Question about Dryers
No heat coming out tested power have 220 no continuity between leads figure element burned out how do you replace?
    Brigadier General:
  • 4,088 Answers
In general, remove the cabinet top, then the cabinet front. This should give access to the drum which needs to be removed. You need to release the drive belt tension by accessing the lower back panel to get to the motor where the tension device is located. Remove the screws in the center back of the drum and take out the drum. This should expose the heater assembly along with a thermostat switch and a safety high-temperature switch. Both switches should be 'on' when cold. The element(s) should read fairly low 'ohms' if good. You can sometimes just replace the heater wire, or replace the whole assembly--your choice. Re-assemble in reverse order. Check the condition of the drive belt and outer drum bearings (rollers or sliders) while you have it apart. Hope this helps!
Posted on Sep 29, 2010
Reg-94 bk is not heating no volts at Element and no continuity in element as well
Go to your power panel and reset the circuit breaker for the dryer. Then recheck the volts at the wall socket. If you only get 120 but not 220 then replace the breaker. No continuity on the element says it's burned out. That definitely needs replacement.
Aug 08, 2015 | Dryers
I have an electric whirlpool dryer model# wed5300sq0 and it stopped heating. Still operates just no heat. Figured it must be the heating element so i ordered and replaced it. I also tested the fuse and...
Hi dustin me413...
Try some of these tests to locate your problem
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks.
If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the
wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed
component. The switch is inside the dryer main housing near the door frame.
Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Check for continuity you should have none with door open, and should have a reading when closed.
If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause
heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the
thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape
or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged
with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's
plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace an element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Apr 26, 2011 | Whirlpool Dryers
Pulled out heating element both black wires connecting heating element are burned is this mean its a faulty heating element
Hi franklin bai
Yes the element is faulty...replace it...but also check some other things...see below
Check your Wiring
wire is attached.
Apr 16, 2011 | Amana NDE2335AY Electric Dryer
Preforma dryer:: heating element comes on and glows red for about a minute or so then it goes out and stays out for long time and then it will come again if you restart the drying cycle the element heats...
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
For video and pictures on how to replace the element go to the following website:
Dec 12, 2010 | Maytag PYE2300AY Electric Dryer
Heating element does not come on when dryer cycle is started
Check your Wiring
Oct 18, 2010 | Dryers
The dryer spins and blows air... but the air is not hot... no matter the setting... Help... I'm a plumber... not a dryer!
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
For further instructions on how to replace the element go to the following website:
Oct 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
No heat and autosense timer does not shut off. Is this just the thermal fuse or is the element bad?
There is a thermal fuse located at the top of the heat canister that could be bad. The heating element could be bad. The 220 volts power to the dryer could be bad.
You need a volt/ohm meter to check these out. Set the meter for volts. Remove the service plate from the rear of the dryer where the cord connects. Check for 220 volts incoming. Check the wires there to make sure one has not burned loose.
Remove the rear panel to access the heat canister. Turn off the power or unplug the cord. Set the meter for ohms/continuity. Remove the wires from the thermal relay on the top of the heat canister. Touch each meter lead to each of the 2 terminals on the relay. If it reads,it is good.
Remove the wires from the heat element. Touch both leads from the meter to each terminal on the heater. If it reads it is good.
If any part does not read,replace it.
Sep 13, 2009 | Roper Dryers
Whirlpool duet electric wil not heat
Remove 1 wire from the element . Your 220 V comes from ...110 motor , 110 control board . Check which wire is not getting 110 V , trace it and see which it comes from . That will tell you which one is defective .
Jul 30, 2009 | Whirlpool GEW9250 Electric Dryer
New Heating Element; Has Power But Not Heating Up
Let's go over a few things:
  • Your unit uses 220 volts to provide heating.  Some elements are wired to one of the two 'legs' of the 220 giving you 'low'.  High uses 220
220 consists of three wires...two 'hot' (red and black) and a neutral which is white.  Neutral to hot will give you 110...hot to hot 220.  Measure accordingly and use care!  Neutral and the frame of the stove are effectively the same terminal...for safety.
  • You say some of the wires are burnt or a fuse is blown.  They need to be replaced with proper wire...not just any kind.  There is high temp insulated wire available from many ACE and other home stores or parts shops.  It needs to be thick enough, too.  Make all connections carefully and fully onto clean terminals.  Tighten clockwise.
  • Check the voltage coming to the element on various settings as above.  If you only get 110/120, you have an open supply issue which needs to be found.
Look for: loose wires, corrosion, burned insulation to ground.
Nov 19, 2008 | Belling CookCenter 151 Dual Fuel (Electric...
Maytag electric dryer not heating
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Nov 01, 2007 | Maytag PYE2300AY Electric Dryer
Dryers Logo
24 people viewed this question
Top Dryers Experts
