When trying to fax i am receiving the message no dial tone. i pick up the receiver to my phone and i hear the dial tone. is there a pne number to call for tech support.
    Scholar:
  • 78 Answers
Without knowing the exact model, I am unable to direct you to tech support....A common problem that causes this is either the phone cord is plugged into the out instead of the in jack on the back of the printer. Another possible situation is that you have VoIP phone service (comcast, or vonage) which doesn't provide a true dial tone for faxing, in which case you would need a dedicated phone line for the fax.
Posted on Sep 29, 2010
WE CANNOT RECEIVE OR SEND FAXES, BUSY/NO SIGNAL
Plug a phone into the jack and check to make sure you have a dial tone. If not telephone company needs to be called. If dial tone it may be the other number you are trying to fax to. try calling the number from phone and see if it picks up.
Aug 25, 2010 | Brother Office Equipment & Supplies
Can not receive or send faxes???
If your fax machine was working before this could be a line problem. Call your fax number with your cell phone or another phone. If you get a message phone the phone company or it just rings busy its probably a line problem. Another check is to plug your hand set into the wall outlet jack, you should hear the dial tone. If there is no dial tone its also a line problem. Or just try pluging your fax machine in at another location, if it works there you know its a line problem. If its still not working its going to be one of the boards inside the fax machine. Good luck.
May 16, 2010 | Office Equipment & Supplies
Brother Intellifax 4100 unable to send fax but can receive
Is the fax sensing the paper you put in to send out? Check the little black levers that poke into the document area. They should move freely when you touch them gently with a finger, and return quickly when you take your finger off. If it can't sense the paper it won't try to send a fax. If, when the paper is inserted, the display changes from whatever it said to anything else, the paper is being sensed.
Let's try dialing manually. Just left of the 1 key is a button labeled "Hook." Pressing that will take the telephone line "off-hook," like picking up the receiver of a phone. You should hear a dial tone -- if not, try adjusting the speaker volume with the buttons just right of the numbers. Once you get a dial tone, dial a number, whether it's another fax, or your own cell phone. As far as the phone company is concerned, your fax is just a phone, calling another phone. If you can make a call, and the phone at the other end rings, we're closing in on the problem. If you can dial another fax machine manually, you can still turn this into a fax call, assuming there's paper ready to fax. After the distant fax answers, touch the Start button, and your fax should take over. If you can't dial manually, try unplugging your fax from the phone line, and replacing it with a regular phone. Can you make calls with it? If not, the fax is no longer a suspect - you have a phone line problem.
Are you at a business where you need to dial 9 to get an outside line? It's easy to forget that detail when you're using a fax, but it has to dial out just like any other phone on the system.
If you can't get a dial tone at all with the fax, but it works with the phone alone, the main board in the fax is probably bad. If you can dial manually, using the Hook switch, but the same number doesn't work when you dial xxx-xxxx-Start, that sounds like a main board problem, too.
May 05, 2009 | Brother IntelliFax-4100e Fax
I need to retrieve my home phone messages from cell phone
Activating Call Forwarding
You can activate Call Forwarding whenever you want your calls to be sent to another phone, including a mobile phone. Once activated, all your calls will be sent to the forwarding number you request. Each time a call is forwarded, you will hear one short reminder tone on your home phone, but you will not be able to answer the call from your home number.
1. Lift your telephone's receiver and listen for a dial tone.
2. Press *7 2.
In some areas you must use 72#
Dial 1172 on rotary or pulse-dialing phones.
3. At the tone, dial the telephone number where you want your calls transferred.
You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
You will hear two short tones telling you that Call Forwarding is activated.
5. Hang up the receiver.
Deactivating Call Forwarding
Turn Call Forwarding off when you want to receive calls on your home phone.
2. Press * 73.
In some areas you must use 73#
Dial 1173 on rotary or pulse-dialing phones.
3. Listen for two short tones.
Call Forwarding is now off and you will receive your calls at your home number.
Dec 01, 2008 | Uniden Cordless Phone
Sending a fax
First make sure that the fax button has been pushed and is llit...
The 2820 should have a handset. In order to use manual transmission (when you get to hear all the beeps and whistles) you will need to load the document then pick up the handset. then dial the number, when you hear the recieving fax tone then hit the start button.
The 2820 should also have a hook hold button pressing this will allow you to hear the dial tone and the numbers you dial along with the receiving fax tone. If you dont hear anything when you press this button then you may want to use the volume buttons to increase the volume.
