Question about Electrical Supplies
WHO DO I GET A LAWM MOWER 4 CYCLE ENGINE TO PRODUCE ELECTRICITY , THE ENGINE IT IS A CRANK START ,AND IT GOES IN A GOKART AND I WANT TO INSTALL HEAD LIGTHS ,TAIL LIGTHS AND OTHER ELECTRIC PARTS
    President:
  • 1,388 Answers
In order for an engine to produce electricity it would have to have a stator under the flywheel and the flywheel would need a ring of magnets. Take a look at the following link and look at an example:
http://cgi.ebay.com/Briggs-Snowblower-light-flywheel-alternator-ring-gear-/280561041778?pt=LH_DefaultDomain_0&hash=item4152bdc172
If the link does not work go to ebay and search "briggs alternator"
Most small lawnmower engines did not come from factory with alternator. Usually snowblower, riding mower, commercial mower engines had charging/altnator for lights. Usually if the mower had an electric starter, it would have a charging system(not very powerful however). You could be creative and attach pulley to shaft before clutch or power takeoff and attach small alternator. Look for one that has a built-in regulator to simplify things. Sounds like a fun project, good luck.
Posted on Oct 02, 2010
Rough sound coming from gas lawm mower on start up
Sounds like the blade is hitting the inside of your deck. Look under mower and I believe you will find area where blade is hitting deck . GOOD LUCK FRIEND.
Sep 12, 2014 | Briggs & Stratton Garden
Oil appearing at exhaust, smokey, briggs and stratton lawm mower.
You will need to replace or clean the air filter, and probably the spark plug. Do not operate the mower for some hours to allow the oil drain (inside the engine). Check oil level and fill it if necessary. Some oil remaining in the exhaust should be burnt next time the lawnmower operates.You will see smoke at the beginning, that will be normal (burnt oil). Hope this helps!
May 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
My craftsman 6.5 hp lawn mover oil leaaking and smoke coming ou
Smoke white or blue? = oil overfilled possibly.
Apr 16, 2010 | Garden
Lawm mower engine will only run on choke
the carb is gummed up with laquer. take it of the motor and soak it in some solvent for an hour. but first take off the float cover before emersion.
Nov 12, 2009 | Briggs & Stratton Briggs Stratton Intek V...
I have a Troy Bilt mower w/ a Honda engine GCV160. OK, so I turned it on it's side after the last mow and the next time I tried to start it, it smoked and quit. Now the engine will not even turn over when...
Pull the spark plug and see if there is oil in the cylinder. When you turn a 4 cycle engine over or on it's side, the oil can leak into the cylinder. There may be so much oil in there that the piston won't move. When you have the plug out, clean it before you re-install. Good luck...Lee
Nov 01, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Toro lawm mower
the bulb is allowing air in some where. Replace it.
Jul 20, 2009 | Toro Lawn Mower With Toro Power Tools
Lawm mower back fires and kills when blade is engaged
Check your spark plug. Or maybe your choke is stuck
Jun 19, 2009 | Craftsman Garden
Excess white smoke coming from exhaust of TB 75SS string trimmer
This model is a four cycle engine meaning that it does not a mix of gas and 2 cycle oil. You just fill it like your lawn mower, gas and fill the crank case with oil
May 25, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
I have a broken deck cable can any buddy help it's on a riding mower
This is a lawn mower that is in the chainsaw section. We don't answer lawm mower questions and you don't cut down trees.
Apr 10, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Electrical Supplies Logo
100 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
