Question about Microwave Ovens
I need a replacement rechargeable battery for a Scunci Model 52160 Big Scrubber. The numbers on the current battery component are PA66GF30, PA66GF30UL and SPR1-PO13. Can you help me?
I need a new handle for model number JBP30BA2WH
Enter your full model number here to get the parts list. I'm a big fan of The Pros.
You'll probably need to separate the door panels to access the screws. On some models you have to remove one door screws, then gently rotate the handle.
Nov 23, 2016 | Microwave Ovens
It won't heat things, Model #OGS31102
test this components and fix it. God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Oct 24, 2013 | Oster Microwave Ovens
Need a over the range microwave with height of 14"
The first thing I'd do is contact the manufacturer of the old oven and ask if they have a current "drop-in" replacement model to replace your old one's model number.
Otherwise, you'll have to visit various manufacturer Web sites and dealers to check out their specifications.
Oct 18, 2012 | Microwave Ovens
I am getting ready to update my appliances. I want to know the exact size of the appliances I currently have supplying you the model and serial numbers. Double wall oven: RDE 2400 P2 Model Number, MI 34...
OK, now replacement of major appliances in your home should be left to someone that you don't even know. Why should I recommend Whirlpool replacement appliances. This is your decision.
It depend on what you want in appliances; such as, top quality, the most expensive, mid level appliances, and many other factors involved in your choices of replacement appliance.
Mrs Alecia William you need to talk it over with your husband and friends, do your research on appliances on the internet. Just remember this....Everybody will give advise on what appliances to buy but the final decision will be left you and your husband. I could recommend different types of appliances, but who am I! Please do your research. All I can recommend is BUY AMERICA. And yes, United States does make all the appliance that you have mentioned. GB you...stewbison
Sep 05, 2011 | Whirlpool Microwave Ovens
I have a P- 820 Koblenz floor scrubber and the wire that controls the release of the water is broken. could this part be replaced? and if it can where could i get the part from? how soon could it be...
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Dec 19, 2010 | Microwave Ovens
My microwave shows an error that says c-5 what is it
That would be "CS", which means low current sense.
CS Current Sense
Current Sense - Indicates control is sensing low current
(Amp) draw. Check components which would allow unit
to run but produce no heat or low heat. Current sense
circuit is active only when using pre-programmed pads.
Time Entry feature will by-pass current sense circuit.
Red wire from cavity T.C.O. must be routed through
current sense loop on H.V. Board.
Possible Causes:
1. Interlock switch (contacts 2 & 3).
2. Open thermal cut-out (magnetron).
3. Open/loose wire.
4. Power relay.
5. H.V. Board.
6. Magnetron.
7. Diode.
8. Capacitor.
9. Transformer.
10.Triac.
See the full service manual here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 01, 2010 | Amana RC17 Microwave Oven
The unit is not functioning although power supply is fine; I suspect a blown fuse but cannot locate my original parts list (model #721.62622) to identify which fuse to replace. Are fuses available from any...
20A ceramic fuses (the most common) can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
It may be the fuse, which is usually located behind the grille, on the floor of the oven behind the control panel, between the door switches, or on the filter board near where the cord comes into the unit.
If the fuse is good, it may be an open thermostat / thermal cutout (TCO) / thermal fuse on top of the cavity / body of the oven.
Accessing some components (especially the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as 721.62622200. Check the tag on your unit.
But Sears parts can usually be obtained for far less here by entering either the part number.
When you enter your model number here, on the resulting page look to the right for the blue "View manuals" button. Click there.
d:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpgd:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpgd:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpg439cb0b.jpg
That Sears-related site has many free manuals. While the manuals they list there are all free, they will ask you to register.
Many times, the owner's manual will also have the installation instructions inside, too.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
We have the overall schematic diagram for model 721.62622200 here and here. It may be close enough to yours to help.
Jun 26, 2009 | Kenmore 62622 Microwave Oven
I NEED AN ENTIRE MICROWAVE, MODEL NUMBER
GE Customer Service is here.
They may be able to tell you what a current "drop-in replacement" would be for your model.
Jun 06, 2009 | General Electric Microwave Oven
Blown Fuse on a Microwave
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Let us know if you need further help with torubleshooting.
Nov 28, 2008 | Kenmore 62702 Microwave Oven
Countertop kenmore microwave, large, brown, old...whar is model number...I need to manual
Sorry, but you can't get a manual without the model number. You can find help locating your model number here.
If the manual doesn't address how to change the bulb, or you don't see an obvious bulb cover, then you'll have to remove the outer cover.
Be sure to unplug the oven first.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 03, 2008 | Microwave Ovens
Microwave Ovens Logo
44 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
