Question about Winbond Electronics Corp Winbond W89C840 PCI Fast Ethernet Adapter
The Network card Winbond PCI Fast Ethernet W89C840 2.40.1381.1 is not identified in Window7. That to do?
Good day. Need a driver for SMC Sun PCI Quad Fast
Please be informed that any Driver Software depends upon its Hardware make and Operating System support. You need to know all these information to get started working with that particular hardware. You can find the driver software inside the disc provided to you at the time of purchase.
As per your query i have checked a lot of technical sites and even Sun microsystems,but I found that this network device can not be installed in a windows platform as this only supports Solaris Operating System.Please find the detail here http://docs.oracle.com/cd/E19113-01/quad.fast.sbus/804-6116-10/804-6116-10.pdf
The Sun Quad FastEthernet SBus adapter is supported on systems running the Solaris operating environment, versions 2.4, 2.5, 2.5.1, 2.5.1 Hardware releases, and 2.6. The Sun Quad FastEthernet PCI adapter is only supported on systems running the Solaris 2.5.1 Hardware releases and Solaris 2.6.
Nov 24, 2011 | SMC Sun PCI Quad Fast Ethernet Card (p/n...
Can i take the old card out when installin the new d link
If you have bought a new pci Ethernet network card then yes you can, you need to completely turn off the computer and unplug from the power socket, taking the side panel off and locating your pci card, un-screw the clip that holding it in place making sure you dont touch any other part of the computer, and taking the old one out, remove the packaging from the new pci network card and pushing it into place making sure its completely down and before applying the screw to fix it in place, put the side panel back on, plug in the plugs and turning the computer back on making sure you re-place the Ethernet cable, after which on boot-up your computer will say new hardware found and install it if it doesn't do it by itself you will need to search or insert the driver cd that came with it to make sure it works perfectly. please let me know the outcome of this Kronoguy
Jul 06, 2011 | D-Link DFE-530TX+ Fast Ethernet PCI...
Download software realtek RTL8139Family PCI fast ethernet NIC
Hi..
To download a realtek fast ethernet network interface card.you just search in the internet, just type the realtek rtl8139 then chose the free download driver then start to download,
Regards
PCmania
Jul 10, 2009 | Generic Memory Computers & Internet
Network card cnet pci-bus adapter without drivers for linux pleas
Install the drivers that came with it. it's usually comes witha CD. If not, download the drivers from cnet website. After you install the drivers turn off your computer, open the cover of your CPU and plug the adapter on any available PCI slot. When your restart your computer the card will be detected and drivers will b e installed automatically.
Jun 08, 2009 | Cnet : 10/100 PCI FAST Ethernet Card...
Drivers
If it is a laptop or a brand PC, just post a new request on Fixya with computer's make and model, for explample Dell optiplex 120, we will find the drivers for you.
Ifcomputer is assembled you will need to access the motherboard, and the audio card and posthere the code number printed on the motherboard, on on a sticker on top of the motherboard, and post also numbers you find on all device cards (PCI, AGP etc.).
Here is how board identification numbers look like
See also:
Motherboard Identification
and
How to Find Out Your Motherboard Manufacturer and Model
Sep 13, 2008 | Creative Labs Sound Blaster Live! 5.1...
Need Ethernet port on PC
If you have a wireless router then the ethernet cable will go between the modem and the router. Then you need a wireless LAN card to connect the PC to the router
What model router and modem do you have?
PC wireless card
Jul 03, 2008 | D-Link DFE-530TX+ Fast Ethernet PCI...
Vist driver for n/w card
This is the best you can do, if these Winbond drivers don't work, you'll need to buy a new card. They're pretty cheap, around $20 or so. Make sure it's Vista certified!
http://www.driversplanet.com/device.php?id=78807
Jul 01, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
71 people viewed this question
Top Winbond Electronics Corp Computers & Internet Experts
David Payne
David Payne
Are you a Winbond Electronics Corp Computer and Internet Expert? Answer questions, earn points and help others
