Question about KitchenAid Dishwashers
Hi, I have a Kitchenaid KUDI01TJWH0 dishwasher that failed. Any of the front control buttons like Heavy-Normal-RinseOnly or even the HiTemp-EnergySaver .... when you press any of these, the corresponding light for it will blink three times and go off. Normal operation that light for that button will come on and stay on. but none of the lights stay on. If you press start, the 'water heating' light will come on and you will hear the pump run for about 10-15 senconds, and then everything goes off, pump, water heating light, and then nothing. We cycled the power, but that didnt do anything. Any and all help appriciated!
Hi Your Problem is Probably The Control Panel. Not The Electronic Control. The Plastic Piece Across the Top of the D/W, Which Tells the Control What to do But You Must Realize These Parts Can Be Very Expensive. John H. Been in this Business 35 Yrs
Posted on Sep 29, 2010
How do you reset a KitchenAid dishwasher model: KUDE70FXSS4?
Press High Temp Scrub and Dry Heat option buttons in quick succession one after the other for about 6 sec until all the lights come on. Then press Cancel button. This should reset the dishwasher. Press equivalent buttons on the panel if the actual ones above are not there.
Make sure the dishwasher detergent dispenser lid is shut and the dishwasher door is shut before you start the above reset sequence.
Jan 02, 2013 | KitchenAid Dishwashers
KitchenAid dishwasher KUDM01TJBS0 does not start.
Most likely your keypad is bad. Will need to replace the console.
Nov 20, 2011 | KitchenAid Dishwashers
Kitchenaid dishwasher Kudio1il 24'stainless steel. Problem with control panel. Dishwasher will not start. Only NORMAL button, HI-Temp button, Energy Saver Dry button, and cancel button light up when...
I'm having similar problem.I uploaded video of my attempt to reset and problem that I have after.I've already tried replacing my board... but have the same problem. The board was a refurb... so not sure if the board sent was defective - or if the problem is the control panel or something else?? thoughts?https://www.box.com/shared/ef486b70331cd4462ed6
Oct 05, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Is there a replacement door for a Kitchenaid kudi01tjwh0 dishwasher made of stainless steel? Maybe another model with the same size/layout of the door?
Applianceart.com has stainless steel options for door panels as well as a faux stainless steel that was on HGTV. I'm not sure if the panels they have would fit your model, but their rolls of stainless would definitely help.
Nov 24, 2009 | KitchenAid 24 in. KUDI01TJ - Multiple...
My diswasher won't work
Kitchenaids have a diagnostic service mode ... but each model can be different on how to activate. The mode is started by sequentially pressing a number of the control buttons repetitively. The particular sequence is usually listed in service technician paperwork within the dishwasher behind the low kick plate in front of the dishwasher.
Or web search "Kitchenaid KUDPO1FL S7 diagnostics" which may help you understand this whole process
Good luck on your troubleshooting
Jan 16, 2018 | KitchenAid 24 in. KUDI01FLSS Stainless...
Control panel lights but won't start
the front control panel fries out.. We had to have ours replaced after 7 months ... after that was replaced it only lasted 2 months... WE ARE VERY disappointed and will be calling once again tomorrow. The dishwasher is not even a year old yet!
Aug 16, 2009 | Maytag MDC4650AW Built-in Dishwasher
KUDI01TJWH0 kitchen aid....the clean light is blinking and wont do anything else....how do we reset or do we just need to take it in for repair?????
To invoke the diagnostic cycle, perform the following key presses in less than 6 seconds while in standby.
Heated Dry -> Normal -> Heated Dry -> Normal
Invoking the diagnostic cycle clears all status and last run information from memory and restores defaults. It also forces the next cycle to be a sensor calibration cycle. (quoted from service diagnostic cycle notes in troubleshooting guide)
Apr 16, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Maytag dishwasher mdbh950awb
Sounds like you have a control panel and/or control board issue. Normally when operator functions fail or "halfway" work the main control board, associated keypad, or wiring are the likely suspect. Now...another remote possibility could be the door latch not closing properly. However, this would affect ALL functions. I hope this helps you.
Jul 31, 2007 | Maytag 24 in. MDBH950AWS Built-in...
Clean Light Flashes
I found this post elsewhere. It seems to have worked for me: Our KitchenAid KUDP series dishwasher went into a mode where it would not start and would only respond to the cancel/drain button. The clean light would flash 7 times in a row, stop, and then repeat. I read that the 7 flashes indicates an error code and that the dishwasher has detected a problem in the heater element circuit. I tried to reset the error mode by turning off power for 15 minutes, however, that did not work.
We called for a repair. The service person found that the dishwasher was completely fine except that it had gone into an error mode. The technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We were told the dishwasher expects to see the dish water temperature rise in a certain way. If the water does not heat in this way, the dishwasher becomes confused and thinks the heater element has failed. In deed, this happened just following and extended power failure and our hot water tank was cool. I am curious if this code will work for anybody else with the same problem and save a service call and 115 bucks. Overall, this seems to be a serious logic flaw in the design.
Oct 07, 2006 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwashers Logo
233 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
