody have any hints for me how to open it correctly? Thanks!
  • Tierfreund Jun 10, 2008
    Hi jessica3434
    thanks for your instructions. I think this will help me to open the monitor !
Mine is an e173fpc model, I can tell you how to open it. I'm not the best with giving directions so sorry. If your monitor is facing you, you want to look around the outside edge there appears to be a seam going clear around. Get a flathead screwdriver and I started with the seam on the bottom...there are two little spaces down there that a flathead will fit into, just insert and give it a little twist in the first space it will pop it open a little bit, then do the second space. From there I really could not see any more spaces, but I just drug my flathead along the seam twisting it in about three spots on each side all the way around. It will work and it will not break it. Each time you twist the flathead a little it will pop that part off. I hope this was helpful.
Posted on Jun 10, 2008
  • jessica3434 Jun 10, 2008
    Sorry I forgot to mention that unscrewing the base from the back is the first thing I did. You probably knew that though.
I have a Dell E173FP 17 inch Flat Panel LCD Monitor. About two weeks ago after having turned it off at night (leaving the PC on) then turning the monitor back on in the morning it would light up to half of...
The monitor can be repaired - by replacing one or both the fluorescent tube and inverter. You can have the work done for you - or you can attempt it yourself. Lamp prices vary based on size - but most hover in the $10 range. Inverters can vary in price too - but run more than lamps for the most part. There are numerous suppliers for these parts such as this and instructions about how to do it such as this.
I hope this helps! Please rate my reply - thanks!
Dec 21, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor cuts out after a few minutes
Sounds to me like a power inverter. Fix it yourself with the parts found on Ebay at a cheap cost to yourself. The entire Dell E173FP 17" power inverter is selling for $29.99 plus shipping.
The fix can be found at: http://syscon.wordpress.com/2007/07/13/dell-dell-e172fpb-lcd-backlight-repair/
Cheers and good luck!!
Nov 05, 2010 | Dell E173FP 17" LCD Monitor
Hello, my Dell E173FP 17" LCD Monitor has a blinking power light and wont turn on.
It has shorted out transistors in the inverter circuits, check them out first, also check the fuse in the inverters section.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Oct 11, 2010 | Dell E173FP 17" LCD Monitor
Dell E173FP 17 monitor went dark and not working. I restart the pc it shows for only few second and went out again. I plug in one other monitor in my pc and it work fairly well. So something not right with...
Hi!
There are three possible cause why your monitor went black and start working..
1. If your monitor is dead set.. no reaction or lights turn on after power on.. then it needs to check if there is blown capacitor in its power supply section..
2. The high voltage ballast transformer of the backlight inverter is burned - it needs to be replaced so that it will not have a direct effect on the power supply section of the monitor.
3. The backlight inverters are all busted - the backlight was located at the upper and lower back edge of the monitor.. If these lights are busted then all that will be seen in your monitor is black screen.. It will need to be replaced so that image display will come out from your screen..
These 3 reason and its solutions can only be done by yourself if you have the knowledge, proper skills and the right tools to open the back cover of the monitor and replace the problem parts....
Otherwise, bring your monitor to a credible technician and if there is warranty,, avail of this...
Hope that answer your question..
Much appreciated if you rate this help..thanks..
May 20, 2010 | Dell E173FP 17" LCD Monitor
No Video/ Power LED on
You need to open it up and check the fuse and the transistors in the inverter power supply/inverter board, see failed DELL monitors here: http://s807.photobucket.com/home/budm/allalbums
Mar 19, 2010 | Dell E173FP 17" LCD Monitor
Has power but no display
Do the flashlight test. Shine flashlight on front of screen at angle and see if you can see an image or lettering. If so, it is probably inverter board. Let me know first if you have an image.
Jan 29, 2008 | Dell E173FP 17" LCD Monitor
Dell e173fp monitor power
These monitors are a pain to open up. The inverter circuit for the backlight is on the right side of the monitor when veiwed from the front, part is c5707(marked) or 2sc5707(actual part number) around $1, there are 4 of them, one or 2 usually fail. Sometimes this failure can cause damage to one or more of the corresponding transformers which can can be visibly be seen affecting(melted) the yellow wrap. Be sure to check for dry joints around the affected area as the boards are very badly made, primarily around these transistors and transformers or the fault could reoccur soon after the repair. The same fault occurs in the dell 19", part number is 2sc5706. I hope this helps you out.
Jan 05, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E173FP temperature sensitive 17" monitor
No. The best way is to take off the rear panel and insulator cover. Look on the board for "p/n: xxxxxxx" for the exact part number. I've found this to be the best way to ensure the correct board.
Also, once you're inside, you could see how many CCFLs you have.
Nov 06, 2007 | Dell E173FP 17" LCD Monitor
Dell E173FP
HI Jamil , I'm french technician and I solve this problem yesterday .
For your problem yo cans change capacitor C6 , C26 220uF 25V 105°(105° is important for longer life of you'r screen).see this vue
Jan 24, 2007 | Dell E173FP 17" LCD Monitor
Dell E173FP 17" LCD Flat Panel Monitor Logo
1,314 people viewed this question
Alun Cox
