Question about Brother IntelliFax-2820 Laser Fax
Brother fax 2920- error message "failure to warm up" turned on and off. unplugged. waited . problem unsolved
  • 241 Answers
This message means the fuser is not heating to the proper temperature. The fuser will more that likely need to be replaced. But considering cost it might be more cost effective to replace the machine.
Posted on Sep 29, 2010
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 105 Answers
Better take it to professional service because it could be failed fuser which you can't do nothing about yourself. In any case, be sure to check out the user manual for additional info
Posted on Dec 01, 2013
Hi, I am getting an error message on my Brother fax 2920 saying Drum error. I have tried changing the drum unit but no luck?
Ok so changing the drum has not resolved the problem. I suspect you have a bad contact between the machine and the drum. Its been a while since i have worked on a 2920 but i remember a case of a drum problem which turned out to be a poor contact from one of the contacts on the left side of the machine. Also take another look inside where the drum sits and you will see two runners that are spring loaded. the drum rests on these and i have known the springs to jump out and the runners have become stuck. of course this allows the drum to sit incorrectly and that may cause the error.
If no joy then let me know where you are located.
Good luck
Aug 26, 2011 | Brother FAX-2920 Plain Paper Laser
Item: Brother fax 2920 super g3 33.6 Kbps We are trying to change an existing one-touch/speed-dial number but cannot operate the cursor? email address: sue@eurotubes.co.uk
I saw your question on fixya.com. I am having the exact same problem. Are you getting 3 beeps when you try to operate the cursor? Apparently this means one of the buttons is stuck and the you have to clean the buttons with a wipe and try to "unstick" them. I have cleaned mine but unfortunately the problem remains unsolved I hope you will / have had better luck. To get help from Brother ring: 0161 615 6200
Sep 02, 2010 | Brother Office Equipment & Supplies
Brother fax 2920 error message displaying "rear door open" door is firmly closed , fax still showing error message ?
Look very carefully at the area, Most likly there is a sensor not being flaged. So check for any broken plastic tabs or it just my be an adjustment were a sensor was bent back or pushed out of place on a jam removal.
Jun 09, 2010 | Brother IntelliFax-2920 Plain Paper Fax,...
No manual to "Brother Super G3 336kbps IntelliFax-2920"
It is telling you the fuser unit needs replacement. Thats the heater that fuses the toner particles to the paper by heating them. If it cannot reach the correct tempurature the toner comes right off the paper.
So you will need to order a fuser wire kit to fix that error. That can be fairly expensive on a brother. I believe somewhere around $150 and up.
I can at least help you get a replacement manual. This link takes you to the downloads for your printer and you can then download the various manuals.
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_top.html?reg=us&c=us&lang=en&prod=fax2920_us
May 13, 2010 | Brother IntelliFax-2920 Fax
Brother Intellifax 2920 Error "Unable to Print"
Check the flux capacitor, those usually go out on brother faxes.
I just replaced mine last week, same problem.
Jan 05, 2010 | Brother IntelliFax-2920 Fax
Compatible drumunit brother fax 2920
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
Mar 23, 2009 | Brother FAX-2920 Plain Paper Laser
WHAT IS ERROR #202 MEANS
hello! i just checked the dervice manual for the rror202 that you said that you are having did not find that code could you clarify thanks brother sr tech
Jan 22, 2009 | Brother IntelliFax-2920 Plain Paper Fax,...
Brother Intellifax 2800 --message turn off and call Brother
what you want to do is unplug for a couple of minutes while checking to make sure there is paper jammed anywhere in the machine, remove all your paper from supply as well. then time how long it take to warm up or the error code comes up.
mikey
Mar 13, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
275 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
