Question about Canon ImageCLASS MF4370dn Laser All-in-One Printer
The fax function on my Canon ImageCLASS MF4370dn was working fine. After I scanned a document, then I tried to send a fax. I put the documents on the sheet feeder (not the platen). After pressing the "Fax" button, then dialing the recipient's phone number, then pressing "Start", I get a message, "Original Size Letter" and nothing happens. If I then press the "Start" button again, this message is displaid: "Scanning", then the machine makes a noise as if scanning. Then I get the message, "Next page: start. (new line) End scanning: OK" I turned off the machine and turned it on again. But the same process happens. I didn't change anything in the machine's setup menu. But I suppose something was reset when I used the scan function of the machine. Any help would be appreciated. Thanks very much. dgardner@ucsd.edu
  • 3 more comments
  • dgardner760 Sep 30, 2010
    Thanks for your reply. I wonder how it could be a corrupted driver when I'm performing all the operations described above on the copier/ fax/ scanner itself and not from the computer.
    I wonder how the problem could be the driver if the operations were done on the Canon machine itself and not the computer.
    The problem was solved when I followed the directions for the Canon support person (see below). I opened the ADF cover. The black plastic flag sensor in the middle was in the up position. But I pushed it down, a motor activated for about 3 seconds, and the screen displayed "Available memory 100%". Then I tried to send a fax, and it worked. I think that pushing down the plastic sensor must have reset something.
    Thank you for your inquiry. We value you as a Canon customer and appreciate the opportunity to assist you. We sincerely apologize for any difficulties you have experienced with the fax feature on the MF4370dn not working correctly.
    You may need to check for possible obstructions in the MF4370dn ADF.
    Try the following suggestions:
    1. Open the ADF cover.
    2. Look for any obstructions. *Make sure the black plastic flag sensor is in the up position.
    3. Close the ADF cover.
    4. Open the ADF and check for possible obstructions in the ADF area.
    5. Close the ADF.
    Note: Be careful not to get your fingers caught.
    If necessary, reset the unit by cycling the power. Turn the power switch off and then back on again. If the issue persists, the MF4370dn may require service from an Authorized Service Facility (ASF). We apologize for any inconvenience this may cause...
    I had already received the (somewhat) correct solution from a canon support person before I received this expert's reply, which was not as specific as the one from canon tech support.
    Yes, those were the exact recommendations of the Canon tech support person. When I pressed the black flag from the up position to the down position, a motor sounded briefly, and the screen displayed a message "Memory available 100%". I didn't turn off the machine. But the fax functioned fine.
    President:
  • 2,777 Answers
This is very strange indeed. Does it still receive faxes just fine? Have you tried just placing the paper on the platen and seeing if it will scan / fax that way? It sounds like a feeder issue, but can't be sure just yet.
Try that and let me know.
Thanks
Tim
Posted on Sep 30, 2010
  • Tim Grayson
    Tim Grayson Sep 30, 2010
    Ah fantastic, and I am going to add that to my personal notes so that if someone in the future has this issue I will know what to do right away. Thanks so much! If possible please come back to the question here and click the Accept
    This Solution button, otherwise I don't get credit for the help
    provided.
    Thanks,
    Tim
    Genius:
  • 1,035 Answers
Hi. You may try following these troubleshooting steps from Canon:
5. Close the ADF.
  • Canon Master
  • 3,083 Answers
Not sure if the information in this excerpt from a review on Amazon.com will help, but it might:
I was a little disappointed. This printer didn't turn out to be everything I thought it would be, which is why I only gave it 4 stars. First of all, you must know Windows Fax & Scan does not work with this printer. That is the let down of the year to me, but it's not Canon's fault... not necessarily. Turns out WF&S only uses WIA scanning drivers and this printer uses TWAIN. Thanks Microsoft. The computer never directly communicates with the printer, so the faxing is treated like printing. As a result, the faxing portion of the software doesn't work with it either.
This printer DOES come with software for scanning. It's burried on the CD, and you must explore the CD to find it. I believe it's only for the PC, however.As the other poster said, I searched all over for the scanning software I thought I installed. Turns out it was just a driver. I own Adobe Photoshop and Acrobat, so it's not much of a concern for me. They are both TWAIN compatible by the way. One thing I don't like about this printer is the need to press the scan button prior to scanning. This is not very convenient for a network printer. It's even worse if you have a long way to go to get back to your PC. By the time you get there, the thing may have gone back into power saving mode.
