Question about Samsung SyncMaster 753S 17" CRT Monitor
Everything is blurry because the settings were played with...can i have the original factory settings like :brightness %...etc??
    Guru:
  • 452 Answers
The blurry is caused by the FBT voltage open the cover and correct the focus Horizontal and Vertical with the scewdrive
Posted on Oct 16, 2010
Geek Squad broke my Television
Try these settings:
Picture Mode: Movie
Contrast: 100
Brightness: 44
Sharpness: 20
Color: 50
Tint: 50
Backlight: 7
Color Tone Warm1
Digital NR Auto
Detailed Settings
Black Adjust Low
Dynamic Contrast Low
Gamma -1
Color Space Auto
Edge Enhancement On
xvYCC Off
White Balance
R-Offset 21
G-Offset 20
B-Offset 21
R-Gain 0
G-Gain 21
B-Gain 26
My Color Control
Pink 20
Green 15
Blue 15
White 15
Auto Motion Plus 120hz: Low
Feb 28, 2014 | Samsung UN55C6500VFXZA 55in Led Hdtv 1080p...
New Philips Televion dim and flickers
You should return the player because if it is dim and flickering than there is a miss connection in the play. It could also be that your tv is not compatable with that player.
Dec 25, 2012 | Philips 50PFL3807/F7
I have a samsung lcd tv mod LN46A550P3F that the pix is so bright ,you can see the image but it is like negative , some help is welcome . thanks.
Initially try to enter a factory settings if not helped try to play a dvd movies etc on your TV,,if the problem is still there you have bad T-con board..Just replace it to fix the problem,,
Aug 28, 2012 | Acer Televison & Video
My screen suddenly developed horizontal lines in it. I tried everything, but the only thing that worked with "Memory Recall", which as I understand it, changes the settings back to the original...
It sounds like you have an issue with the monitor's power. Make sure all connections with the power cord and audio cables are secure. If this does not resolve the issue and the monitor is under warranty you may want to RMA it.
May 27, 2011 | ViewSonic VA1912wb Monitor
Blurry screen
check your cable VGA or DVI - reboot - if not work, uninstall your drivers and reinstall them
Sep 01, 2009 | HP vs19 (Silver) 19" LCD Monitor
Turned blurry with brilliant colors
this is not connected about the changed cables,digital boxes.the problem of your television is in focus of picture tube. you cannot adjust this because of some problem in tube.find a right technician so he can fixed this one.
Feb 21, 2009 | Sanyo DS31590 31" TV
WD-52525 screen is jumping all around with wavy horizontal lines etc.
Good Day;
Keep talking to the factory, it is their product. Best Buy won't replace unless it is deemed not repairable and/or terms of the contract. You purchased the extra warranty because you most have felt that the TV might break down. Well, it did, now use the contract to repair your TV.
Good Luck, big IRISH.
Sep 29, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Help with settings - blurry SD picture
contrast full, brightness, tint, color, in the middle, then adjust sharpness for what suits your eyes, you may turn brightness and color below middle.
Mar 17, 2008 | Sony BRAVIA KDL-40V3000 Television
Dell UltraScan P1110 flat-screen monitor BLURRY?
The button you pressed is the reset button and according to the documentaton "returns the monitor to factory defaults".
Here's a link to the Dell support page for your monitor:
http://support.dell.com/support/edocs/monitors/p1110/En/index.htm
Regarding the lines that were orginally were trying to fix; see Damper Wires in Troubleshooting in the above documentation and you'll see that they're a fact of life with this type of monitor. I realize this may not have been your problem, but then again...
I'm surprised that the factory reset made things blurry. Usually this is the result of less than optimum settings on the display adapter in your computer rather than the monitor itself. The Trouble Shooting guide says the brightness and contrast being set too high can cause this so that may be worth checking.
I think you should check your display adapter settings after you try the Troubleshooting suggestions. On the desktop of your computer right click in an empty spot and select Properties. Click on the Settings tab and see what the resolution is. If it's not 1280x1024 you might want to try that. Everything on the screen may suddenly appear smaller so don't be surprised. I would also check the monitor frequency. This will probably be found under Advanced. Every display adapter is different so I can't tell you exactly where to look, just polk around. If you start changing things you may want to write down the original settings so you can at least get back to where you started if there's a problem.
Lastly, I want you to know I'm not paid to provide these suggestions. I know it's a strange hobby, but I like helping when I can. If you find this helpful I hope you'll take a moment and provide a positive rating. About half of the solutions I've posted have never been rated... Thanks and good luck.
Jan 02, 2008 | Computers & Internet
Blurry and Bright white on subject face
This could be a CCD fault or possibly Lens damage. Not I would think something amenable to a sensible repair price- check Olympus first though.
Jun 18, 2007 | Olympus Camedia C-4000 Zoom Digital Camera
Samsung SyncMaster 753S 17" CRT Monitor Logo
229 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