Also remember that if you have not picked up the handset or pressed he hook/hold button the unit will use automatic mode, which is to say that all you will do is load the document, dial the number, and then press the start button.
May 19, 2008 | Brother IntelliFax-2820 Laser Fax
Lexmark 7350 all in one
Before you begin
To pinpoint the cause of the issue, please record answers to the following questions:
Can a fax be sent or received?
Can a fax be sent, but not received?
Has the fax function ever worked in the past?
Any error messages may also help to narrow down the cause of the issues.
Print out the following:
- a settings list to view the current fax settings
- a receive log if there are issues receiving faxes
- a send log if there are issues sending faxes
- an activity log if faxes cannot be sent or received.
Initial checks
If the fax option has worked in the past and does not do so now, check that the same connection is being used and that it still works.
Check to see if any configuration settings have been changed that could have affected the fax settings.
Faxes cannot be sent/received:
If you are using a digital line, you need an analog card, an ISDN adapter, or an ADSL filter in order to send faxes.
If a PBX is being used, an ISDN Adapter/ADSL filter will not be used as these are supplied within the system. (A PBX is normally used within a company to share a small number of public lines among a large number of private ones to save on cost.) For instructions on configuring the X6100 Series machine with a PBX, see How and When to Use the PBX Option.
Check the phone line (without the printer):
Test the line by connecting a phone directly into the phone port.
Check for a dialing tone.
If you cannot hear a dialing tone, try another phone cable. Once you can hear a dialing tone, you know that the phone port is live and working.
Make sure the RJ11 cable is not damaged.
Check that the printer is accessing the dialing tone correctly:
Press the Options button on the operator panel five times until ON HOOK DIAL is displayed.
Press Select. You should hear a dialing tone.
If you can't hear a dial tone, make sure that the speaker volume is set to High. (Go to Fax, press Options eight times until SPEAKER VOLUME is displayed, then use the plus or minus buttons to change the setting to HIGH. Press Select.)
If there is still no dial tone, unplug the power cable and the phone lead, then plug them back in and try again.
Faxes can be sent but not received:
Connect the Lexmark All-in-One directly to the phone port. IMPORTANT: Do NOT connect any phones to the EXT port.
Make sure the Fax receive mode is set to answer the fax after 3 rings. (Press the Fax button on the operator panel and then press Options three times until ANSWER FAX WHEN is displayed. Change the settings using the - or + buttons as appropriate.)
Faxes can be received but not sent:
Make sure that Country Code is set correctly:
Press the Fax button on the operator panel and then press Options 15 times until Advanced is displayed.
Press Select.
Press Options 13 times and then press the + or - button until the right country is displayed.
Press Select.
IMPORTANT! These tests must be carried out with NO EXTENSIONS, i.e. phones or answering machines, connected to the EXT port on the All-In-One.
Feb 15, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Faxmachine
CHECK 1.DO YOU GET DIAL TONE ON -ON HOOK DIAL BUTTON OR ON THE HANDSET ? IF NOT PLS CHECK THE PHONE LINE OTHERWISE--- 2.TRY RINGING THE MACHINE FROM OTHER PHONE,CAN U HEAR THE RING ? IF YES ,PLS CHECK WHAT NOS OF RINGS ,THE MACHINE IS SET TO RECEIVE, AS WELL AS SET THE CORRECT RECEIVE MODE , I.E. FAX /TEL/ANS-FAX... 3 IF U STILL DON'T GET FAX TONE WHILE RECEVING ,THEN TELEPHONE LINE CARD SHOULD BE BAD... TRY REPLACING TEH SAME ,SHOULD RESOLVE THE PROBLEM. HAPPY FAXING OMNIPRESENT HAPPY FAXING
Sep 21, 2007 | Office Equipment & Supplies
Sending and receiving problems
Where the telephone line comes in from the wall, make sure that it is plugged in the "line" or "wall" port. There is probably another port call "tel" or "acc". If the line is plugged into that port you will still get a dial tone but you are not connected to the fax's modem. You hope that's it. Ed
May 15, 2007 | Canon FaxPhone L75 Plain Paper Laser
Can't receive fax
Pick up the receiver and see if you hear a fax tone noise. If so then push the start button and hang up. Is this machine on a dedicated line or shared with the main phone number? Sometimes some people will pick up the receiver on their fax machine dial the fax number and wait for a tone before sending. If this is the case the machine can not recognize that is a ax. Make sure your machine is set for auto receive if it is on a dedicated line.
Apr 06, 2007 | Brother IntelliFax-2820 Laser Fax
100 people viewed this question
k24674
