Question about Toro Garden
After staring my mower motor, the motors stops once I engage the blade.
  • Toro Master
  • 7,482 Answers
Check your fuel filter if you have one.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 12, 2010
Craftsman Model Number: 917.377151 motor shuts down when blades engaged
The engaging of the mowdeck is cause an excessive demand of your engine. From that, we can assume your problem is in the deck. Since the power drive is all about belts and it threw the belts, from your information I can only deduce that either an object (stick-wood-rock) has wedge into a position that has stopped rotation of the blades. Also, each blade has a pulley/spindle. These have bearings which must be free to rotate.
A bearing failure or seizing can also cause the problem you report.
Follow safety rules in your manual to insure the engine cannot start. Attempt to rotate each blade to check for free rotation. If the do not you most likely will need to remove the mower deck and check further. An obstruction or seized spindle should be easy to determine and sit repair is easily possible.
Sep 03, 2016 | Craftsman Garden
Pulled the knob to engage blade but blade would not engage.motor stops
possible bent damaged seized shaft, look under deck for excess debris, rope, damaged blades
Jan 28, 2016 | Husqvarna "RZ4621 46"" Briggs And Stratton...
I was mowing and the blades stopped turning. I disengaged and re-engaged the blades a few times and they started back. Then a few minutes later the blades stopped again then the motor stopped and will...
I have no idea what type or model of mower you have but if I was to guess I would say it has an electric pto clutch on it, if so remove your pto belt and clutch. I would bet it is burned out and locked up preventing your motor from turning over. Once the clutch is removed I will bet it will start and run fine. This is not a cheap fix but relatively easy one. Hope this helps.
Aug 21, 2014 | Toro TimeCutter Zero Turn Lawn Mower...
Did not press the RIO when going in reverse with the blades engaged. The motor stopped for safety reasons. Now I cannot get the mower started. Any ideas?
What model machine, and are blades engaged by flicking a switch or by actuating a lever.
BUT .... did you place machine in neutral, apply parking brake and disengage blade PTO before trying to re-start ?? Machine's safety system needs to be satisfied that the machine is safe to re-start.
Oct 30, 2013 | John Deere Garden
Tractor quits when engaging the blades
unhook clutch and see if blades stop turnig and then try engage clutch with the switch if motor stays running bad clutch
Jun 01, 2013 | Mtd Garden
Craftsman 18hp riding mower runs & stalls when engage the blades
motor off= deck engaed turn blade should turn motor and belt fairly easy, NO remove the belt from the motor pulley with deck engaged blades should turn freely.
most decks have breaks on the pullies so if the deck is not engaged the break will be on
May 27, 2017 | Craftsman Garden
Mower wants to stall when blades are engaged on a Huskee 13hp 38'' cut Tecumseh engine 6 speed on the go shift
Usually when the motor stalls when blades are engaged on any mower it is the carb that needs cleaned and rebuilt. The motor isn't getting enough gas to handle the load.
Jun 23, 2009 | Garden
Motor stops when the pto or cutting blades are turned on or engaged.
you most likely have a bad safety switch. there is one under your seat,one on engagement lever for blades,and probably one or two more in other places.start with the one under your seat by unplugging it and then going ahead with normale start up and implement engagement. you will have found the bad switch when everything works as it should.replace switch if you feel its necessary or just leave unplugged. it will not affect performance or longevity of the tractor
Apr 25, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Garden Logo
77 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