I've seen good reports on Canon's support, so you might try contacting them to see if they have a settings or updated driver remedy for this problem. Here's their site:
http://www.usa.canon.com/cusa/support
Didn't see this problem reported on the net, so it could possibly be a corrupted driver- not sure.
Good luck, and hope this helps.
Posted on Sep 29, 2010
Canon imageclass D1120 printer says: feeder paper jam,
Hi Try this method
To "Settings/Registration Table"
You can specify the method for restarting scanning of documents when a paper jam occurs in the feeder.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
  1. Press b_in_add.gif(Settings/Registration) ? [Function Settings] ? [Common] ? [Scan Settings] ? [Feeder Jam Recovery Method].
  1. Select [From 1st Page] or [From Stopped Original] ? press [OK].
Details of each item are shown below.
[From 1st Page]: If a paper jam occurs in the feeder, scanning starts again from the first page of the document. [From Stopped Original]: If a paper jam occurs in the feeder, scanning starts again from the page of the document scanning was interrupted.
Jun 10, 2011 | Canon ImageCLASS D1120 All-In-One Laser...
After installed the Window 7, MF4360dn scanner is not working!
Hi there
Not work you need to find the windows 7 printer driver for it and it could be a job trying to find one as they are still selling there printers with xp drivers only, sorry.
Feb 21, 2010 | Canon ImageCLASS MF4370dn Laser All-in-One...
Trying to scan, but keep getting error code 2,162,0 My scanner printer - my Canon 4370 won't scan. Printing and copying is working fine.
This works!:
noavatar_s.gif the_sunman
Rank: Apprentice
Rating: 94%, 4 votes
I finally got a solution to my problem, which is the same as this one. When trying to scan via USB, you have to make sure the unit is set to USB. On the top panel just above the LCD display, is 3 buttons, Copy, Fax, Scan. Hit the SCAN button, till the display says USB SCANNING. Then try to scan again. Good luck!
Sep 08, 2009 | Canon ImageCLASS MF4370dn Laser All-in-One...
Scanning Multiple pages into one pdf
Scanning a multi-page document as a .pdf file reverts the settings for rotation, selected area, etc. to default for any pages after the first page. This applies to Mac OSX 10.3, 10.4, & 10.5. A simple, but tedious work-around is to scan each page as a separate file and easily recombine them using OSX Preview. Just open the first page, view the Sidebar, and drag-drop the additional page files into the sidebar. Save and it's all one multi-page .pdf.
Jun 26, 2009 | HP Photosmart C5280 Printer
I finally got a solution to my problem, which is the same as this one. When trying to scan via USB, you have to make sure the unit is set to USB. On the top panel just above the LCD display, is 3 buttons, Copy, Fax, Scan. Hit the SCAN button, till the display says USB SCANNING. Then try to scan again. Good luck!!
Apr 23, 2009 | Canon ImageCLASS MF4370dn Laser All-in-One...
Canon will not receive faxes or copy documents
see if you have fax line(conect a telefone in the line to see if you have tone) or if the cable is conected.
Nov 21, 2008 | Canon NP 7130 Black and White Copier
Canon Fax B160 sending fax troubles
The fax transmission speed was set to 14400, we have solved the problem by putting down transmission speed to 4800 and now emission works without troubles.
Mar 03, 2008 | Canon FAX-B160 Plain Paper Bubblejet
I want to scan then send instead of scanning whilst sending
There are 2 methods of sending 1. Through memory, in which the machine scans the document then sends when all pages have been scanned. 2. In real time, in which the document is placed in the ready mode and the line monitor or handset is used to dial the number. In this case the document is not scanned until a response is heard from the other machine.
However, in the case of the memory being full, either of documents in the queue or if there are documents waiting to be printed (because of no toner or no paper) then the machine will not allow sending from memory.
Feb 07, 2008 | Canon FAX-L200 Plain Paper Laser
Canon ImageCLASS MF4370dn Laser All-in-One Printer Logo
820 people viewed this question
old marine
old marine
