What is error code biohd2 on hp all in one computer
2 Suggested Answers
  • 11800 Answers
SOURCE: Elder parents have a 1 1/2 yr old HP Pavillion
That means that the BIOS of the motherboard can't detect the hard disk = it has died. Replace the hard disk and reinstall.
Posted on Aug 12, 2010
Hp 6930p nmi channel check iochk
System I/O address specifications 970-071 NMI enable/RTC
What is Nmi Error On Hp Server error? The Nmi Error On Hp is the Hexadecimal format of the error caused. This is common error code format used by windows and other windows compatible software and driver vendors.
This code is used by the vendor to identify the error caused. This Nmi Error On Hp Server error code has a numeric error number and a technical description. In some cases the error may have more parameters in Nmi Error On Hp Server format .This additional hexadecimal code are the address of the memory locations where the instruction(s) was loaded at the time of the error.
What causes Nmi Error On Hp Server error? The Nmi Error On Hp may be caused by windows system files damage. The corrupted system files entries can be a real threat to the well being of your computer.
There can be many events which may have resulted in the system files errors. An incomplete installation, an incomplete uninstall, improper deletion of applications or hardware. It can also be caused if your computer is recovered from a virus or adware/spyware attack or by an improper shutdown of the computer. All the above actives may result in the deletion or corruption of the entries in the windows system files. This corrupted system file will lead to the missing and wrongly linked information and files needed for the proper working of the application.
How to easily fix Nmi Error On Hp Server error? There are two (2) ways to fix Nmi Error On Hp
Advanced Computer User Solution (manual update):
1) Start your computer and log on as an administrator.
2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore.
3) In the new window, select "Restore my computer to an earlier time" option and then click Next.
4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next.
5) Click Next on the confirmation window.
6) Restarts the computer when the restoration is finished.
Novice Computer User Solution (completely automated):
1) Download (Nmi Error On Hp Server) repair utility.
2) Install program and click Scan button.
3) Click the Fix Errors button when scan is completed.
4) Restart your computer.
Dec 10, 2016 | HP Computers & Internet
Hp officejet 6500A giving an error code 0x61011bea
Is the error displaying on the printer... Have you connected the printer to the computer.. Whats the OS on tge computer
. try disconnecting the printer andcheck for the error messages..
Feb 09, 2014 | HP OfficeJet Office Equipment & Supplies
Error 1801 micro code
The code is only translated by HP and is of no use to an assistant; however, I suggest you go to HP.com, allow the Automatic search of your HP devices, and when it finds the computer; go to the Drivers section. Download the drivers and perhaps a reset will occur and eliminate the code in question.
Jan 02, 2014 | HP Compaq dc7600 Small Form Factor PC...
The code purple shows up on my computer hp desktop
The following error message opens after the PC is started after a recovery: Your system has detected a configuration error. Please call your Customer Care Center number, located in your Warranty and License information, for technical support. (Code Purple) contact hp tech support...meder's tv service Figure 1: Code Purple error c00372799.jpg
Aug 29, 2012 | HP Computers & Internet
The code purple on my computer
Code purple is because an O.S other than a genuine HP has been installed and as it is HP it would have to be HP as it is designed especially to run HP computers only, For example if you try to install an O.S from a Compaq even though Hp and Compaq have merged it is written for Compaq computers not HP and vice/versa. Re-Install your original HP O.S and this should sort out the code purple error. I hope this helps.
Elder parents have a 1 1/2 yr old HP Pavillion Series 4600. They are getting a black screen that reads "Disc Boot Failure Code HP-BIOHD2. Can you help me?
Aug 12, 2010 | HP Computers & Internet
Code purple error after system recovery on windows xp how can i fix im a green hand but follow clear instructions very good
There is no way to fix a Code Purple error on an HP computer.
Basically what has happened is that there is a Hard Coded Information "Tattoo" on the motherboard that tells the computer what hardware should be on this machine.  The Hard Code and the hardware do not match.  It is kind of a known fault by HP.
But there is some good news.  No matter long your computer has been out of warranty, this problem IS covered.  The wrong hardware was put into your machine and no matter when this error occurs, HP will support it.
Call HP's tech support and when you speak to a Technical Agent, you let them know you got the Code Purple Error, and they should immediately escalate your call to their Hardware Specialists and set up a service repair where they send you a box and paid shipping label to ship your computer to one of their repair facilities where they will fix it and send it back to you at no cost.  Call 1-800-HP-INVENT.
I used to work for HP tech support and we would see a Code Purple case about once every few months, even on computers 3+ years old.
Mar 26, 2010 | HP PC Desktop
Hp error code for compaq presario code 1002
http://h30434.www3.hp.com/t5/Operating-systems-and-software/Recovery-Error-Code-1002/m-p/11366
Jan 21, 2010 | Computers & Internet
Configuration error on windows xp code purple
if its a code purple error on ur hp computer and its a blue screen error message then the issue is with the motherboard of your computer...and in this case nothing can be done.If your computer is only 4 to 5 years old or less than that call to HP they will replace your free of cost,HP's phone number is 18004746836
Nov 28, 2009 | HP Pavilion m7560n PC Desktop
My computer tell me that my printer as a error code 20
Error code 20 in HP printers usually means you are trying to print to a non-default printer. try setting your D7200 as the default printer. Here is the direct link to HP about your problem:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00759728&jumpid=reg_R1002_USEN
Jan 07, 2008 | Office Equipment & Supplies
Computers & Internet Logo
298 people viewed this question
David Payne
David Payne
